Linuxcnc 2.7.8 Iso
- MarcoGaspar
06 Feb 2017 21:34 #87418
by MarcoGaspar
Linuxcnc 2.7.8 Iso was created by MarcoGaspar
Hello,
Where i can get a Linuxcnc 2.7.8 Iso?
- Thank you received: 1369
06 Feb 2017 21:52 #87423
Replied by Todd Zuercher on topic Linuxcnc 2.7.8 Iso
The ISO images are updated very infrequently. I'm not sure what the current version is on the ISO (it might only be 2.7.0 and definitely is not 2.7.8). If your machine has an internet connection it is very simple to update to the latest version after installing, just run the software updater program.
07 Feb 2017 00:12 - 07 Feb 2017 00:13 #87427
by BigJohnT
The LiveCD's are always only the base version ie. 2.7.0 then the Synaptic Manager will update you to the current version. The only time an ISO was updated when there was an error in the ISO itself... and I've only seen that once in many years of using EMC and LinuxCNC.
JT
Replied by BigJohnT on topic Linuxcnc 2.7.8 Iso
Hello,
JT
Last edit: 07 Feb 2017 00:13 by BigJohnT.
Time to create page: 0.062 seconds
