Install current master 2.8
24 Sep 2016 15:32 #80852
by BigJohnT
Replied by BigJohnT on topic Install current master 2.8
If you find out that was removed during the update, compare to the backup file the file a bug report.
JT
JT
24 Sep 2016 15:59 #80854
by terkaa
Replied by terkaa on topic Install current master 2.8
I will check this on monday
Tero
Tero
06 Dec 2016 11:38 - 06 Dec 2016 11:56 #83712
by emad
Replied by emad on topic Install current master 2.8
I have installed the master branch using the master zip archive from Github,I used the default Linuxcnc Debian ISO(rtai) to install
it because it has most dependencies installed. I can't find the master in Synaptic package manager but I can still run it from place .I've disabled the default Linuxcnc in Synaptic. My problem is the rip-environment script which I don't know how to use. I can't start the Stepconfig to setup 4axis gantry plasma machine.XYYZA.Norbert told me to start the config linuxcnc-dev/configs/sim/gmoccapy/gmoccapy-JA/Gantry/gantry_mm.ini .Do not forget to start from terminal and do a rip-environment befor starting the config.Than change the sim config to fit your needs.I don't know how to start it.
Last edit: 06 Dec 2016 11:56 by emad.
06 Dec 2016 13:36 #83713
Replied by rodw on topic Install current master 2.8
17 Jul 2017 14:09 #95895
by joel0407
Not quite. What is this?
"Upgrading to a new major version
If you're upgrading from one major version to another, for example from 2.6 to 2.7, you may need to do config changes! Read about it on the Wiki."
What do I need to read on the Wiki?
Happy Days
Replied by joel0407 on topic Install current master 2.8
Follow the instructions on the buildbot to configure synaptic. See
buildbot.linuxcnc.org/
Very easy
Happy Days
- Thank you received: 1369
17 Jul 2017 14:18 #95896
Replied by Todd Zuercher on topic Install current master 2.8
I would have referred you to the manual.
www.linuxcnc.org/docs/2.7/html/getting-s..._configuration_files
17 Jul 2017 14:27 #95898
Replied by andypugh on topic Install current master 2.8
config changes from 2.7 to 2.8 are extensive. Luckily there is a script that should make all of the required changes automatically. The script should run the first time you launch the new version and will ask if you want the config to be auto-converted.
- hardware_crash
07 Aug 2017 15:19 #97106
by hardware_crash
Replied by hardware_crash on topic Install current master 2.8
Hey guys,
Today I tried to download the master branch for wheezy with uspace: realtime with RT-Preempt, but it seems that the buildbot server is down .
Is there another way to install the linuxcnc master with rt-preemt ?
Thanks in advance
Lukas
Thanks in advance
Lukas
07 Aug 2017 15:27 - 07 Aug 2017 15:28 #97108
by grump
Replied by grump on topic Install current master 2.8
Dunno where you will get 2.8 from without the buildbot but I have just installed this and upgraded from it it installed the new linux image i think 9.3 over 9.2 but haven't run the cnc yet to know what version it is
www.linuxcnc.org/testing-stretch-rtpreempt/
Just did it's 2.7.11
Last edit: 07 Aug 2017 15:28 by grump.
08 Aug 2017 12:34 #97170
by grump
Looks like buildbot is back up and running again it just upgraded me to 2.8
Time to create page: 0.114 seconds
