Work with probe
14 Mar 2016 13:50 - 14 Mar 2016 13:51 #71632
by cncbasher
Replied by cncbasher on topic I can not configure
DEBUG = 0xbda
change to DEBUG = 0
[DISPLAY]
DISPLAY = axis
MBED_TAB_NAME=Probe Screen
change to EMBED_TAB_NAME = Probe Screen
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
change to DEBUG = 0
[DISPLAY]
DISPLAY = axis
Last edit: 14 Mar 2016 13:51 by cncbasher.
14 Mar 2016 14:07 #71634
by cusna
Replied by cusna on topic I can not configure
Thanks now works !
I do not know how it happened, probably a copy paste
I have another question, out of curiosity.
because if I delete files .axisrc go out and return from LinuxCNC does it anyway?
14 Mar 2016 15:32 #71643
by csbrady
Replied by csbrady on topic Work with probe
I recently added a touch probe and the probe software is very well thought out and nice to use. However, found a few bugs that I am currently working on. I found that the behaviour is a bit erratic, mostly working but occasional goes in the weeds. The code that waits for a function to complete sometimes returns early, causing a variety of weird problems. I have a fix, but I need to tidy up the code and fix another issue. I'll post the fixes when they are done.
14 Mar 2016 21:39 #71655
by csbrady
I ran into a couple problems in probe_screen.py. I managed to work around the first but am stuck on the second one.
The first problem was the code not waiting for gcode and ocode segments to finish. I determined that the function linuxcnc.wait_complete() sometimes will return on the first probe signal and not when the ocode or gcode segment completed. This led to a variety of problems. I worked around the problem by replacing the wait_complete() with:
while self.stat.interp_state <> linuxcnc.INTERP_IDLE :
time.sleep(.1)
self.stat.poll()
This fixed all of the strangeness, but I ran into another, related issue.
Before issuing a command the code switches to MDI mode using the following lines:
self.command.mode( linuxcnc.MODE_MDI )
self.command.wait_complete()
Once again I confirmed that intermittently the wait_complete() does not wait and the command gets issued without being in MDI mode, getting an error. I put a debug statement after the wait to print an error if we get there without being in MDI mode. I can't figure out a way to work around this in the probe code. Unless someone else has some insight I'll delve into the linuxcnc code and try to figure out why it is not working. It seems odd that Linuxcnc would work at all if such a common function such as this is broken so I must be missing something.
BTW: With the first fix everything works as long as you manually set the mode to MDI before probing.
time.sleep(.1)
self.stat.poll()
14 Mar 2016 21:56 #71656
I wonder if it is somehow specific to Glade? Axis uses the sequence as-written and is probably the best-tested UI we have.
Replied by andypugh on topic Work with probe
17 Mar 2016 00:43 #71752
by gizmo6023
Replied by gizmo6023 on topic Installing Work with probe
I am attempting to install this on my mill and have apparently done something wrong as I am getting error messages on start:
Debug file information:
Can not find -sec RS274NGC -var PARAMETER_FILE -num 1
Can not find -sec DISPLAY -var INTRO_GRAPHIC -num 1
Can not find -sec DISPLAY -var INTRO_TIME -num 1
File "/usr/bin/axis", line 2916, in <module>
max_feed_override = float(inifile.find("DISPLAY", "MAX_FEED_OVERRIDE"))
TypeError: float() argument must be a string or a number
4796
PID TTY STAT TIME COMMAND
4845
Stopping realtime threads
Unloading hal components
4796
4845
17 Mar 2016 00:53 #71753
What is the entry in MAX_FEED_OVERRIDE in the INI? (perhaps it is blank?)
Replied by andypugh on topic Installing Work with probe
17 Mar 2016 01:21 #71755
by gizmo6023
this is the line from my .ini
MAX_FEED_OVERRIDE = 1.2
17 Mar 2016 01:24 #71756
Odd.
Do you have a text editor that allows you to turn on visibility of invisible characters?
I wonder if there is something wierd on that line.
You could try deleting it and re-typing it.
The following user(s) said Thank You: verser
17 Mar 2016 01:30 #71757
by gizmo6023
I do not think my editor is that sophisticated but but not sure, Linux is a foreign language to me at the moment, only been using it for a little over a month while attempting to get my machine running.
I deleted and re entered the value in the .ini and get the same error message.
Odd.
Time to create page: 0.251 seconds
