Config Yaskawa Servo SGDH-30DE-0Y step/dir
14 Apr 2017 14:13 #91365
by BRITWA
Config Yaskawa Servo SGDH-30DE-0Y step/dir was created by BRITWA
I HAVE servo SGDH-30DE-0Y(driver SGMGH-30DCA6F-0Y With 17 bit encoder utsih-b17ck )
Screw pitch 10mm Z axis, 5mm X Axis
I have a few questions at the bottom:
SGDH-30DE-0Y
Pn000 Control mode selection = n0010.
Pn202 Electronic Gear Ratio (Numerator)?
Pn203 Electronic Gear Ratio (Denominator)?
Linuxcnc
Motor steps per revolution=32768X4?((
Driver microstepping =1?
SGDH-30DE-0Y
Linuxcnc
19 Apr 2017 15:52 #91643
Replied by andypugh on topic Config Yaskawa Servo SGDH-30DE-0Y step/dir
The final answer is a single "SCALE" number in the INI. It doesn't matter how you get to that number as long as it is the right number. You could just calulate it by hand, it needs to be steps/inch or steps/mm depending on machine units.
Time to create page: 0.831 seconds
