Problem with probing (Repeat)
20 Nov 2016 03:39 #83019
by ericg
Problem with probing (Repeat) was created by ericg
sorry to repeat the topic I started in general topics, but I just thought it might be better to ask another question here.
I'm grasping at straws but I just realised the issue I'm having with probing has started since I stopped using one set of drivers and then buying and installing a gecko g540, during that interval I see I upgraded to 2.7.8 (just a normal agree to upgrade without thinking).
Is it possible that a bug has been introduced causing my issue and if so how could I check?
Eric
Eric
- Thank you received: 5872
20 Nov 2016 06:23 #83020
Replied by tommylight on topic Problem with probing (Repeat)
I do not think it is a bug, i am pretty sure it is related to inverting the polarity of the signal in the g540.
It would have been much more apropriate to check that first, instead of insisting on a bug.
Open the hal file and find the said input, just add a "-not" to it, that should fix it.
20 Nov 2016 06:55 #83021
by ericg
Replied by ericg on topic Problem with probing (Repeat)
That is already there and I removed it temporarily also to no avail, so it the "-not" is now back in, and I'm not insisting it is a bug, just asking about the possibilty
Thanks for the thought anyway
Eric
Eric
21 Nov 2016 05:45 #83051
Did you manage to find the culprit ?
Do you use a different probe for auto levelling ?
Regards,
Regards,
21 Nov 2016 09:51 #83057
by ericg
thanks for the query,
I may have found a workaround at least, it is nothing to do with the g540 or the wiring, that was misleading me due to the timing of installing it.
Now I definitely did not have issues last time I used the software, all was fine, it was about 3 weeks before I got things running again with the g540 (waiting on parts for previous system, failing to fix, buying the gecko etc)
So then I had this issue and incorrectly suspected a wiring problem, however looking at the subroutine call that the pendant makes it has the lines
<pre>
o100 sub
( Set current Z position to 0 so that we will always be moving down )
G10 L20 P0 Z0
( Probe to Z-10 at F25 [Uses machine units, I work in mm, this is meant to be slow!] )
G38.2 Z-10 f25
( Set Z0 at point where probe triggers with offset of +1.55 [this is the thickness of my PCB plate. You must adjust this for your plate / setup] )
G10 L20 P0 Z1.55
( Rapid up to Z10 above the material )
G0 Z10
o100 endsub
</pre>
Autoleveller creates the code
G0 X0 Y0 Z0
G38.2 Z-10 f100 <- this is where is barfs
So I placed
G10 L20 P0 Z0 in front of that line and it worked.
I have not checked extensively and will try more in a couple of days, but hopefully that will be a simple fix.
I read up a bit on G10 L20 but still trying to learn what it means. (I'm just a part time hobbyist so the learning is slow)
Again, probably not a bug in 2.7.8 but is it possible there has been a coding change?
thanks for the interest.
Eric
<pre>
o100 sub
G10 L20 P0 Z0
G38.2 Z-10 f25
G10 L20 P0 Z1.55
G0 Z10
o100 endsub
</pre>
G0 X0 Y0 Z0
So I placed
Eric
Time to create page: 0.148 seconds
