hitachi wj200
30 Jan 2017 01:25 #86936
by cmtunnel
hitachi wj200 was created by cmtunnel
I'm installing a wj200 after my huanyang blew up. I am wondering what kind of changes need to be made in linuxcnc to make it work and what are the settings on the drive that are important to a correct installation. Not much info out there for the hitachi and I'm new to working with vfd's and a little gun shy.
31 Jan 2017 02:03 #87029
Replied by andypugh on topic hitachi wj200
Are you controlling with analogue voltage or modbus?
In the former case, you will wire up pretty-much identically. If modbus, then you need to change the HAL component and the HAL pins will all change too.
31 Jan 2017 13:53 #87062
by cmtunnel
Replied by cmtunnel on topic hitachi wj200
Hmmm. Is there any reason to use modbus? analogue works fine for me.
31 Jan 2017 16:49 #87073
You might get more info back, such as spindle current and bus voltage.
However, analogue is more realtime.
31 Jan 2017 17:30 #87075
by cmtunnel
analogue will do it for now. I'm just getting ready to get back into this. I am planning on hooking the shield to the same ground that the motor and vfd use with no termination at the motor end.....is this best? How do I use the driver that I have read about linuxcnc already has loaded...do I need to load it or is is called up in the config files??
31 Jan 2017 18:03 #87076
You shouldn't need to change anything at all in the software. Just wire the new VFD exactly the same way as the old VFD.
31 Jan 2017 18:57 - 31 Jan 2017 20:58 #87087
by cmtunnel
Awesome. How about the drive settings....should I just mimick what was done with the HY or are there more things to be concerned with. I just want to get the machine back online now and worry about the fancy stuff later...I'm just apprehensive after blowing the hy. I've got an ac reactor on the way also.
edit: also, should the motor be run in constant torque mode for a router?
Last edit: 31 Jan 2017 20:58 by cmtunnel.
01 Feb 2017 00:32 #87103
I imagine the manual will take you through the setup? It helps if you have nameplate data from the motor, though
(Maybe write that in the manual)
01 Feb 2017 01:08 #87105
by cmtunnel
Yeah I've been working through it. I didn't know how many poles the spindle was so I used 4 and it seems to be running as it should. I'll get the analogue working tomorrow.
01 Feb 2017 09:41 #87116
You can figure out the pole count from the rated speed @ frequency.
3000 rpm @ 50 hz = 2 pole, 1500 rpm @ 50 Hz = 4 pole. etc.
