Latency Histogram
18 Apr 2017 12:16 #91571
by BigJohnT
Latency Histogram was created by BigJohnT
The following user(s) said Thank You: cncnoob1979
- cncnoob1979
- Thank you received: 75
18 Apr 2017 12:38 #91576
by cncnoob1979
Replied by cncnoob1979 on topic Latency Histogram
Ill give it a try and report back here. Thanks JT.
- Thank you received: 5907
18 Apr 2017 21:22 #91601
Replied by tommylight on topic Latency Histogram
Just tested it on LMDE with LCNC2.8, it works properly.
Gave it a try before installing LCNC, it said it depends on Linuxcnc or Linuxcnc userspace, as it should.
All is good, thank you.
Side note, JT did you get my e-mail?
18 Apr 2017 22:32 #91612
by BigJohnT
Replied by BigJohnT on topic Latency Histogram
Good to know that it works, the dependencies was an adventure lol.
Yes I got the email.
www.mesaus.com/info/links.html
JT
JT
29 May 2020 12:09 #169310
by Clive S
John Is this still working
cnc@cnc-machine:~/Desktop$ sudo apt-get install lhgui
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package lhgui
I am using mint by Beagle
Replied by Clive S on topic Latency Histogram
I've created a GUI launcher for the Latency Histogram and packaged it as a deb. If someone could test adding my repository and installing the GUI that would be nice.
sudo add-apt-repository "deb http://mesaus.com/packages/lhgui_1.0-6 ./" sudo apt-get install lhgui
JT
29 May 2020 13:31 #169315
Add the repository, do an update, then install.
Time to create page: 0.105 seconds
