Following errors after upgrade.
24 Feb 2020 16:03 #158388
by sliptonic
Following errors after upgrade. was created by sliptonic
I've been running linuxcnc 2.7 on my mill for a couple years. I recently upgraded to build both linuxcnc and machinekit from source so I can test development work being done in FreeCAD Path workbench.
After building LinuxCNC 2.9, all the tests pass. When I launched the mill configuration, the script prompted for automatic upgrade which I allowed. Now the mill config starts and shows gmoccapy. But when I try to enable the machine, the Z axis moves momentarily and then throws a following error.
I assume this is related to the 2.8 joint/axis merge. Since none of the joint configuration numbers changed, it must need some additional configuration for the joints that I'm missing. Any ideas?
Working machinekit configuration: github.com/sliptonic/millstone/tree/gmoccapy
Failing Linuxcnc configuration: github.com/sliptonic/millstone/tree/linuxcnc-2.9-gmoccapy
- Thank you received: 5983
24 Feb 2020 16:15 #158391
Replied by tommylight on topic Following errors after upgrade.
Usually a discrepancy between axis/joints in the ini file.
I had such issues only once a long time ago when 2.8 was still in testing, cant recall the exact error.
Am on the phone, will try to have a look at the files later.
24 Feb 2020 17:56 #158401
by sliptonic
Replied by sliptonic on topic Following errors after upgrade.
I found a minor discrepancy between joint and axis in the max_velocity. Corrected this but it had no effect. Still get the error.
24 Feb 2020 18:21 #158406
Replied by PCW on topic Following errors after upgrade.
deleting all lines like:
net N-vel-fb => pid.N.command-deriv
Should fix the issue
24 Feb 2020 19:22 #158415
by Henk
Replied by Henk on topic Following errors after upgrade.
What PCW said worked in my case.
24 Feb 2020 21:44 #158424
by sliptonic
Yep, that did it. Thank you. I'm curious what's going on here. Perhaps there should be a note on the upgrade wiki page.
25 Feb 2020 08:21 #158443
by bbsr_5a
Replied by bbsr_5a on topic Following errors after upgrade.
is this caused by the Axis/joint conversion updater or by a new wizard config
- Thank you received: 1370
25 Feb 2020 17:30 #158473
Replied by Todd Zuercher on topic Following errors after upgrade.
I think it was caused by an error made by the old configuration wizard, but because of an old bug in the PID component, wasn't noticed until updating to the current version where the PID comp was fixed.
25 Feb 2020 19:00 - 25 Feb 2020 19:00 #158481
Yep that's basically it. The old PID component ignored its command_deriv input and
always calculated it internally. The new component uses the command derivative
input if its connected to a signal, and uses an internal calculation if its command_deriv
pin is unconnected. The problem is that some versions of pncconf connect an undriven
signal to the PIDs command_deriv pin, making the FF1 tuning term inoperative.
Last edit: 25 Feb 2020 19:00 by PCW.
25 Feb 2020 20:24 #158489
Replied by cmorley on topic Following errors after upgrade.
Well I'd suggest using black magic rather then a switch for this PID behavior was the real problem.
In fact I still think it should be changed.
In the very least the black magic should have checked if there was a driving pin connected.
Chris
Chris
Time to create page: 0.095 seconds
