Tool path going off the grid on my display screen.
01 Sep 2016 10:16 - 01 Sep 2016 10:17 #79821
by Jena Lynn
Tool path going off the grid on my display screen. was created by Jena Lynn
My tool path on the control screen goes 90 degrees away from my part set up. No matter where I set my x y z. Is it my post processor, or is it a setting in EMC2/ Probotix/ Meteor/ Fireball. I just get Exceeds x or Exceeds y when I try to run it. Thank you all.
Last edit: 01 Sep 2016 10:17 by Jena Lynn.
- Thank you received: 5925
01 Sep 2016 13:18 #79830
Replied by tommylight on topic Tool path going off the grid on my display screen.
More info would be helpful, such as what software (CAM), post processor, your machine setup ( hal and ini files) etc.
Also attach the ngc file you are using.
In the mean time check if you have any offsets active and cancel them.
linuxcnc.org/docs/2.5/html/common/User_C...hen_you_8217_re_lost
01 Sep 2016 13:56 #79835
by Jena Lynn
Replied by Jena Lynn on topic Tool path going off the grid on my display screen.
Hi Tom, I posted a simple drilling cycle with the same Mastercam post that you tried for me. I touched off the same place that I had it set up as in Mastercam on the front right corner of the stock. The view on the router screen has the stock rotated 90 degrees and the display has the cutter path way left and off the stock. Is there an F key or something to rotate the stock in the control?. I'll send the program later today. Thank you.
01 Sep 2016 16:24 #79839
by Jena Lynn
I might have an answer, just maybe. Normal machining for me is x left and right and y front and back, both from the spindle. This router is opposite. I can check and see if that is my issue.
01 Sep 2016 18:31 #79863
Yup, check that and let us know.
The origin has to be lover left corner, almost always.
If the origin is set to lower right, as i understood from your post, it wont work as the axis will complain about exceeding limits.
01 Sep 2016 23:46 #79886
by Jena Lynn
Yes, that was it. x 29.5 won't fly,lol, y, no problem. Thank you for the support. I'm sure I'll need more help.
02 Sep 2016 00:05 #79888
You are welcomed. As usual.
03 Sep 2016 09:53 #79965
by Jena Lynn
Yes, that fixed it. Y is x and x is y to me on that machine.
03 Sep 2016 14:10 #79973
Glad you got it going!
Time to create page: 0.177 seconds
