Install current master 2.8
- Thank you received: 5912
19 Sep 2016 14:12 #80610
Replied by tommylight on topic Install current master 2.8
It does, i have done it on many configs i am working on. On some you will need to edit the acceleration manually after the conversion, but most work without any issue.
- Thank you received: 1369
19 Sep 2016 17:19 #80621
Replied by Todd Zuercher on topic Install current master 2.8
There is a small burb about the updating script here.
linuxcnc.org/docs/devel/html/getting-sta...ript_for_joints_axes
It looks in your ini file under for an
[EMC]
VERSION = 1
If the version reference isn't there or is less than 1 it prompts for running the update script. I'd make a backup before trying to run the scrip even though it is supposed to automatically make a backup of any files it changes.
[EMC]
VERSION = 1
The following user(s) said Thank You: Mike_Eitel, terkaa
19 Sep 2016 19:31 #80630
by terkaa
Replied by terkaa on topic Install current master 2.8
Ok it seems there a quite a lot of changes to HAL and INI files. I will try to get this working...
Tero
Tero
19 Sep 2016 20:39 #80632
Did you give the script a try to see how much of a mess it makes of it? It might be a lot less work to fix the errors the script might make than to try to do everything by hand.
19 Sep 2016 21:29 #80640
Replied by andypugh on topic Install current master 2.8
I wrote the script. I intended it to work.
Please try it, and if it fails, let me know how it failed.
The following user(s) said Thank You: tommylight, terkaa
19 Sep 2016 22:11 - 19 Sep 2016 22:12 #80642
And it does create a backup of the existing config, i have tested it on 4 of my configs, all of them worked without issues. On one i had to lower the acceleration as it was set to 5000mm/s/s, although that might have been in the existing config, i just do not recall seting it that high, usually on that machine i have it at 2000.
Andy, thank you.
Andy, thank you.
Last edit: 19 Sep 2016 22:12 by tommylight. Reason: Almost forgot to thank Andy!
20 Sep 2016 09:10 - 20 Sep 2016 09:11 #80659
by terkaa
Ok, Master is now installed. I used auto script and everything seems fine. Also ABSOLUTE_ENCODER_HOMING = 2. I connected halui.joint.N.home pins to machine_enabled pin and that does turn DRO to green BUT I still need to press Gmoccapy home all button before I can jog axes. Why is this?
Tero
Tero
Last edit: 20 Sep 2016 09:11 by terkaa.
23 Sep 2016 21:12 #80838
by newbynobi
Replied by newbynobi on topic Install current master 2.8
Because your Ini does not contain
NOForceHoming=1
Norberf
Or just set all joints to be homed!
NOForceHoming=1
Norberf
23 Sep 2016 22:57 - 23 Sep 2016 22:58 #80840
by BigJohnT
Actually it is:
linuxcnc.org/docs/2.7/html/config/ini-config.html#_traj_section
JT
Replied by BigJohnT on topic Install current master 2.8
Tero
Actually it is:
[TRAJ]
NO_FORCE_HOMING = 1
JT
Last edit: 23 Sep 2016 22:58 by BigJohnT.
24 Sep 2016 05:43 #80845
by terkaa
I am 100% sure I had that before upgrading to 2.8 i have to check that it is still there after update script.
Tero
Tero
Time to create page: 0.099 seconds
