Installation is super confusing
- jwalter007
05 Mar 2017 15:12 #89040
by jwalter007
Installation is super confusing was created by jwalter007
I should preface this with that I am an extreme linux newbie
I recently installed Linux Ubuntu 16.04 LTS
I have been trying to follow the instructions for installing LinuxCNC.
I have the ISO wheezy loaded on an external USB stick.
As I understand it, I should reboot the machine and go into the bootloader section to boot from that USB, however the USB drive is not showing up as a bootable device.
This is the same usb that I previously used to install ubuntu in the first place.
Any advice would be great thanks
05 Mar 2017 19:15 #89052
Replied by PCW on topic Installation is super confusing
The LinuxCNC ISO is a complete Linux (Debian Wheezy) installation so you
do not need to install another Linux version first. To install the LinuxCNC ISO
you boot from the USB stick (not hard drive) and follow the instructions
If you cannot boot from the LinuxCNC USB drive, that's often because of a USB image creation issue
or sometimes a UEFI BIOS issue if you have a newer PC
05 Mar 2017 20:34 #89059
Replied by rodw on topic Installation is super confusing
I have had problems creating bootable USB's and after researching, this is not uncommon. Assuming you still have a Windows box, download the free Windows program win32diskimager and use it to create your bootable USB.
You need to rename the .ISO file to .IMG
This works every time for me on any hardware I've tried.
- jwalter007
05 Mar 2017 20:50 #89060
by jwalter007
Replied by jwalter007 on topic Installation is super confusing
Unfortunately, when I was installing Linux, I wiped the windows partition.
Can I install LinuxCNC as program into an existing Ubuntu system? Like installing a program in windows?
05 Mar 2017 22:39 #89065
Yes you can, but you will need to install a real time kernel if you want to run a real machine.
Its generally much easier to just boot/ install the LinuxCNC ISO which contains both
a real time Linux version and LinuxCNC
Here's a thread/howto about installing a real time kernel and LinuxCNC with Mint18 (ubuntu 16.04 would be very similar)
forum.linuxcnc.org/9-installing-linuxcnc...r-deb?start=40#88289
The following user(s) said Thank You: jwalter007
Time to create page: 0.114 seconds
