Mesa Products in North America
- racedirector
- Thank you received: 41
11 Feb 2016 23:20 #70018
by racedirector
Replied by racedirector on topic Mesa Products in North America
Nice JT, just did a test order to see what the total plus shipping would be for 5i25 and 7i76 and was pleasantly surprised. Hopefully I can turn that into an order soon.....
11 Feb 2016 23:58 #70019
by BigJohnT
Don't forget a DB25M-DB25M IEEE cable...
JT
Replied by BigJohnT on topic Mesa Products in North America
JT
The following user(s) said Thank You: racedirector
12 Feb 2016 00:08 #70020
by rubes
Replied by rubes on topic Mesa Products in North America
Thanx JT...
- 5axisormore
12 Feb 2016 21:03 #70048
by 5axisormore
Replied by 5axisormore on topic Mesa Products in North America
How extensive of the line are you going to handle? I just bought back my old Hardinge HNC and will be trying to use the original resolver/tach combo, so I was wondering if you will be handling the resolver boards as well. The previous owner had sawed through the cables and got rid of the GE550T control cabinet, so I will replacing the HIACK drives with AMC's and using an AnTek Inc 500 watt torroidal power supply, but otherwise all the original parts including the parts catcher and cutoff slide. Possibly even attempting a PathPilot system on it at some point.
Fred
Fred
12 Feb 2016 22:13 - 12 Feb 2016 22:20 #70049
by BigJohnT
Hi Fred,
Yes, I'll be getting them on my next stock order. I really like the Antek power supplies. I plan on carrying everything I need to supply the CNC market.
JT
How extensive of the line are you going to handle? I just bought back my old Hardinge HNC and will be trying to use the original resolver/tach combo, so I was wondering if you will be handling the resolver boards as well. The previous owner had sawed through the cables and got rid of the GE550T control cabinet, so I will replacing the HIACK drives with AMC's and using an AnTek Inc 500 watt toroidal power supply, but otherwise all the original parts including the parts catcher and cutoff slide. Possibly even attempting a PathPilot system on it at some point.
Fred
Hi Fred,
JT
Last edit: 12 Feb 2016 22:20 by BigJohnT.
- B.Reilly01
- Thank you received: 11
04 Mar 2016 23:00 #71064
by B.Reilly01
Replied by B.Reilly01 on topic Mesa Products in North America
Do you think you'll be getting DIN RAIL mounts in? I've just discovered I have a nice spot on a din rail for my 7i77 if I can find a mount.
04 Mar 2016 23:10 - 04 Mar 2016 23:18 #71065
by BigJohnT
Yes, the components are on the way already. All I have to do is machine the aluminum bars on my VMC. I'm making mounts for both the daughter cards and the THCAD cards.
JT
JT
Last edit: 04 Mar 2016 23:18 by BigJohnT.
08 Mar 2016 13:56 #71219
by BigJohnT
I have another stocking order due in Friday that will add THCAD-10's, THCAD-300's and 7i80HD-16's to the cards already in stock.
In stock now.
5i24-16
5i25
6i25
7i37TA
7i76
7i76E
7i77
7i77ISOL
7i90HD
7i92
I also have 5vdc and 24vdc power supplies in stock.
JT
In stock now.
5i24-16
5i25
6i25
7i37TA
7i76
7i76E
7i77
7i77ISOL
7i90HD
7i92
JT
15 Mar 2016 22:28 #71703
by BigJohnT
The THCAD-10's, THCAD-300's and 7i80HD-16's are in stock now.
JT
JT
03 Apr 2016 20:23 #72650
by BigJohnT
Time to create page: 0.348 seconds
