Sticking Home/Limit Switches - Please help
31 May 2017 17:50 #93900
by McAdam
Using a multimeter across the pins on the BOB I see 9V.
I have tested with standard switches and also switches that have resistors limiting it to 5V.
Just an update...
I have been working on the machine all day (still doing config stuff)with all switches in NO mode, and it was working fine for homing.
BUT, it seems that after a few hours - even with all switches being NO - something sticks.
e.g. Z homes, makes contact with the switch (verified via halscope) then it backs off, the switch is physically disconnected but halscope shows it as connected for another 5-10 seconds.
So it seems that the issue is continuing to grow in intensity.
It seems to me that there may be a build up of something (im not an electrician but perhaps static, emi, atomic radiation???)
That's the only explanation I have about why it just keeps getting worse and worse..
Apart from ordering another Motherboard and Stepper Drivers, does anyone have any ideas?
Replied by McAdam on topic Sticking Home/Limit Switches - Please help
I don't think I would connect the 0V from the 48V power supply if that is the one to power the steppers.
Indeed, it is likely to introduce noise from the chopper in the drive. Though some drives make the connection for you, unfortunately.
This is all a but puzzling.
What voltages do you see across the inputs with a multimeter?
Just an update...
31 May 2017 18:49 #93901
by McAdam
Another update...
For Z (untested on others)
If I Jog - then manually activate home switch, it sticks.
Jog z + , switch toggles perfectly fine
WTF?
I am seriously at the point of just buying one of the ready made BOB and Controllers...
WTF?
- Thank you received: 5924
31 May 2017 20:37 #93902
Replied by tommylight on topic Sticking Home/Limit Switches - Please help
Following this from the start, i can only come to a conclusion that something is very wrong with the :
Power supplies making to much ripple
BOB with personality issues <<<<least likely
Miss wiring on the ground side of the things, therefore creating a different potential between pins.
You mentioned that you get 9V at the BOB pins, that is not OK in any way for a 5V BOB, see above about ground <>potential.
31 May 2017 20:52 #93903
by Clive S
Replied by Clive S on topic Sticking Home/Limit Switches - Please help
I have not checked but going from memory this bob inputs are fed from the 12-24V power supply and I think they could be at 9V. This is why I asked for a drawing of how it is exactly wired up preferably with a pic.You mentioned that you get 9V at the BOB pins, that is not OK in any way for a 5V BOB, see above about ground <>potential.
31 May 2017 22:05 #93908
by McAdam
Clive you're right, it is fed 12v for the inputs, and I have seen mention elsewhere of 9v across the pins.
I just spent an hour trying to make a diagram but the tool got too annoying so I trashed it...
Might try paper and pen...
01 Jun 2017 13:27 #93927
by McAdam
01 Jun 2017 13:52 #93932
Replied by andypugh on topic Sticking Home/Limit Switches - Please help
Each switch is wired to an input pin and the shared GND terminal?
What voltage do you measure between the terminals and the shared GND 1) When no switches are triggered 2) When they have "stuck"
01 Jun 2017 14:00 #93934
by McAdam
Correct
1) 9v
2) 9v
3) 0v (when triggered - currently in NO)
I can also confirm that they only get stuck when jogging/moving in + direction, not when moving in -
When they have stuck I can still see the voltage go from 9v to 0v when triggered.
Maybe I can try to measure the voltage on the DB25 Connector pins... But not sure which ones
Correct
1) 9v
2) 9v
01 Jun 2017 14:03 #93935
So, the voltages at the screw terminals behave correctly, but the values on the parallel port pins don't.
How curious.
You could try measuring the voltages on each side of the opto-couplers (input and output pairs)
How curious.
01 Jun 2017 14:15 #93937
by Clive S
I am away for a few days. But I take it you are using a correct type of PP cable as they are not always pin to pin. Try another one.
Time to create page: 0.148 seconds
