Hitachi X200 VFD
- racedirector
- Thank you received: 41
05 Apr 2016 01:01 #72756
by racedirector
Cheers
Replied by racedirector on topic Hitachi X200 VFD
Thanks Danny, will play this one and see what I can come up with....comp file enclosed. There's some stdout messaging I was using for diagnostics that need to be removed.
Cheers
01 Jan 2017 16:53 #85021
by dannym
Replied by dannym on topic Hitachi X200 VFD
The X200 VFD has a notably serious bug here.
IF you send it a zero frequency (RPM), and enable Run mode, it will hang with isRunning=1 and spindleAtSpeed=0. IIRC it has to be literally zero, not just a freq below the minimum freq in the setup. Sending a new, valid frequency command will not make it run again.
Cycling power on the VFD will work but due to its huge internal caps it takes more than a minute of off-time. Sending the Reset command across ModBus WILL fix the condition.
I added some logic that the vfd-run pin won't be set unless rpm is above a min. I also added a VFD Reset button on pyvcp and, for kicks, a red/green button for VFD packet errors, and a short one-shot latch for "error" to guarantee it displays. This was informative, I now see the VFD does get some noisy error packets when accelerating and decelerating.
- racedirector
03 Jan 2017 06:50 - 03 Jan 2017 06:50 #85132
by racedirector
So is there a trick to getting this compiled? I just did a source install of LinuxCNC (2.7), copied the wj200_vfd folder, renamed it to x200_vfd, changed the code as required plus renamed it x200_vfd, changed the Submakefile to read x200_vfd in all positions where wj200_vfd existed and then made LCNC, The x200_vfd component DIDN'T get compiled.... and I have no idea why.
Anyone have any pointers?
Cheers
Bruce
Cheers
Bruce
Last edit: 03 Jan 2017 06:50 by racedirector.
03 Jan 2017 07:08 - 03 Jan 2017 07:09 #85133
by dannym
I compiled only the x200_vfd file. However, I gotta say, it was not straightforward even with help. It's not bizarre or anything but it's kinda like "a guy who knows what he's doing may not be able to blindly quote you the exact compile link but he can poke around and make it work easily enough". I was not a guy who knew what he was doing.
I don't have what actually worked written down.
I'll see if I can get the source up on sourceforge.
Last edit: 03 Jan 2017 07:09 by dannym.
- racedirector
03 Jan 2017 07:16 #85134
by racedirector
Hahaha, sounds like me.... I know just enough to be dangerous I am great at copy and paste but terrible at starting for scratch
03 Jan 2017 09:38 #85137
Replied by andypugh on topic Hitachi X200 VFD
The next-level-up submakefile might need instructing to look in your new folder.
But, have you tried compiling just the component with halcompile?
- racedirector
03 Jan 2017 10:54 #85138
by racedirector
Found it, hidden in the main Makefile under the src directory... all compiled now and ready to test.
Apparently you can't use halcompile due to the dependency on libmodbus
- racedirector
04 Jan 2017 12:41 #85195
by racedirector
Well I am back on my re-modified mb2hal mainly due to this components tendency to just disconnect from modbus whenever it felt like it.
Time to create page: 0.628 seconds
