How to setup a 4axis gantry plasma machine using gmoccapy?
16 Dec 2016 10:00 #84263
Sorry, I have not built my table yet so can't help on that one. I will be following your journey.
Replied by rodw on topic How to setup a 4axis gantry plasma machine using gmoccapy?
Hi, rodw. My problem is not the rotary, now. It's the gantry squaring. That's why I asked for the JA setup.I think that swapping the axes may be a solution. But now I need to know how to configure Hal pins and INI file parameters.
The following user(s) said Thank You: emad
17 Dec 2016 01:26 #84300
I don't understand what you are saying here.
Can you try try re-phrasing it?
Replied by andypugh on topic How to setup a 4axis gantry plasma machine using gmoccapy?
I can't alter the HAL manually without a GUI.
- Thank you received: 5923
17 Dec 2016 08:38 #84313
Replied by tommylight on topic How to setup a 4axis gantry plasma machine using gmoccapy?
I am on the phone so i can not help much, but i know there is a wiki on seting up 2 motors on the same axis, and if you study the ini file you can easily figure out how and what to change. So make a usual config for 4 axis, and edit the ini file to set the A axis as the second Y or X axis. This is for 2.8pre version.
17 Dec 2016 17:51 #84332
by emad
Replied by emad on topic How to setup a 4axis gantry plasma machine using gmoccapy?
andypugh wrote: I don't understand what you are saying here.
I meant that I can't edit the HAL without the help of Stepconfig which does it for me. Because I had no idea about how Linuxcnc works.
17 Dec 2016 17:58 - 17 Dec 2016 18:02 #84333
by emad
I did it :d I can now move the machine with X Y Y Z B configuration.Thank you all for giving help. please, I need to know about the THC wiring and about the Gmoccapy plasma section also Hal pins. Please, don't expect me to rephrase my sentences because my native tongue is Arabic and I can hardly speak English.
Last edit: 17 Dec 2016 18:02 by emad.
17 Dec 2016 20:08 #84338
This thread and the attached configuration files might help.
forum.linuxcnc.org/38-general-linuxcnc-q...other-plasma-install
Good luck with the rest of your build.
18 Dec 2016 22:14 #84376
I am very aware that most of the people in the world do not speak English. But often a different combination of words can make the meaning more clear.
There are (often only partial) translations of the LinuxCNC documentation in French, and the software itself has a number of language choices:
github.com/LinuxCNC/linuxcnc/tree/master/src/po has entries for de, es, fi, fr, hu, it, ja, pl, pt, ru, ro, sk, sr, sv and Chinese.
If you fancy a project that would increase your understanding of the software, perhaps you would like to consider making an arabic translation file?
19 Dec 2016 01:49 #84389
by emad
Hi Andy. I have already tried to make an Arabic translation using Poedit but I can't find the technical words and acronyms in The Fus-ha ( Standard Arabic). That's bigger than me. I wish I could help. sorry.
19 Dec 2016 01:58 #84390
by emad
By the way, there is a typo in the main page linuxcnc.org/
Full source code available under under the terms of the GNU GPLv2 (General Public License version 2).
The word "under" is repeated.
19 Dec 2016 12:01 #84405
Fixed, thanks.
Fixed, thanks.
Time to create page: 0.156 seconds
