Problem with stepper system cutting oversize.
13 Apr 2017 23:27 #91333
by jbunch
Problem with stepper system cutting oversize. was created by jbunch
I am having a problem where the system is cutting over size.
I am running:
Debian Wheezy
2.8-pre
Gecko 201X drives
Mesa 7i76
Intel mini ITX MB
5mm per rev ball screws
stepper motors are 200 steps per rev
At first it was cutting under-size by quite a bit so I played with the acceleration settings and it no longer cuts under-size.
Now it cuts oversize by what looks to be about 3 steps per inch. In doing the math it should be 1016 steps per inch X 10 for the microstep on the Gecko drive. That makes it 10160.00. steps per inch. where am I making my mistake in my calculations? How does the size grow?
Jim
I am running:
Debian Wheezy
2.8-pre
Gecko 201X drives
Mesa 7i76
Intel mini ITX MB
Jim
14 Apr 2017 01:51 #91338
Replied by PCW on topic Problem with stepper system cutting oversize.
Your calculations look correct
Are the errors consistent?
That is, if you move back and forth does it return to the same place?
If the errors are consistent and proportional to distance that suggests a ball screw tolerance issue
If you get inconsistent readings, it could be a lot of things:
Lost steps from wrong timing or too high acceleration
excessive backlash etc etc
- Thank you received: 5909
14 Apr 2017 11:29 #91354
Replied by tommylight on topic Problem with stepper system cutting oversize.
Check the screws, i have some NOOK ones that are 5.08 mm per revolution and some NSK that are 5mm. Made me scratch my head on occasions.
- Thank you received: 1369
14 Apr 2017 13:06 #91362
Replied by Todd Zuercher on topic Problem with stepper system cutting oversize.
5 TPI is a common screw lead and is very close to 5mm (it is 5.08mm)
14 Apr 2017 14:02 - 14 Apr 2017 14:03 #91364
Replied by rodw on topic Problem with stepper system cutting oversize.
If it is not a metric/imperial thing, I would test the axis using a metal ruler and a programmed known distance. You can calculate the percentage error and convert that to steps and adjust. If you use move relative commands you can do multiple passes. When I had a similar problen due to non standard gear rack, I got it close against a 1.0m steel rule then set a dial indicator up so I could measure the error after 20 metres of travel.
Last edit: 14 Apr 2017 14:03 by rodw.
19 Apr 2017 15:50 #91642
That's a very small error. You say that it is 10160 steps per inch and you are out by 3 steps, or 0.0003"
How are you measuring this?
Replied by andypugh on topic Problem with stepper system cutting oversize.
Time to create page: 0.075 seconds
