Knows someone this error message
- Holzwurm56
04 Jan 2017 13:11 - 04 Jan 2017 13:12 #85198
by Holzwurm56
Knows someone this error message was created by Holzwurm56
Hello,
i am retrofitting wood cnc machine with 5I25 and 7I77. I have connect the 3 encoder and when i move the axes withhand the dros are working. I test the servosystem with an analog signalgenerator, the axes are moving with a + - 10V signal, then i connect the amplifier inputs with the analog output from the 7i77 the axes move very very slow, normally i think they had to stand still. When i activate the manual working button on axis after two seconds the button is deaktivated and there is a error message: "joint 2 following error". Does someone knows what this mean?
Hans
Hans
Last edit: 04 Jan 2017 13:12 by Holzwurm56.
04 Jan 2017 14:18 #85208
Replied by andypugh on topic Knows someone this error message
It sounds like the axes are simply drifting, and that the PID loop and LinuxCNC are not correcting the position.
Have you checked that the 7i77 analogue outputs are working?
It may be that your scalemax / maxoutput paramters are set much too low in the HAL / INI.
- Thank you received: 1369
04 Jan 2017 14:51 #85214
Replied by Todd Zuercher on topic Knows someone this error message
Have you tried tuning the PID loop in Linuxcnc?
- Holzwurm56
04 Jan 2017 15:26 #85220
by Holzwurm56
Replied by Holzwurm56 on topic Knows someone this error message
Hello,
in what kind of way can i test the analog outputs. When the analog outputs are not to the servos connected and the servos enable there is no drift and i cannot move the axes with hand.
Means "Joint 2" that this means axes 2?
Hans
Hans
04 Jan 2017 15:47 #85223
Replied by PCW on topic Knows someone this error message
You should expect a slow drift (or even a fast runaway, so be careful ) and following errors
when first enabling the servo loop and before things are tuned. Here is JTs velocity mode tuning guide:
gnipsel.com/linuxcnc/tuning/servo.html
If you are using Axis, the ""Machine --> Calibration" menu item can be use for tuning the PID values
Time to create page: 0.132 seconds
