Proximity Sensor Source
08 Jan 2016 03:13 #68048
by fc60
Proximity Sensor Source was created by fc60
Greetings,
Just spent two hours searching for an Inductive Proximity Sensor.
Plenty out there; but, I need one with a long, 2 meter, cable.
LJ12A3-4-2, I think is the part code.
I do know it is 12mm diameter x 60mm long.
NPN NO
Three wires, blue, black, and brown.
Please send me a link to a source.
With kind regards,
Dave in the USA
NPN NO
With kind regards,
Dave in the USA
- kornphlake79
- Thank you received: 10
08 Jan 2016 03:39 - 08 Jan 2016 03:43 #68050
by kornphlake79
Replied by kornphlake79 on topic Proximity Sensor Source
www.automationdirect.com/adc/Shopping/Ca...9K_(12mm)/PNM6-AN-3A
This was the cheapest I found that meets your requirements at about $18, not sure what sensing distance you need but automation direct sells the same sensor with other sensing distances for about the same price.
If you are willing to use a sensor with a quick disconnect you can get a cable up to 7 meters.
www.automationdirect.com/adc/Shopping/Ca...nce_(12mm)/PBM-AN-1H
Last edit: 08 Jan 2016 03:43 by kornphlake79.
The following user(s) said Thank You: fc60
08 Jan 2016 12:57 #68059
Replied by andypugh on topic Proximity Sensor Source
Why not extend the cable?
(Or take the cables to a small intermediate junction box so that you don't have the same problem next time)
23 Jan 2016 00:50 #68946
by fc60
Replied by fc60 on topic Proximity Sensor Source
Greetings,
Went to Automation Direct and purchased a new sensor. Wow, what a selection and they speak English.
Anyway, I have the new sensor and it is a "shielded" model. That is, the metal case goes all the way up to the "sensing" end. The old broken sensor appears to be the "non-shielded" variety. Where the metal case leaves about 4-5mm of plastic sensor on the end.
Not being an electrician, what is the difference between the two? The specification sheet lists the shielded as having 4mm range and the non-shielded at 7mm range.
The sensor is used to detect the HOME position of my mill.
Also, Automation Direct was very Customer focused and the sensor I received was Made In Germany. Shipping was also quite reasonable. I would recommend them to other users.
Cheers,
Dave
Cheers,
Dave
23 Jan 2016 01:05 #68947
The "shielded" type will work when embedded in metal with only the surface visible. The other type, if you put them in a hole in metal will detect the hole itself and never "un-trigger"
- kornphlake79
23 Jan 2016 02:54 #68951
by kornphlake79
I'm glad you enjoyed the experience, I have had nothing but positive experiences with automation direct. Their products don't quite compete with Allen Bradley or Siemens, but the work just as reliably in my experience and cost a fraction as much.
