Spindle-Pitch
12 Aug 2017 11:06 #97361
by Tchefter
Spindle-Pitch was created by Tchefter
Hi @All, I need to change the spindle pitch in my machine and do not want to do this via the STEPCONF Wizard since otherwise all my adjustments are gone. Can someone write me how I can change this manually? (I think this must be in mymachine.ini)
(Google-Translation )
Regards Fritz
Regards Fritz
12 Aug 2017 11:14 #97362
by tecno
Replied by tecno on topic Spindle-Pitch
Als eine gute maßnahme
Always include your .ini and .hal files so you can get easier help.
12 Aug 2017 11:59 #97366
by Tchefter
Replied by Tchefter on topic Spindle-Pitch
Hi Tecno, thanks for the Info
here they are
here they are
15 Aug 2017 13:25 #97508
I am afraid that Google has made a bad job of the translation, as it is unclear what you mean by "spindle pitch". What was the phrase in German(?)
Replied by andypugh on topic Spindle-Pitch
(Google-Translation)
16 Aug 2017 03:47 #97544
by Tchefter
Hi Andy, thanks for your reply.
i mean the LeadScrew in German: Trapezgewindespindel.
I have a TR12x3 and mean that this is only 12x2.9 or 12x2.8.
When I measure with the dial gauge, so 3mm, then I am at 2.9mm.
So would like to try a few things, but would not want to destroy my configuration.
But I could also configure a new machine to test, which should have the same effect.
16 Aug 2017 05:34 #97546
Replied by rodw on topic Spindle-Pitch
Assuming it is the Z axis you need to change. Open up your .ini file and find this block
Then change this line which is the number of steps per mm. eg. the number of stepper pulses to move your axis by 1.0mm. You must allow for any gearing and microstepping
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 23.75
MAX_ACCELERATION = 100.0
STEPGEN_MAXACCEL = 125.0
#BACKLASH = 0.0400
SCALE = 533.333333333
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -100.0
MAX_LIMIT = 100.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_SEQUENCE = 0
16 Aug 2017 10:31 - 16 Aug 2017 10:31 #97560
It is very unlikely that your 3mm leadscrew is 2.9mm. It is more likely that you are losing steps, or have backlash, or some other mechanical issue.
I could understand 3.175mm pitch, or 2.54, but 2.9 seems very unlikely.
Last edit: 16 Aug 2017 10:31 by andypugh.
16 Aug 2017 18:26 - 16 Aug 2017 18:48 #97591
by Tchefter
Thank you rodw and andy for reply,
well the trapezoid thread spindle is not as precise as a ball screw, so i think der must be an error.
A few weeks ago a shaft coupling is broken, now i changed all couplings from cheap to a "little higer prized" one.
That makes a lot of positiv different to the machine, it runs smoother, anyway...
I got also a " Antibacklashnut " (poormans solution = Feather an and a second Nut)
The topic of lossing steps I've already thought, only the problem is how do I notice this?
Must i hear or see it?
For Example:
When I make a wooden box with finger tenons, the tenons are mostly 2/10 larger and the counterpart 2/10 smaller.
For a TR Leadscrew i think tjhis is not bad
I hope it is not too confused for you
regards Fritz
For Example:
regards Fritz
Last edit: 16 Aug 2017 18:48 by Tchefter.
Time to create page: 0.106 seconds
