parallel port no signal
- doityourselfer
27 Jan 2017 22:28 #86806
by doityourselfer
parallel port no signal was created by doityourselfer
I installed LinuxCNC via this ISO image onto a partition of my machine.
I've configured my machine but no signal is being sent to the parallel port.
I was able to control the machine using Grbl and my Arduino.
Any help on why there is no signal on the parallel port?
- Thank you received: 5925
27 Jan 2017 23:44 #86809
Replied by tommylight on topic parallel port no signal
When using stepconfig on the second page uncheck "sim" or "simulator" or something like this.
I can not recal the exact naming and i am on a tablet so i can not check.
- doityourselfer
28 Jan 2017 12:07 #86834
by doityourselfer
Replied by doityourselfer on topic parallel port no signal
thanks tommylight,
I'm assuming you are referring to the "create simulated hardware configuration" check box which is unchecked but there is still no communication.
28 Jan 2017 12:52 #86837
More info on the hardware/software would be helpful, but you can edit the address port in the stepconf or hal to 0 (zero) if you have only one paraport. What does sudo lspci -v say?
- doityourselfer
28 Jan 2017 13:41 #86840
by doityourselfer
I just read another forum that suggested finding the lspci -v and after finding out what my port address was and entering it rather than leaving it 0. This Worked!!!
