Work with probe
17 Sep 2015 22:01 #62710
by verser
Replied by verser on topic Work with probe
It is my mistake, I apologize. RAPID_FEED fixed in RAPID_SPEED in the first post in the installation instruction.The famous RAPID_SPEED error has struck... just downloaded from git and installed on the axis sim. Screenshot shows the required entry in the ini DOES exist. Where to from here?
The following user(s) said Thank You: racedirector, licantrop
17 Sep 2015 22:01 #62711
You may need to turn on the option of G-code access to INI parameters:
linuxcnc.org/docs/html/remap/remap.html#...i_file_configuration
Replied by andypugh on topic Work with probe
- racedirector
- Thank you received: 41
18 Sep 2015 06:43 #62733
by racedirector
Replied by racedirector on topic Work with probe
Oh boy, I am an idiot. Thanks Andy, forgot to do the FEATURES = 30 bit. Pays not to play with these things in the wee hours of the morning.
19 Sep 2015 23:11 #62786
by cncbasher
Replied by cncbasher on topic Work with probe
ok i have just installed probe_screen , am i correct in that the origins and locations of the screen buttons align for a Gantry router
rather than say a mill . as it feels to me that the xy directions are incorrect for a mill those being the x axis is left to right , and the y front to back.
i.e the x axis is the longer of the 2 , either that or my brain is taking to interperting incorrectly.
if so i can possibly see some configuration issues as it grows .
however excellent work ,loving it allready .
19 Sep 2015 23:58 - 20 Sep 2015 15:12 #62787
by verser
If the x axis begins right to left, it is required to change only probe_screen.glade file, flip all X buttons relative to the central columnok i have just installed probe_screen , am i correct in that the origins and locations of the screen buttons align for a Gantry router
Last edit: 20 Sep 2015 15:12 by verser.
20 Sep 2015 22:58 #62818
by thor44
Replied by thor44 on topic Work with probe
I don't seem to have the file probe_screen.glade or at least I can't find it. Can some one give me an idea were it might be?
- LearningLinuxCNC
- Thank you received: 61
20 Sep 2015 23:11 #62819
by LearningLinuxCNC
it is in the icons folder.
Replied by LearningLinuxCNC on topic Work with probe
21 Sep 2015 01:03 #62820
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic Work with probe
I noticed a couple of pages back that someone is having trouble using the probe tab when NGCGUI is installed on the same machine.
I have not seen that anyone has a resolution to this.
Is it still an issue, or is the a workaround?
Ray M.
Ray M.
Albert Einstein
- allenwg2005
21 Sep 2015 01:32 - 21 Sep 2015 02:00 #62821
by allenwg2005
Replied by allenwg2005 on topic Work with probe
Great stuff!!
A fantastic addition for LCNC.
Many thanks to Verser and all who contributed.
I'm reluctant to monkey with my .ini anymore than I have without guidance.
Here is an abbreviated copy of the "LCNC start errors" and the section of my ".ini that applies.
What changes should I make here?
Thanks for any help.
Last edit: 21 Sep 2015 02:00 by allenwg2005.
The following user(s) said Thank You: verser
21 Sep 2015 03:38 #62823
by cncbasher
Allen:
email me your current ini file
Time to create page: 0.385 seconds
