- Configuring LinuxCNC
- Basic Configuration
- Geckodrive G540 won't come out of fault. Charge Pump issue?
20 Sep 2017 07:15 #99152
by Evan
Geckodrive G540 won't come out of fault. Charge Pump issue? was created by Evan
The config below works as long as I have the charge pump switch turned off on the G540. The motors have holding torque & I can jog around no problems. But when I flip the switch back it just sits with the fault light on. But I'd very much like to have it work properly.
I'm new to both LinuxCNC & using the G540. Here's my HAL file:
I was thinking it may be the way I have the estop configured, but I've tried a couple different combinations so far based on what I've seen in other solutions on this forum, including both inverting pin 15 & just unsetting it entirely. The only physical e-stop is connected to the power supply, and doesn't communicate with the G540. The terminal-block pins #10 & #12 on the bottom of the G540 are shorted to have the "input disabled" state kept at 0v.
Now I'm assuming it's an issue with the charge pump signal. I read that the G540 pulls too much current on this pin? Here's a photograph of my oscilloscope probing pin #16 (ground is on pin #25):
So it's putting out the required signal of over >10kHz that the G540 requires, but since this isn't probing in-line, I'm not sure what it's like when the drive is pulling it. Also, I'm not sure why the voltage is shown so high at max=51.2v & min=10v. Seems weird.
Here are my PCI Parallel port details:
One last thing, but when I cut power to the G540, it very briefly will exit the fault state where I'll hear the motors engage & the green light comes on, just before power completely fades. This only happens when the parallel port cable is plugged in!
Anyone have some ideas?
# Generated by stepconf 1.1 at Tue Sep 19 22:40:25 2017
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0xcc00 out"
setp parport.0.reset-time 1000
loadrt stepgen step_type=0,0,0,0
loadrt charge_pump
net estop-out charge-pump.enable iocontrol.0.user-enable-out
net charge-pump <= charge-pump.out
addf charge-pump base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-05-out-invert 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
setp parport.0.pin-07-out-invert 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net charge-pump => parport.0.pin-16-out
net estop-ext <= parport.0.pin-15-in-not
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 25200
setp stepgen.0.dirsetup 25200
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 25200
setp stepgen.1.dirsetup 25200
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 25200
setp stepgen.2.dirsetup 25200
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 25200
setp stepgen.3.dirsetup 25200
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd
net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net aenable axis.3.amp-enable-out => stepgen.3.enable
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
$ lspci -v
01:0a.0 Communication controller: MosChip Semiconductor Technology Ltd. PCI 1 port parallel adapter (rev 01)
Subsystem: LSI Logic / Symbios Logic PCI 1 port parallel adapter
Flags: medium devsel, IRQ 18
I/O ports at cc00 [size=8]
I/O ports at c800 [size=8]
I/O ports at c400 [size=8]
I/O ports at c000 [size=8]
I/O ports at bc00 [size=8]
I/O ports at b800 [size=16]
Kernel driver in use: parport_pc
Kernel modules: parport_pc
$ dmesg | grep parport
[ 10.631746] parport0: PC-style at 0xcc00 (0xc800), irq 18 [PCSPP,TRISTATE,EPP]
[ 10.728182] lp0: using parport0 (interrupt-driven).
20 Sep 2017 16:06 - 20 Sep 2017 16:07 #99168
Replied by PCW on topic Geckodrive G540 won't come out of fault. Charge Pump issue?
This is a known issue on the G540: it needs considerable high side drive from the parallel port to run the charge pump
but Gecko chose Parallel port pin 16 to drive it. Unfortunately pin 16 is a open collector driver with a weak pull-up _unless_
the parallel port is in EPP mode (its a push-pull output in EPP mode)
As a first try I would set the port to EPP mode in the loadrt hal_parport command line in your hal file
and if that fails, add a stiff pullup resistor (say 300 Ohm) to pin 16
Last edit: 20 Sep 2017 16:07 by PCW.
21 Sep 2017 02:06 #99188
by Evan
Replied by Evan on topic Geckodrive G540 won't come out of fault. Charge Pump issue?
Tried setting the loadrt line to:
But when running LinuxCNC I got the following errors:
And dmesg shows this:
And then if I change it back to use "out", LinuxCNC still won't start up and gives me a dmesg log similar to the one above, but says this error instead:The only way to get it working again I've found is to reboot after changing the
I'm guessing my parallel port PCI card doesn't play nice with trying to be put in EPP mode by LinuxCNC? This is the card I installed , and the description says it supports EPP mode.
Unless you see an obvious issue I'm overlooking, I'll probably try to install a pull-up resistor or switch to one of those Mesa cards people seem to like.
loadrt hal_parport cfg="0xcc00 epp"
Starting LinuxCNC...
Found file(REL): ./sherline2k_gecko540_4axis.hal
insmod: ERROR: could not insert module /usr/realtime-4.1.0-1-rtai-686-pae/modules/linuxcnc/hal_parport.ko: Device or resource busy
./sherline2k_gecko540_4axis.hal:6: exit value: 1
./sherline2k_gecko540_4axis.hal:6: insmod for hal_parport failed, returned -1
[ 198.730481] config string '0xcc00 epp'
[ 198.730595] PARPORT: ERROR: request_region(0xffff) failed
[ 201.171445] RTAI[math]: unloaded.
[ 201.192047] SCHED releases registered named ALIEN PEDV$D
[ 201.201354] RTAI[malloc]: unloaded.
[ 201.300022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 201.314217] I-pipe: head domain RTAI unregistered.
[ 201.314229] RTAI[hal]: unmounted.
PARPORT: ERROR: port parport0 claim failed
21 Sep 2017 02:17 - 21 Sep 2017 02:18 #99189
What version of LinuxCNC?
Just tried here and it works fine (2.7 and 2.8)
looks like it does not understand the EPP token and tried to extract an address instead
Last edit: 21 Sep 2017 02:18 by PCW.
21 Sep 2017 02:24 - 21 Sep 2017 02:32 #99190
by Evan
My version is 2.7.11, running on LinuxMint with rtai kernel realtime-4.1.0-1-rtai-686-pae
Edit:
Also, when trying to start up after changing it back to "out", it gives this error in the console:Not sure if it's helpful.
Edit:
insmod: ERROR: could not insert module /usr/realtime-4.1.0-1-rtai-686-pae/modules/linuxcnc/hal_parport.ko: Resource temporarily unavailable
Last edit: 21 Sep 2017 02:32 by Evan.
21 Sep 2017 02:37 #99191
I've seen this:
happen when LinuxCNC does not exit gracefully, you may have to re-boot and retry the epp type flag
21 Sep 2017 02:45 #99192
by Evan
Yeah, I tried rebooting but it just keeps failing. In order to get it back into a working state (excluding the charge pump, of course), I have up update it back to say "out", and then reboot again.
21 Sep 2017 03:28 #99193
by Evan
So I decided to just solder up a pull-up resistor. Connected a 470 ohm resistor between pin-16 and the 5-volt line on the card from pin-62 on the PCI slot. Works great now!
Time to create page: 0.117 seconds
