Going back to a machine home every start up
- Wolfmansbrother
- Topic Author
28 Mar 2017 17:12 #90452
by Wolfmansbrother
Going back to a machine home every start up was created by Wolfmansbrother
Hi all,
I know what I want to do, I just don't know if it is possible.
I want to use small dc motors like encoders, but, I want to write this position to a file, and when linuxcnc starts up, it looks at these positions and "subtracts" that distance in movement so the machine starts in the same place each time.
If this has been extensively covered pardon me.
I am looking through hal documentation atm
- Thank you received: 5918
28 Mar 2017 20:01 #90456
Replied by tommylight on topic Going back to a machine home every start up
You can not use DC motors as encoders, they are not the same thing, not even close. You can use a DC motor as a tacho for biger motors and that would be velocity mode control so you would nees apropriate drives, plus encoders if you want position mode control.
Tell us more anout your existing machine and what you want to do with it.
If you just need to know XYZ positions after a shut down, just add a file named last_position to your config directory, and add the entry to ini file.
That way the machine will know the position it was shut down at.
If you need to have repeatable 0 position, you need home switches added to the machine and wired, that way no matter what position machine was on, it will find the same starting position all by itself.
29 Mar 2017 11:39 #90495
Sounds like you want the [TRAJ] POSITION_FILE option.
linuxcnc.org/docs/2.7/html/config/ini-config.html#_traj_section
Replied by andypugh on topic Going back to a machine home every start up
