LinuxCNC on Debian Stretch
06 Aug 2017 13:32 #97068
by grump
Replied by grump on topic LinuxCNC on Debian Stretch
I had noticed the buildbot had been down for some time now, hope it comes back on soon.
I need my monthly fix of reinstall.
- skunkworks
- Thank you received: 148
06 Aug 2017 22:11 #97082
by skunkworks
Replied by skunkworks on topic LinuxCNC on Debian Stretch
this is the actual link..
www.linuxcnc.org/testing-stretch-rtpreempt/
07 Aug 2017 08:14 #97098
by grump
Whoo Hoo. Back in business. Many thanks.
I will be getting my fix today.
21 Aug 2017 13:57 #97814
by Zuikkis
Replied by Zuikkis on topic LinuxCNC on Debian Stretch
I'm currently running Debian Wheezy. Is it possible to upgrade directly by editing sources.list, replacing wheezy with stretch? This is how I usually update my other Debian machines, but I understand LinuxCNC needs some magic like the RT kernel.
- Thank you received: 1369
21 Aug 2017 14:22 #97815
Replied by Todd Zuercher on topic LinuxCNC on Debian Stretch
I am going to go out on a limb and just say NO.
If you are using the standard Linuxcnc iso that uses the RTAI kernel, there is no pre packaged RTAI kernel (or Linuxcnc version) currently available for Jessie or Stretch.
(It might, maybe be possible if you are using a Preempt-RT version, but no guarantees.)
21 Aug 2017 19:02 #97834
by grump
Don't replace but add the repository also add the Jessie backports although that may not now be necessary.
I added buildbot also to get 2.8.
Open synaptic type linux-image and select the one you require, it is in there or was when I did it 3 weeks ago.
25 Sep 2017 20:53 #99428
by PKM
Replied by PKM on topic LinuxCNC on Debian Stretch
Hello
I installed LinuxCNC from amd64 image www.linuxcnc.org/testing-stretch-rtpreempt/
How do I get glade editor working here?
glade-gtk2 is not available
I installed glade but it doesn't have linuxcnc widgets
Thanks a lot
Thanks a lot
26 Sep 2017 10:09 #99450
by scubawarm
See this thread
forum.linuxcnc.org/gmoccapy/33309-glade-3-18-3
You can get the source code with a Google search as well and have 3.8.6.
I hate Debian because of standard Linux tools made unavailable. Have spent days trying to get Mint or Ubuntu with a fully working Glade-3 (what you get if you compile). Trying to do tutorial #2 crashes it.
Please let me know if you are successful.
Replied by scubawarm on topic LinuxCNC on Debian Stretch
Hello
Thanks a lot
See this thread
The following user(s) said Thank You: PKM
26 Sep 2017 18:35 #99479
by PKM
Thank you!
I decided to use wheezy for editing until this (hopefully) gets resolved.
24 Oct 2017 10:22 #100740
by jtc
Replied by jtc on topic LinuxCNC on Debian Stretch
Hi!
I'm trying to install a Run In Place version on Debian Strech, but I cant solve this dependencies:
I'm using a preemrt kernel , so i made configure: ./configure userspace on debian folder.
any work around?
thanks
dpkg-checkbuilddeps: error: Unmet build dependencies: linux-image-userspace rtai-modules-userspace | rtai-modules-userspace linux-headers-userspace
any work around?
thanks
Time to create page: 0.184 seconds
