Latency and Wifi problem
15 Aug 2017 13:38 #97512
by joel0407
Latency and Wifi problem was created by joel0407
Hey guys,
Before I start.
Yes I read this:https://forum.linuxcnc.org/forum/9-installing-linuxcnc/26068-latency-fix-wifi-driver-auto-loadunload
That's great but I copy a Gcode file via Wifi, start LinuxCNC, run then I need the next Gcode file for the same piece. Maybe I copy the drilling, clearing then outside contour. Problem is I can't exit LinuxCNC each time as I'll loose G54. So that counts this solution out.
I tried this: wiki.linuxcnc.org/cgi-bin/wiki.pl?RealTime
That gets my latency down from 12,000 to 4,000.
Now my problem. When I run the latency test, it will sit at 4,000 or 12,000 depending if I'm using the above settings or not. Then all of a sudden, it'll jump to 75,000. The time it takes to jump might be 15 seconds or 2 seconds after I hit reset values. I managed to stop this by removing the WiFi card. I also have a USB WiFi adapter that I couldn't get to work.
So I've narrowed it down to the pci WiFi card but haven't found a solution.
I'm wondering if anyone has one working and what they did to get it to work without the latency spikes.
Happy Days
Before I start.
Happy Days
15 Aug 2017 13:55 #97514
by joel0407
Replied by joel0407 on topic Latency and Wifi problem
According the this:
emc-users.narkive.com/CsirrOt0/wifi-hardware-for-linuxcnc
There might not be a fix. Just use an external wifi router. I can but it's messy.
15 Aug 2017 13:58 #97515
by bevins
Replied by bevins on topic Latency and Wifi problem
Why would you loose G54 when shutting down LCNC? I never do. I can run a job all day, shut everything down, next day power up everything and G54 offset is still there and active.
Cant comment on the wifi as I hate wifi and wire everything direct.
15 Aug 2017 20:23 #97531
by joel0407
Ok. I didn't know that. But I do know I'll loose home and since I manually home until at the moment then I'd be just guessing where it was.
Happy Days.
Happy Days.
15 Aug 2017 22:25 #97534
Replied by rodw on topic Latency and Wifi problem
What PC are you using?
With the USFF machines you cannot use the onboard wifi but an external USB wifi dongle works perfect.
15 Aug 2017 23:03 #97535
by joel0407
I have a Dell 780 with 2600 intel processor working fine. I couldn't get a USB WiFi adaptor to work after numerous attempts then I put in a WiFi card and it worked straight away. I thought I would add a video card to take the load of the processor and pickup some latency speed. Downside was the motherboard in the 780 only has one PCI slot which got taken up by the WiFi card.
My wife is currently using a Dell 980 with the same 2600 intel processor. Her's needs an upgrade and it has a PCI and mini PCI slot. I thought great, I'll upgrade her's and take the old one for the router.
The mini PCI slot is specifically for a WiFi card. So put that in and video card in the other slot and got latency down to 12,000 but then it would jump to 75000. I did the searching about changing a few things and got it down to 4000 but I couldn't stop it jumping to the 75000. Removing the WiFi card stopped the it instantly so I have no doubt it's the problem.
If I'm going to purchase another WiFi USB Dongle just to try, I'll buy a cheap single port router instead as it removes the problem from the machine. I'd prefer to keep it neat thought and have the WiFi contained in the PC. I just need to work out why it spikes the latency.
Happy Days
Happy Days
15 Aug 2017 23:12 #97536
Just to help Ned Kelly out, I'm using a Asus Nano USB10 wifi dongle. I paid $20 ages ago
www.asus.com/au/Networking/USBN10_NANO/
There were some tricks getting it running on Debian and googling gave me the solution but on Linux Mint, it was supported out of the box.
15 Aug 2017 23:30 #97537
by joel0407
Searching.
Searching.
15 Aug 2017 23:50 #97538
This one, 1st method worked
wikidevi.com/wiki/ASUS_USB-N10_Nano
16 Aug 2017 13:32 - 16 Aug 2017 14:12 #97566
by joel0407
Thanks Rod, The WiFi USB Dongle worked straight up with Mint. Better video resolution as well.
Just working on getting LinuxCNC installed now. Following along here: forum.linuxcnc.org/forum/9-installing-li...linux-mint-with-rtai
Last edit: 16 Aug 2017 14:12 by joel0407.
Time to create page: 0.159 seconds
