Z Axis Homing
01 Dec 2016 17:50 #83531
by Les91
Z Axis Homing was created by Les91
When homing the Z axis I get the error message: "Probe tripped during homing motion".The Z axis homes correctly then gives the error message. X and Y axis do not give an error message when they are homed first. I can't determine what is causing this error. If I sequence homing X then Y then Z, X and Y are properly homed and Z homes then gives the above error message. Would appreciate any help.
01 Dec 2016 22:26 #83545
by BigJohnT
Replied by BigJohnT on topic Z Axis Homing
Assuming you have a probe installed my best guess is electrical noise from the Z axis is getting into the probe input.
JT
JT
02 Dec 2016 14:19 #83576
Replied by andypugh on topic Z Axis Homing
If you _don't_ have a probe then it might be a HAL config problem.
05 Dec 2016 21:55 #83704
by Les91
Replied by Les91 on topic Z Axis Homing
Thanks for your reply. I have the probe input grounded. It just dawned on me that it may be inverted. I will check that.
Les91
Les91
07 Dec 2016 19:47 #83751
by Les91
Thanks for your reply. Why didn't think on removing the Z axis probe? This solved the problem and I am able to continue checking out my machine. I really didn't need the Z axis probe.
Time to create page: 0.061 seconds
