rt-preempt kernel configuration
11 Aug 2017 12:38 #97338
by gambaf
rt-preempt kernel configuration was created by gambaf
when configuring the rt-preempt kernel, other than configuring the kernel as "fully preemptible kernel" (processor type and features -> preemption model), what other options should you enable/disable?
14 Aug 2017 16:15 - 14 Aug 2017 16:15 #97469
Replied by andypugh on topic rt-preempt kernel configuration
Maybe start with the the config from debian and work from there?
linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel
(I am assuming that the "sudo apt-get install linux-image-rt-amd64" command gets the kernel build config as well as the kernel)
Last edit: 14 Aug 2017 16:15 by andypugh.
31 Aug 2017 03:19 #98254
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic rt-preempt kernel configuration
What about boot parameters, like isolcpu?
Albert Einstein
31 Aug 2017 03:39 #98258
They have no affect.
The best things I could do for latency was to disable some of the bios settings.
Replied by rodw on topic rt-preempt kernel configuration
Time to create page: 0.131 seconds
