Synaptic pkg error when attempting upgrade from 2.70 to 2.7.8
07 Mar 2017 01:19 #89120
by dokwine
I'm running the Deb Wheezy 2.7 ISO - installed no problem. Running (as far as Ive taken it so far) no problem. But when I try to update to 2.7.8 Synaptic throws:
"Failed to fetch linuxcnc.org/dists/wheezy/Release Unable to find expected entry '2.7.8-rtai/source/Sources' in Release file (Wrong sources.list entry or malformed file)
Some index files failed to download. They have been ignored, or old ones used instead."
Indeed when I look there I do not see 2.7.8 - only 2.7. I'm sure I'm missing something basic; could someone give me a pointer in the right direction?
- cncnoob1979
- Thank you received: 75
07 Mar 2017 13:09 - 07 Mar 2017 13:12 #89134
by cncnoob1979
Replied by cncnoob1979 on topic Synaptic pkg error when attempting upgrade from 2.70 to 2.7.8
Have you tried to reset your internet connection? Or tired more than once?
If you are just trying to upgrade you could just download the .deb from here [looking for the latest release]
linuxcnc.org/dists/wheezy/2.7-rtai/binary-i386/ [32bit]
That should get you going short term. Look in synaptic package manager, under sources see what is listed for your sources. You might need to add the source if not there already [or listed incorrectly/possibly with white space?]
The instructions are here. buildbot.linuxcnc.org/
Last edit: 07 Mar 2017 13:12 by cncnoob1979.
- Thank you received: 5924
07 Mar 2017 18:36 #89147
Replied by tommylight on topic Synaptic pkg error when attempting upgrade from 2.70 to 2.7.8
You need to update package list before you try to upgrade. It is in synaptics, just click on it and wait till it finishes, then mark for upgrade and aply.
- cncnoob1979
07 Mar 2017 18:48 - 07 Mar 2017 18:51 #89149
by cncnoob1979
Ha!
Good catch, did not think about the possibility that he hadn't updated sources listing since the install.
Here is a way via terminal/console:
then you can typeTo update all available packages listed in synaptic.
manpages.ubuntu.com/manpages/zesty/en/man8/apt-get.8.html
sudo apt-get update
then you can type
sudo apt-get dist-upgrade
Last edit: 07 Mar 2017 18:51 by cncnoob1979.
07 Mar 2017 20:16 - 07 Mar 2017 20:18 #89160
by dokwine
Replied by dokwine on topic Synaptic pkg error when attempting upgrade from 2.70 to 2.7.8
Thanks for the suggestions, but no joy. Yes, my internet connection is good and I have tried multiple times. I have been trying to update the package list and I believe this is where the problem is. with synaptic during the attempted package update I get the error above. With the suggested command line update I get:
"W: Failed to fetch linuxcnc.org/dists/wheezy/Release Unable to find expected entry '2.7.8-rtai/source/Sources' in Release file (Wrong sources.list entry or malformed file)"
When I look in ../wheezy/Release I see lots of 2.7 packages but nothing labeled 2.7.8.
Is 2.7.8 within the 2.7 package? If so, what is the source of the list that apt and synaptic are using directing it to 2.7.8-rtai...
Sorry, I come at this from primarily a Unix background with little direct experience with Debian (yet
Last edit: 07 Mar 2017 20:18 by dokwine. Reason: garbled error message transcription
07 Mar 2017 20:25 #89162
Did you edit the sources list manualy?
On that distribution you should not edit anything at all, just update and install the new version.
Even if you want to get master, there is nothing to edit, there are enties already there in synaptic sources.
07 Mar 2017 20:39 #89164
by dokwine
No, I did not edit the the sources list. Not even sure where it lives exactly yet - just wanted to check since both synaptic and command line are complaining that the 2.7.8-rtai... is not found.
07 Mar 2017 20:58 #89167
at the very bottom you have the .deb package for the 2.7.8, download and open with gdebi ( right click on it, on the menu there should be gdebi package installer).
Let us know how it goes.
07 Mar 2017 21:16 #89169
by dokwine
no gdebi. Think I'll try to track that down. I think I used apt -R when I was installing vnc but gdebi sounds like it'll save some time in the future.
07 Mar 2017 22:25 #89176
Sorry, my bad, no gdebi in wheezy, but there should be a package installer there for sure, choose that, please.
Time to create page: 0.130 seconds
