What is your configuration batting average?
- schmidtmotorworks
- Thank you received: 6
13 Nov 2016 07:37 #82735
by schmidtmotorworks
What is your configuration batting average? was created by schmidtmotorworks
I am asking, when you have the instructions to connect something and have all the wires etc.
What % of the time you do get it right on the first try?
I almost never do, I almost always have some misunderstanding or mistake to correct.
13 Nov 2016 16:59 #82742
Replied by andypugh on topic What is your configuration batting average?
I achieve approximately 0%
I count it as a win if i get to use the same hardware for my second attempt.
- Thank you received: 5907
13 Nov 2016 18:53 #82744
Replied by tommylight on topic What is your configuration batting average?
I do get over 90% overall, counting cases when i do not have instructions.
But i did electronic since i was a kid.
That makes for nearly 40 years of experience.
I am lacking on the mechanics front, not for knowledge, for implementing things as it takes a lot of time and i am always pressed for time. Having a really smal lathe and no mill does make a huge impact on the results. That made me concentrate on building smal engravers and plasma cutters as they do not require heavy metal parts. Retrofits i can do easily, and thanks to Andy and other members of this forum, programing anything complicated gets to be also easy, in most cases.
Time to create page: 0.063 seconds
