Wanted to buy toolchanger code for Mori MVJR
- schmidtmotorworks
- Thank you received: 6
08 Mar 2016 06:39 #71205
by schmidtmotorworks
Wanted to buy toolchanger code for Mori MVJR was created by schmidtmotorworks
I did a retrofit of a MVJR a few years ago but never got the tool changer working.
I tried to do it with some help using Glade but it was over my head and there were some bugs at the time that prevented it from being completed on the current version at that time.
If there is anyone that has or knows how to make tool changer code for that machine I would like to buy it pay you to develop it.
I would be happy to make my configuration available to all if I could complete it.
08 Mar 2016 12:33 #71210
by BigJohnT
Replied by BigJohnT on topic Wanted to buy toolchanger code for Mori MVJR
It would help to know where your located at?
JT
JT
- schmidtmotorworks
08 Mar 2016 15:27 #71232
Replied by schmidtmotorworks on topic Wanted to buy toolchanger code for Mori MVJR
I am in Orange CA. Thanks for reminding me,
I can provide all the information needed for someone to code it from wherever they are.
All of the switches and sensors are already connected.
08 Mar 2016 16:36 #71237
Is it possible that integrating the tool-changer has become easier in the interim?
Have a look at the simulated VMC in sim->axis>Vismach->VMC_toolchange and see if that is anywhere close to the behaviour you need.
Replied by andypugh on topic Wanted to buy toolchanger code for Mori MVJR
If there is anyone that has or knows how to make tool changer code for that machine I would like to buy it pay you to develop it..
The following user(s) said Thank You: schmidtmotorworks
- schmidtmotorworks
08 Mar 2016 17:17 #71238
Thanks for the suggestion, I was not aware of that, it sounds like I have some catching up to do.
I will take a look at it.
I have been procrastinating doing an update,
My Umbuntu release raises a message that it is no longer supported for about 6 months now.
and 2.7.4 looks like a nice advancement.
I have been procrastinating because I am uncertain about the procedure to update Umbuntu and what other reinstallation work I will need to do.
Perhaps the best thing to do now would be to buy another hard drive so that worst case I can always get back to where I am today with minimal effort.
- Thank you received: 1369
08 Mar 2016 17:39 - 08 Mar 2016 17:43 #71239
Replied by Todd Zuercher on topic Wanted to buy toolchanger code for Mori MVJR
You don't have to change from Ubuntu 10.04 (unless you want to). Just open Synaptic, pull down the Settings menu, click on Repositories, click on Add, then paste this line, in the appropriate place.
deb buildbot.linuxcnc.org/ lucid 2.7-rt
Uncheck the old Linuxcnc version. Close the Repo window, and click on Mark all Upgrades and then Apply.
If you want to upgrade Ubuntu, the easiest way is to start over with a new live iso. Brace yourself for the switch to Debian, it's a little bumpy for those used to Ubuntu.
Last edit: 08 Mar 2016 17:43 by Todd Zuercher.
- schmidtmotorworks
08 Mar 2016 18:03 #71241
Thanks for the warning about "bumpy ride", to Debian, I am wondering what bumpy means? Are the bumps complicated problems like drivers and compatibility issues or just something different about the UI to get used to?
I am really satisfied with Ubuntu 10.4 but the message saying it is no longer supported can't be closed and it gets annoying sometimes, I can live with it though.
08 Mar 2016 20:57 - 08 Mar 2016 20:58 #71246
Disable the automatic updates and the warning message should go away. Use Synaptic to do your Linuxcnc updates then.
Mostly it is getting used to the new UI (or installing the UI you like). But also a number of features that were automatically installed or configured must be done manually, just little annoying types of things.
Last edit: 08 Mar 2016 20:58 by Todd Zuercher.
08 Mar 2016 23:43 #71253
by BigJohnT
I'm offering bumpless hard drives pre-loaded with LinuxMint 17.3, Mate desktop, RTAI kernel, and all my fixes. I still have 10.04 on 3 machines...
JT
JT
- schmidtmotorworks
08 Mar 2016 23:52 - 08 Mar 2016 23:56 #71254
I just ordered a new hard drive but that might be interesting, it was interesting to see, the original drive I built with was 32GB, now smallest one I found quickly on Amazon was 120GB SanDisc.
Do you have a web site to explain the details or a price?
Maybe I could send you the drive I just ordered and you could do a copy to it?
If I got your setup could I just copy my configuration to it and run it?
Last edit: 08 Mar 2016 23:56 by schmidtmotorworks.
Time to create page: 0.130 seconds
