Upgrading Linuxcnc
09 Jul 2016 22:04 - 09 Jul 2016 22:28 #77237
by BigJohnT
Upgrading Linuxcnc was created by BigJohnT
If you have a 2.5 install on Ubuntu 10.04 to upgrade you need to do the following:
Changes to your configuration
The user configs moved from $HOME/emc2 to $HOME/linuxcnc, so you will need to rename your directory, or move your files to the new place. In your user configs, check your ini file for references to the old path, such as [DISPLAY]PROGRAM_PREFIX. Update these by changing emc2 to linuxcnc.
The hostmot2 watchdog in LinuxCNC 2.5 does not start running until the HAL threads start running. This means it now tolerates a timeout on the order of the servo thread period, instead of requiring a timeout that's on the order of the time between loading the driver and starting the HAL threads. This typically means a few milliseconds (a few times the servo thread period) instead of many hundreds of milliseconds. The default has been lowered from 1 second to 5 milliseconds. You generally don't need to set the hm2 watchdog timeout any more, unless you've changed your servo thread period.
The old driver for the Mesa 5i20, hal_m5i20, has been removed after being deprecated in favor of hostmot2 since early 2009 (version 2.3.) If you are still using this driver, you will need to build a new configuration using the hostmot2 driver. Pncconf may help you do this, and we have some sample configs (hm2-servo and hm2-stepper) that act as examples.
If you are using a usb joypad you may need to rename the pin
input.0.btn-trigger
to
input.0.btn-joystick .
If you are using NGCGUI you will need to edit your configuration file to remove the line
USER_COMMAND_FILE = ./tkapp.py
as the 2.5 version does not use it.
Note: you don't have to upgrade LinuxCNC to 2.6 just upgrade your configuration then go on to 2.7.
To upgrade your configuration to 2.7
linuxcnc.org/docs/2.7/html/getting-start..._configuration_files
If you need an older LiveCD they are at linuxcnc.org/iso/
JT
input.0.btn-trigger
to
JT
Last edit: 09 Jul 2016 22:28 by BigJohnT.
16 Dec 2018 06:39 #122469
by pl7i92
Replied by pl7i92 on topic Upgrading Linuxcnc
BE AWARE THERE MAY BEE Config CHANGES
If You go to MASTER 2.8 You will see a different Interpreter on Start
And The Configs may Go Wheer
BEST is Always to be with the STABLE 2.7.14 at this TIME
CHANGING by Packet Source in SYNAPTIC is best to GO
06 Jun 2019 21:02 #136090
by Vector459
Replied by Vector459 on topic Upgrading Linuxcnc
I just purchased a mini lathe with linuxcnc2.5.4 on it and Ubuntu 10.04.LTS. I am used to Mach3 but over the last week and I getting better and understanding this software. I wanted to upgrade to a newer version so this helps. If I follow these instruction and update do I have to reconfig everything all over again ( ports, steppers etc ).. Or do my old setting files carry over to the update?
Since I bout this used and I am not sure of the leadscrews specs etc I wanted to try and save all that info an hoping it transfers over? I am scared I will lose the setttings and have to figure everything out from scratch.
I know with Mach3 you can just save your setting file and it has everything in it when you need to do a fresh install to avoid manually setting up again.
Thanks in advance!
Thanks in advance!
- Thank you received: 1370
06 Jun 2019 21:19 #136095
Replied by Todd Zuercher on topic Upgrading Linuxcnc
I'd recomend reading the upgrading section of the manual for the version you are upgrading to, (and probably any versions between the one you are using) to check for changes that you might need to make to your configuration. (They are all documented). (There are only a couple of minor changes needed between 2.5 and 2.7)
Yes, backup and store a copy of your config directory off of your computer should you ever need to restore it.
06 Jun 2019 21:44 #136100
by Vector459
Ok t thank for the reply. So when you upgrade you just copy your old setting files and that is? No need to go through setup all over again?
Just making sure I understand correctly.
thanks
thanks
- Thank you received: 5983
06 Jun 2019 21:59 #136105
Replied by tommylight on topic Upgrading Linuxcnc
Yes, just copy.
Granted you do not have any comp installed, and even that can be copied and installed again.
06 Jun 2019 22:18 #136112
by Vector459
Comp?
06 Jun 2019 22:22 #136115
by BigJohnT
Replied by BigJohnT on topic Upgrading Linuxcnc
User components, components not included with LinuxCNC that you wrote and installed.
JT
JT
07 Jun 2019 17:00 #136232
by Vector459
Ok thanks I understand now.
20 Aug 2019 02:46 #142540
by kborsum
Replied by kborsum on topic Upgrading Linuxcnc
Back in the early part of the year I acquired an old BOSS-II mill with a equally old tower computer running linuxcnc. I'm trying to replace the tower and paralell port and BOB Board with newer hardware. The AhHa stepper controller boards are still running fine.
Being somewhat new to LinuxCNC I have downloaded and installed the complete package of V2.7 on the new tower. During the download, there was a note to NOT allow ubuntu to upgrade the OS, or allow autoupgrade of the linux part. I am having problems getting linuxCNC to actually load and run, with a whole series of different errors.
I'm running on a Dell tower...not the fastest but adequate for my needs, which is a former Win-10Machine. There are two new parallel port cards that work just fine, as I have seen normal control of all the ports (spindle on/off, brake, and movement in all three axes) while going thru stepconfig. However, it insists on coming up in the AXES GUI and I have yet to figure out how to get it into the gmocappy format--or have it load successfully.
Is there a newer/different version of linuxCNC that would be more suitable for my setup? ie download it and start over?
Any suggestions would be appreciated as this is getting a but frustrating.
Kelly
Kelly
Time to create page: 0.632 seconds
