Where are Mesa 7i76e physical pins configured?
01 Jun 2019 12:03 #135558
by JetForMe
Where are Mesa 7i76e physical pins configured? was created by JetForMe
I found the wonderful connection guide that shows the pin names like `hm2_7i76e.0.7i76.0.0.input-05`, but I can't figure out where in the `.hal` file I'd put a line including that to configure it as a limit switch. The pin names generated by PnCConf seem to be higher-level than that:
net max-x => axis.0.pos-lim-sw-in
Where is `axis.0.pos-lim-sw-in` defined?
When I tried to do this:
net max-x <= hm2_7i76e.0.7i76.0.0.input-05
LinuxCNC complains that `axis.0.pos-lim-sw-in ` is already defined. That implies to me that `axis.0.pos-lim-sw-in` and `hm2_7i76e.0.7i76.0.0.input-05` are synonyms for the same pin, but where is that defined?
Sorry for the basic question, still figuring this out.
01 Jun 2019 12:56 #135562
Replied by PCW on topic Where are Mesa 7i76e physical pins configured?
pncconf does not create pin names, pin names come from LinuxCNCs components
For example:
is a pin created by LinuxCNCs motion component
(man motion for a list of all of motions pins)
and
is a pin created by the hostmot2 hardware driver component
pncconf does create signals ( with the net command ) that link pins from
component to component. ( the created signal is "max-x" in your example )
In fact one of the main purposes of the hal file is to create these connections
For example:
and
The following user(s) said Thank You: JetForMe
01 Jun 2019 13:03 - 01 Jun 2019 13:08 #135564
by BigJohnT
Replied by BigJohnT on topic Where are Mesa 7i76e physical pins configured?
It can be a bit confusing at the start. The first thing you need to understand is the net command. Have a short read of that here...
linuxcnc.org/docs/2.7/html/hal/basic-hal.html#_net
In your ini file in the [HAL] section you can see what hal files are being loaded and in what order. The axis.0.pos-lim-sw-in is a signal so you can't assign a signal to a pin.
Assuming your using the 2.7 version of LinuxCNC the pin names for limit switches are axis.N.neg−lim−sw−in and axis.N.pos−lim−sw−in where N is the axis number. The motion pin names are here...
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
It might be easier to use my 7i76e configuration tool as it is just for that card only.
jethornton.github.io/7i76e/
JT
JT
Last edit: 01 Jun 2019 13:08 by BigJohnT.
01 Jun 2019 13:07 #135565
by bevins
This is one of mine, but this is on 2.8
net x-home-sw => joint.0.home-sw-in
net x-home-sw => hm2_5i25.0.7i70.1.0.input-45-not
Are you on 2.8? IF so use joints.
post your hal file..... Then we can see whats going on.
Replied by bevins on topic Where are Mesa 7i76e physical pins configured?
01 Jun 2019 14:23 #135568
by pl7i92
Replied by pl7i92 on topic Where are Mesa 7i76e physical pins configured?
it woudt be a great Help for the people here
if you upload your HAL and INI
so we can understand better what is going on
YOU can get a look on the alredy connecte pins
with MASHINE Menue Halshow
if you are on AXIS
if you are on AXIS
01 Jun 2019 23:18 #135594
by JetForMe
Replied by JetForMe on topic Where are Mesa 7i76e physical pins configured?
Do you recommend using 2.8? I can upgrade to that if so.
01 Jun 2019 23:24 #135596
by BigJohnT
I use 2.8 on 2 of my 3 CNC machines just because I've not gotten around to creating my lathe GUI in QtPyVCP and I'm still polishing up my plasma GUI.
JT
JT
01 Jun 2019 23:26 #135597
by JetForMe
My long-term goal is to run Tormach's PathPilot on this machine, once I get it figured out. I might have to stick to 2.7 to make that easier, we'll see. (I have two other Tormach machines, and I like the interface.)
01 Jun 2019 23:45 #135598
by JetForMe
JT,
Does your config tool require X to run? Can it run on macOS? I tried installing it but skipped the bit about .xsessionrc. When I run I get:
I do have python installed at that location.
$ 7i76e
-bash: /usr/local/bin/7i76e: /usr/local/opt/python/bin/python3.7: bad interpreter: Operation not permitted
$ /usr/local/opt/python/bin/python3.7
Python 3.7.3 (default, Mar 27 2019, 09:23:15)
[Clang 10.0.1 (clang-1001.0.46.3)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
03 Jun 2019 06:34 #135698
Replied by andypugh on topic Where are Mesa 7i76e physical pins configured?
Do you know what PathPilot is based on? I have a feeling that it is a hybrid of LinuCNC 2.7 and Machinekit, in which case you probably don't want to go to 2.8 because the HAL and INI are significantly different. (in content rather than in format)
I would wait until / if PP moves to 2.8 before making the switch. Unless you have a gantry machine in which case I think I would suggest 2.8 and _not_ PathPilot.
Time to create page: 0.321 seconds
