Wanted to buy toolchanger code for Mori MVJR
- schmidtmotorworks
- Thank you received: 6
09 Mar 2016 08:48 #71258
by schmidtmotorworks
Replied by schmidtmotorworks on topic Wanted to buy toolchanger code for Mori MVJR
I found your site, but it "says out of stock".
Can I send you my drive and pay you to load it up?
This email address is being protected from spambots. You need JavaScript enabled to view it.
These are the parts in my build:
Mesa:
1 x 5i23
1x 7i48
2x 7i64
1x 7i44 RJ45
2x Custom cables (ask Mesa, the know what you need)
Intel Mother Board:
1X D510MO + 1gb memory
Hard Drive
32 GB solid state
Zumax Power Supply
ZU-400W ATX12V
Mesa:
1 x 5i23
1x 7i48
2x 7i64
1x 7i44 RJ45
Intel Mother Board:
Hard Drive
32 GB solid state
Zumax Power Supply
ZU-400W ATX12V
09 Mar 2016 22:51 #71292
by BigJohnT
Replied by BigJohnT on topic Wanted to buy toolchanger code for Mori MVJR
I've almost got the drive ready to be cloned. I should have them in stock in a day or two. I just need to check the image then start cloning.
JT
JT
09 Mar 2016 22:55 #71293
by BigJohnT
My site is mesaus.com
I could burn to your drive, I would have to check the final image size tomorrow.
Yes, you just copy your config to the ~/linuxcnc/configs/your-config directory.
I'm trying to make sure all the extras one needs for a cnc machine are included like G code generator and arc calculators hole pattern generators etc.
JT
Do you have a web site to explain the details or a price?
Maybe I could send you the drive I just ordered and you could do a copy to it?
If I got your setup could I just copy my configuration to it and run it?
JT
- schmidtmotorworks
09 Mar 2016 23:35 #71294
I tried to check-out on your site:
I should order the PCI version, right?
,,,but I got the following message:
If you want to update your site I can wait and order then.
(I can just keep and set aside the drive I ordered from Amazon as a back up)
Or if you want to send me an address and payment info I can mail my drive to you when it arrives.
Whatever is most convenient for you.
Best Regards
Jon Schmidt
Products marked with *** are not available in the desired quantity or not in stock!
Best Regards
Jon Schmidt
09 Mar 2016 23:40 - 09 Mar 2016 23:43 #71295
by BigJohnT
Yes, I've set the store up to not allow orders until I've got stock. I have the drives but I still need to double check the image in the morning and clone them. As soon as I know for certain I can ship when an order arrives I'll update the quantities so you can order. I'm just hardwired that way, I don't believe in vaporware, I have to have it in my hand ready to ship before I can accept your money. And yes the RTAI kernel PCI bus is the one you want and it is what I'm working on first. Let me see what the image size is when I'm done in the morning, it should be under 10Gb.
JT
JT
Last edit: 09 Mar 2016 23:43 by BigJohnT.
- schmidtmotorworks
10 Mar 2016 00:01 #71298
Sounds great, looking forward to it.
10 Mar 2016 12:37 #71327
by BigJohnT
RTAI hard drives are ready.
JT
JT
- schmidtmotorworks
10 Mar 2016 17:28 #71346
Ordered, thanks a lot for making the product available, this kind of thing helps someone like me a lot.
10 Mar 2016 18:03 #71349
by BigJohnT
Thanks for the order, it ships today.
JT
JT
The following user(s) said Thank You: Mike_Eitel, schmidtmotorworks
- schmidtmotorworks
15 Mar 2016 01:23 #71664
The package arrived today, thanks for the excellent service, I look forward to setting it up this weekend.
The following user(s) said Thank You: BigJohnT
Time to create page: 0.441 seconds
