3 home switches but 4 axes?
07 Feb 2017 21:13 #87488
by SvenH
3 home switches but 4 axes? was created by SvenH
I'm finalising the configuration for my new gantry router.
This one has home switches on x, y and z but not on the a-axis.
Can i set up the configuration so that I can actually run the machine?
It now homes x, y, and z fine but I can not run a program because the a-axis does not get homed.
I have not given the a-axis a pin for the home switch when I made the configuration. The configuration has since been altered.
I have tried commenting out the home info in the a-axis area in the .ini file and tried to work in the .hal file but that is more confusing to me...
I have tried a lot of googling but all hits seem to be about no switches at all or switches on every axis.
Any tips?
Any tips?
07 Feb 2017 21:25 #87490
by bevins
Try HOME_SEARCH_VEL = 0 for that axis
Might want to read up on homing.....
linuxcnc.org/docs/2.4/html/config_ini_homing.html
Replied by bevins on topic 3 home switches but 4 axes?
Any tips?
08 Feb 2017 07:01 #87516
by SvenH
Replied by SvenH on topic 3 home switches but 4 axes?
Thanks for the reply bevins.
I'd actually tried that already but that dis not work.
I found out this morning that I had to add something else too.
I now have:
HOME_USE_INDEX NO
HOME_LATCH_VEL 0
HOME_SEARCH_VEL = 0
HOME_SEQUENCE = 3
The last one being the game changer.
I now have:
HOME_USE_INDEX NO
HOME_LATCH_VEL 0
HOME_SEARCH_VEL = 0
HOME_SEQUENCE = 3
08 Feb 2017 22:54 #87615
by bkt
Replied by bkt on topic 3 home switches but 4 axes?
3.12. Immediate Homing
If an axis does not have home switches or does not have a logical home position like a rotary axis and you want that axis to home at the current position when the "Home All" button is pressed in Axis the following ini entries for that axis are needed.
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
I hope these help
Giorgio
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
I hope these help
Giorgio
