Install current master 2.8
20 Aug 2017 09:56 #97765
by joel0407
But that wouldn't get us to 2.8
Replied by joel0407 on topic Install current master 2.8
I would have referred you to the manual.
www.linuxcnc.org/docs/2.7/html/getting-s..._configuration_files
20 Aug 2017 10:07 #97766
But this would:
linuxcnc.org/docs/devel/html/
Replied by rodw on topic Install current master 2.8
But this would:
20 Aug 2017 10:10 #97767
by joel0407
Dont think so Rod. Just have a look. "Getting Started with LinuxCNC" then "Getting LinuxCNC" All instructions for 2.7.
But this would:
20 Aug 2017 10:53 #97769
by joel0407
I'm wondering if Buildbot is down again? It has worked before for me. No it's not.
20 Aug 2017 11:43 #97773
Replied by andypugh on topic Install current master 2.8
If you can install 2.7 then upgrading to 2.8 is fairly easy.
20 Aug 2017 11:54 #97775
by joel0407
Buildbot has been the quickest for me. Just couldn't get the RTPREEMPT version today. Installing the RTAI kernel just so I can go the RTAI version of LinuxCNC.
Happy Days.
Happy Days.
20 Aug 2017 12:03 #97776
Well, Joel. sounds like its a good time to build Linuxcnc from source. I found out the hard way today that our git repository is now on github not on buildbot......
Honestly once you get past the dependencies its really very simple and so easy to try out some of the experimental branches. It only takes a few minutes to compile.
20 Aug 2017 12:09 #97778
by joel0407
The RTAI build is still there.
20 Aug 2017 12:13 #97779
by joel0407
as for getting past the dependanceis. I got down to one I couldn't find. Started again this time with the RTAI buils. What was it you said about not staying on the Bleeding edge. LOL
22 Sep 2017 12:30 - 22 Sep 2017 12:31 #99253
by pippin88
Replied by pippin88 on topic Install current master 2.8
www.linuxcnc.org/testing-stretch-rtpreempt/
I installed debian stretch using the image from the above link, on an Asrock J3455M motherboard.
Note: there is a bug in the version of the stretch live CD used in the above link, which prevents installation if not connected to the internet. You get a "Debootstrap error" "Failed to determine the codename for the release."
Installation works fine if connected to the internet.
Last edit: 22 Sep 2017 12:31 by pippin88.
Time to create page: 0.081 seconds
