Absolute linear scales
- Thank you received: 1369
03 Nov 2016 19:49 #82388
Replied by Todd Zuercher on topic Absolute linear scales
It appears Linuxcnc applies path blending to all moves including G0 moves. That is not how I thought the planner was supposed to work. I thought that all G0 moves were supposed to be pure positioning moves and behave like a G61 move. In my humble opinion this is a bug.
Your config probably has G64 as a default setting, you can either change that to G61 or add a P tolerance to the default G64 setting. That should straighten out your corners.
The following user(s) said Thank You: terkaa
03 Nov 2016 19:57 #82389
by terkaa
Replied by terkaa on topic Absolute linear scales
Ah, this explains it. Thank you.
Tero
Tero
Time to create page: 0.445 seconds
