Hal confusion
19 Aug 2019 17:16 #142502
by jensor
Hal confusion was created by jensor
Booting into Axis, Failure Is:
LINUXCNC - 2.7.11
Machine configuration directory is '/home/jack/linuxcnc/configs/bridgeport'
Machine configuration file is '1BP.ini'
Starting LinuxCNC...
(time=1566230313.311088,pid=7391): Registering server on TCP port 5005.
(time=1566230313.311205,pid=7391): running server for TCP port 5005 (connection_socket = 3).
iocontrol: machine: 'LINUXCNC-1BP' version '2.7.8'
Found file(REL): ./1BPstepper.hal
Found file(REL): ./2X-BoxPinOutTest.hal
./2X-BoxPinOutTest.hal:125: Pin 'parport.2.pin-03-out' was already linked to signal 'estopactivated'
Line 66 in 2X-BoxPinOutTest.hal is apparently causing a problem.
I cannot find where the name "estopactivated" is mentioned in any file being used, 1BP.ini, 1BPstepper.hal, or 2X-BoxPinOutTest.hal Files are attached.
What can be causing this error? (By the way - It used to work ok, but apparently something has gotten contaminated.)
Is there a better way to connect the hal pin "halui.estop.is-activated" to a parallel port pin?
jensor
LINUXCNC - 2.7.11
jensor
19 Aug 2019 17:40 #142504
by pl7i92
Replied by pl7i92 on topic Hal confusion
the halui pin you use needs to be in a postgui file
you can use the motion pin
iocontrol.0.user-enable-out
19 Aug 2019 17:46 #142505
Replied by PCW on topic Hal confusion
You have a conflict in2X-BoxPinOutTest.hal:
net estopactivated halui.estop.is-activated parport.2.pin-03-out
net allhomed logic.0.and parport.2.pin-03-out
- Thank you received: 1369
19 Aug 2019 17:51 #142509
Replied by Todd Zuercher on topic Hal confusion
In line 66 of the file 2X-BoxPinOutTest.hal is the linethen again in in line 126 you tried to connect the same parallel port pin
Any pin name can only be used once in all of your active hal files.
19 Aug 2019 18:07 #142512
by jensor
Replied by jensor on topic Hal confusion
Replacing:
With:
net estopactivated iocontrol.0.user-enable-out parport.2.pin-03-out
Leads to error:
LINUXCNC - 2.7.11
(time=1566237632.285896,pid=10078): Registering server on TCP port 5005.
(time=1566237632.286038,pid=10078): running server for TCP port 5005 (connection_socket = 3).
./2X-BoxPinOutTest.hal:66: Pin 'iocontrol.0.user-enable-out' was already linked to signal 'enable'
So this command isn't available before the postgui file
With:
Leads to error:
LINUXCNC - 2.7.11
19 Aug 2019 18:36 #142514
Postgui has nothing to do with it. It is the fact that you already used that pin name earlier on line 49.
- Online
- Thank you received: 5929
19 Aug 2019 22:35 #142524
Replied by tommylight on topic Hal confusion
You can omit that line or change the pin out number.then again in in line 126 you tried to connect the same parallel port pin
.net allhomed logic.0.and parport.2.pin-03-out
20 Aug 2019 01:17 - 20 Aug 2019 01:18 #142531
by jensor
You're right on line 126. My mistake, however still a problem.
Todd -
48 # create a signal for the estop loopback
49 net enable iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
no reference to parport.2.pin-03-out there.
Doing a search in the file shows only one instance of parport.2.pin-03-out since I deleted it on line 126.
Still get same original error:
So still the question how can it already be linked?
Todd -
Last edit: 20 Aug 2019 01:18 by jensor. Reason: add text.
20 Aug 2019 01:33 #142533
Search for multiple occurrences of: iocontrol.0.user-enable-out
20 Aug 2019 02:04 - 20 Aug 2019 02:16 #142536
by jensor
No other occurrences of "iocontrol.0.user-enable-out".
jensor
jensor
Last edit: 20 Aug 2019 02:16 by jensor.
Time to create page: 0.280 seconds
