LinuxCNC terminated with an error
16 Aug 2017 23:47 #97600
by tml
LinuxCNC terminated with an error was created by tml
Hello,
Today I tried to start my LinuxCNC program and it won't start up. It gave me this long file, which I'm not really sure what to look for. Can someone help me out? Below is what the report log generated:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/tim/linuxcnc/configs/Lathe'
Machine configuration file is 'Lathe.ini'
INIFILE=/home/tim/linuxcnc/configs/Lathe/Lathe.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Lathe.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=4130
Debug file information:
./Lathe.hal:27: Pin 'hm2_5i25.0.7i76.0.0.input-16' does not exist
4130
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bc8a4000 (usable)
[ 0.000000] BIOS-e820: 00000000bc8a4000 - 00000000bc8ab000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bc8ab000 - 00000000bd5a6000 (usable)
[ 0.000000] BIOS-e820: 00000000bd5a6000 - 00000000bdadb000 (reserved)
[ 0.000000] BIOS-e820: 00000000bdadb000 - 00000000cdac6000 (usable)
[ 0.000000] BIOS-e820: 00000000cdac6000 - 00000000cdb2d000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdb2d000 - 00000000cdb82000 (usable)
[ 0.000000] BIOS-e820: 00000000cdb82000 - 00000000cdcb5000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cdcb5000 - 00000000cdfff000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdfff000 - 00000000ce000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000041ee00000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./H97 Pro4, BIOS P1.90 07/27/2015
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xce000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7C00000000 write-back
[ 0.000000] 1 base 0400000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00D0000000 mask 7FF0000000 uncachable
[ 0.000000] 4 base 00CF000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 041F000000 mask 7FFF000000 uncachable
[ 0.000000] 6 base 041EE00000 mask 7FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd170] fd170
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36522000 - 37289000
[ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT cdc84080 00084 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP cdc946d0 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT cdc841a0 1052F (v02 ALASKA A M I 00000190 INTL 20120711)
[ 0.000000] ACPI: FACS cdcb4f80 00040
[ 0.000000] ACPI: APIC cdc947e0 00062 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT cdc94848 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT cdc94890 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT cdc94dd0 00B74 (v01 CpuRef CpuSsdt 00003000 INTL 20051117)
[ 0.000000] ACPI: MCFG cdc95948 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET cdc95988 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT cdc959c0 0036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT cdc95d30 05B5E (v01 SaSsdt SaSsdt 00003000 INTL 20120711)
[ 0.000000] ACPI: ASF! cdc9b890 000A5 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.000000] ACPI: AAFT cdc9b938 0022C (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: UEFI cdc9bb68 00042 (v01 ALASKA A M I 01072009 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2408MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000ce000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000bc8a4
[ 0.000000] 0: 0x000bc8ab -> 0x000bd5a6
[ 0.000000] 0: 0x000bdadb -> 0x000cdac6
[ 0.000000] 0: 0x000cdb2d -> 0x000cdb82
[ 0.000000] 0: 0x000cdfff -> 0x000ce000
[ 0.000000] On node 0 totalpages: 841069
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b62200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4817 pages used for memmap
[ 0.000000] HighMem zone: 609041 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77c9000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 834476
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=68f83532-ebed-4681-a7a8-78652217663e ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] allocated 6750080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000ce000)
[ 0.000000] Memory: 3310720k/3375104k available (3495k kernel code, 53556k reserved, 1237k data, 416k init, 2455432k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3192.841 MHz processor.
[ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 6385.68 BogoMIPS (lpj=12771364)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000026] Security Framework initialized
[ 0.000029] AppArmor: AppArmor disabled by boot time parameter
[ 0.000038] Mount-cache hash table entries: 512
[ 0.000147] Initializing cgroup subsys cpuacct
[ 0.000149] Initializing cgroup subsys memory
[ 0.000152] Initializing cgroup subsys devices
[ 0.000154] Initializing cgroup subsys freezer
[ 0.000155] Initializing cgroup subsys net_cls
[ 0.000156] Initializing cgroup subsys blkio
[ 0.000159] Initializing cgroup subsys perf_event
[ 0.000176] CPU: Physical Processor ID: 0
[ 0.000177] CPU: Processor Core ID: 0
[ 0.001699] mce: CPU supports 7 MCE banks
[ 0.001707] CPU0: Thermal monitoring enabled (TM1)
[ 0.001769] ACPI: Core revision 20120320
[ 0.010875] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.011197] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.050793] CPU0: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz stepping 03
[ 0.158148] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.158153] ... version: 3
[ 0.158154] ... bit width: 48
[ 0.158155] ... generic registers: 8
[ 0.158156] ... value mask: 0000ffffffffffff
[ 0.158157] ... max period: 000000007fffffff
[ 0.158158] ... fixed-purpose events: 3
[ 0.158159] ... event mask: 00000007000000ff
[ 0.170152] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.182114] CPU 1 irqstacks, hard=f40d2000 soft=f40d4000
[ 0.182116] Booting Node 0, Processors #1 Ok.
[ 0.192306] Initializing CPU#1
[ 0.196711] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196731] Brought up 2 CPUs
[ 0.196733] Total of 2 processors activated (12771.36 BogoMIPS).
[ 0.197902] devtmpfs: initialized
[ 0.198051] PM: Registering ACPI NVS region [mem 0xbc8a4000-0xbc8aafff] (28672 bytes)
[ 0.198058] PM: Registering ACPI NVS region [mem 0xcdb82000-0xcdcb4fff] (1257472 bytes)
[ 0.198141] dummy:
[ 0.198174] NET: Registered protocol family 16
[ 0.198250] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.198252] ACPI: bus type pci registered
[ 0.198285] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.198287] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.198288] PCI: Using MMCONFIG for extended config space
[ 0.198289] PCI: Using configuration type 1 for base access
[ 0.198645] bio: create slab <bio-0> at 0
[ 0.198699] ACPI: Added _OSI(Module Device)
[ 0.198701] ACPI: Added _OSI(Processor Device)
[ 0.198703] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.198704] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.201373] ACPI: EC: Look up EC in DSDT
[ 0.204851] ACPI: Executed 15 blocks of module-level executable AML code
[ 0.209522] ACPI: SSDT cdb0bc18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.210218] ACPI: Dynamic OEM Table Load:
[ 0.210220] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.210447] ACPI: SSDT cdb0b618 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.211230] ACPI: Dynamic OEM Table Load:
[ 0.211232] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.211330] ACPI: SSDT cdb0ad98 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.212026] ACPI: Dynamic OEM Table Load:
[ 0.212028] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.212642] ACPI: Interpreter enabled
[ 0.212650] ACPI: (supports S0 S3 S4 S5)
[ 0.212674] ACPI: Using IOAPIC for interrupt routing
[ 0.213026] ACPI: Power Resource [PG00] (on)
[ 0.213365] ACPI: Power Resource [PG01] (on)
[ 0.213698] ACPI: Power Resource [PG02] (on)
[ 0.219779] ACPI: No dock devices found.
[ 0.219783] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.220057] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.220414] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.220416] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.220417] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.220419] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.220420] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.220421] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.220423] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.220424] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.220425] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.220427] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.220447] PCI host bridge to bus 0000:00
[ 0.220448] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.220450] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.220451] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.220453] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.220454] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.220455] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.220456] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.220458] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.220459] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.220460] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.220467] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.220496] pci 0000:00:02.0: [8086:0402] type 00 class 0x030000
[ 0.220505] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.220510] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.220514] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.220555] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
[ 0.220572] pci 0000:00:14.0: reg 10: [mem 0xf7e20000-0xf7e2ffff 64bit]
[ 0.220616] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.220634] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
[ 0.220654] pci 0000:00:16.0: reg 10: [mem 0xf7e3b000-0xf7e3b00f 64bit]
[ 0.220701] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.220726] pci 0000:00:19.0: [8086:15a1] type 00 class 0x020000
[ 0.220741] pci 0000:00:19.0: reg 10: [mem 0xf7e00000-0xf7e1ffff]
[ 0.220748] pci 0000:00:19.0: reg 14: [mem 0xf7e38000-0xf7e38fff]
[ 0.220755] pci 0000:00:19.0: reg 18: [io 0xf080-0xf09f]
[ 0.220798] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.220819] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
[ 0.220838] pci 0000:00:1a.0: reg 10: [mem 0xf7e37000-0xf7e373ff]
[ 0.220904] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.220926] pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300
[ 0.220939] pci 0000:00:1b.0: reg 10: [mem 0xf7e30000-0xf7e33fff 64bit]
[ 0.220986] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.221003] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
[ 0.221049] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.221068] pci 0000:00:1c.2: [8086:8c94] type 01 class 0x060400
[ 0.221115] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.221136] pci 0000:00:1c.6: [8086:244e] type 01 class 0x060401
[ 0.221182] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.221206] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
[ 0.221224] pci 0000:00:1d.0: reg 10: [mem 0xf7e36000-0xf7e363ff]
[ 0.221291] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.221313] pci 0000:00:1f.0: [8086:8cc6] type 00 class 0x060100
[ 0.221413] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
[ 0.221427] pci 0000:00:1f.2: reg 10: [io 0xf0d0-0xf0d7]
[ 0.221433] pci 0000:00:1f.2: reg 14: [io 0xf0c0-0xf0c3]
[ 0.221440] pci 0000:00:1f.2: reg 18: [io 0xf0b0-0xf0b7]
[ 0.221446] pci 0000:00:1f.2: reg 1c: [io 0xf0a0-0xf0a3]
[ 0.221452] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.221459] pci 0000:00:1f.2: reg 24: [mem 0xf7e35000-0xf7e357ff]
[ 0.221483] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.221496] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
[ 0.221508] pci 0000:00:1f.3: reg 10: [mem 0xf7e34000-0xf7e340ff 64bit]
[ 0.221526] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.221579] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.221637] pci 0000:02:00.0: [10ec:8178] type 00 class 0x028000
[ 0.221655] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.221686] pci 0000:02:00.0: reg 18: [mem 0xf7d00000-0xf7d03fff 64bit]
[ 0.221756] pci 0000:02:00.0: supports D1 D2
[ 0.221757] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.228657] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.228660] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.228663] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.228711] pci 0000:03:00.0: [1b21:1080] type 01 class 0x060401
[ 0.228796] pci 0000:00:1c.6: PCI bridge to [bus 03-04] (subtractive decode)
[ 0.228800] pci 0000:00:1c.6: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.228805] pci 0000:00:1c.6: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.228806] pci 0000:00:1c.6: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.228808] pci 0000:00:1c.6: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.228809] pci 0000:00:1c.6: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.228810] pci 0000:00:1c.6: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.228812] pci 0000:00:1c.6: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.228813] pci 0000:00:1c.6: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.228815] pci 0000:00:1c.6: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.228816] pci 0000:00:1c.6: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.228818] pci 0000:00:1c.6: bridge window [mem 0xdf200000-0xfeafffff] (subtractive decode)
[ 0.228859] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.228879] pci 0000:04:00.0: reg 10: [mem 0xf7c00000-0xf7c0ffff]
[ 0.229030] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.229041] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.229049] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229051] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[ 0.229052] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229054] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229055] pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.229056] pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.229058] pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.229059] pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.229061] pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.229062] pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.229063] pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.229065] pci 0000:03:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.229066] pci 0000:03:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.229068] pci 0000:03:00.0: bridge window [mem 0xdf200000-0xfeafffff] (subtractive decode)
[ 0.229088] pci_bus 0000:00: on NUMA node 0
[ 0.229090] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.229244] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.229280] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.229317] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07._PRT]
[ 0.229354] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07.BR40._PRT]
[ 0.229502] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.239532] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.239572] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.239612] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.239649] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.239687] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.239725] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.239763] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.239801] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.239846] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.239852] vgaarb: loaded
[ 0.239853] vgaarb: bridge control possible 0000:00:02.0
[ 0.239869] PCI: Using ACPI for IRQ routing
[ 0.241159] PCI: pci_cache_line_size set to 64 bytes
[ 0.241215] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.241217] reserve RAM buffer: 00000000bc8a4000 - 00000000bfffffff
[ 0.241218] reserve RAM buffer: 00000000bd5a6000 - 00000000bfffffff
[ 0.241219] reserve RAM buffer: 00000000cdac6000 - 00000000cfffffff
[ 0.241221] reserve RAM buffer: 00000000cdb82000 - 00000000cfffffff
[ 0.241222] reserve RAM buffer: 00000000ce000000 - 00000000cfffffff
[ 0.241300] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.241306] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.243313] Switching to clocksource hpet
[ 0.243342] pnp: PnP ACPI init
[ 0.243348] ACPI: bus type pnp registered
[ 0.243544] pnp 00:00: [bus 00-3e]
[ 0.243546] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.243547] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.243548] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.243550] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.243551] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.243552] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.243553] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.243555] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.243556] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.243557] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.243558] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.243560] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.243561] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.243562] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.243563] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.243565] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.243566] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.243567] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.243602] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.243658] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.243684] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.243686] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.243694] pnp 00:02: [io 0x0000-0x001f]
[ 0.243695] pnp 00:02: [io 0x0081-0x0091]
[ 0.243696] pnp 00:02: [io 0x0093-0x009f]
[ 0.243697] pnp 00:02: [io 0x00c0-0x00df]
[ 0.243698] pnp 00:02: [dma 4]
[ 0.243715] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.243720] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.243737] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.243790] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.243808] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.243825] pnp 00:05: [io 0x00f0]
[ 0.243830] pnp 00:05: [irq 13]
[ 0.243848] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.243865] pnp 00:06: [io 0x0800-0x087f]
[ 0.243891] system 00:06: [io 0x0800-0x087f] has been reserved
[ 0.243892] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.243898] pnp 00:07: [io 0x0070-0x0077]
[ 0.243901] pnp 00:07: [irq 8]
[ 0.243920] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.243933] pnp 00:08: [io 0x1854-0x1857]
[ 0.243958] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.243960] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.244003] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.244004] pnp 00:09: [io 0x0290-0x029f]
[ 0.244006] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.244032] system 00:09: [io 0x0290-0x029f] has been reserved
[ 0.244034] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.244211] pnp 00:0a: [io 0x0010-0x001f]
[ 0.244213] pnp 00:0a: [io 0x0022-0x003f]
[ 0.244214] pnp 00:0a: [io 0x0044-0x005f]
[ 0.244215] pnp 00:0a: [io 0x0062-0x0063]
[ 0.244216] pnp 00:0a: [io 0x0065-0x006f]
[ 0.244217] pnp 00:0a: [io 0x0072-0x007f]
[ 0.244218] pnp 00:0a: [io 0x0080]
[ 0.244219] pnp 00:0a: [io 0x0084-0x0086]
[ 0.244221] pnp 00:0a: [io 0x0088]
[ 0.244222] pnp 00:0a: [io 0x008c-0x008e]
[ 0.244223] pnp 00:0a: [io 0x0090-0x009f]
[ 0.244224] pnp 00:0a: [io 0x00a2-0x00bf]
[ 0.244225] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.244227] pnp 00:0a: [io 0x04d0-0x04d1]
[ 0.244256] system 00:0a: [io 0x04d0-0x04d1] has been reserved
[ 0.244258] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.244394] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.244398] pnp 00:0b: [irq 4]
[ 0.244399] pnp 00:0b: [dma 0 disabled]
[ 0.244437] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.244816] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.244817] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.244819] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.244820] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.244821] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.244822] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.244823] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.244825] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.244826] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.244827] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.244828] pnp 00:0c: [mem 0xf7fe0000-0xf7feffff]
[ 0.244870] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.244872] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.244874] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.244875] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.244877] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.244878] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.244880] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.244881] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.244883] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.244885] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.244886] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.244888] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.245043] pnp: PnP ACPI: found 13 devices
[ 0.245044] ACPI: ACPI bus type pnp unregistered
[ 0.245046] PnPBIOS: Disabled by ACPI PNP
[ 0.280659] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.280668] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.280670] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.280674] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.280680] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.280687] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.280698] pci 0000:00:1c.6: PCI bridge to [bus 03-04]
[ 0.280702] pci 0000:00:1c.6: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.280735] pci 0000:03:00.0: setting latency timer to 64
[ 0.280738] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.280739] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.280741] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.280742] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.280743] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.280745] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.280746] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.280747] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.280748] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.280750] pci_bus 0000:00: resource 13 [mem 0xdf200000-0xfeafffff]
[ 0.280751] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.280753] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.280754] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.280755] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.280756] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.280758] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.280759] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.280760] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.280761] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.280763] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.280764] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.280765] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.280767] pci_bus 0000:03: resource 13 [mem 0xdf200000-0xfeafffff]
[ 0.280768] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.280769] pci_bus 0000:04: resource 5 [mem 0xf7c00000-0xf7cfffff]
[ 0.280771] pci_bus 0000:04: resource 8 [io 0x0000-0x0cf7]
[ 0.280772] pci_bus 0000:04: resource 9 [io 0x0d00-0xffff]
[ 0.280773] pci_bus 0000:04: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.280774] pci_bus 0000:04: resource 11 [mem 0x000d0000-0x000d3fff]
[ 0.280776] pci_bus 0000:04: resource 12 [mem 0x000d4000-0x000d7fff]
[ 0.280777] pci_bus 0000:04: resource 13 [mem 0x000d8000-0x000dbfff]
[ 0.280778] pci_bus 0000:04: resource 14 [mem 0x000dc000-0x000dffff]
[ 0.280779] pci_bus 0000:04: resource 15 [mem 0x000e0000-0x000e3fff]
[ 0.280781] pci_bus 0000:04: resource 16 [mem 0x000e4000-0x000e7fff]
[ 0.280782] pci_bus 0000:04: resource 17 [mem 0xdf200000-0xfeafffff]
[ 0.280823] NET: Registered protocol family 2
[ 0.280856] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.280944] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.281056] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.281114] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.281116] TCP: reno registered
[ 0.281117] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.281120] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.281162] NET: Registered protocol family 1
[ 0.281169] pci 0000:00:02.0: Boot video device
[ 0.281473] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.281479] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.319173] PCI: CLS 64 bytes, default 64
[ 0.319197] Unpacking initramfs...
[ 0.506338] Freeing initrd memory: 13724k freed
[ 0.507660] audit: initializing netlink socket (disabled)
[ 0.507668] type=2000 audit(1502926388.400:1): initialized
[ 0.516228] highmem bounce pool size: 64 pages
[ 0.516231] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.516345] VFS: Disk quotas dquot_6.5.2
[ 0.516360] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.516403] msgmni has been set to 1697
[ 0.516498] alg: No test for stdrng (krng)
[ 0.516514] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.516516] io scheduler noop registered
[ 0.516517] io scheduler deadline registered
[ 0.516528] io scheduler cfq registered (default)
[ 0.516640] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.516649] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.516651] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.516868] acpiphp: Slot [1] registered
[ 0.517020] GHES: HEST is not enabled!
[ 0.517027] isapnp: Scanning for PnP cards...
[ 0.870604] isapnp: No Plug & Play device found
[ 0.870635] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.890944] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.911468] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.911646] Linux agpgart interface v0.103
[ 0.911739] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.914536] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.914552] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.914603] mousedev: PS/2 mouse device common for all mice
[ 0.914635] rtc_cmos 00:07: RTC can wake from S4
[ 0.914731] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.914754] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.914826] TCP: cubic registered
[ 0.914856] NET: Registered protocol family 10
[ 0.914978] Mobile IPv6
[ 0.914980] NET: Registered protocol family 17
[ 0.914982] Registering the dns_resolver key type
[ 0.915017] Using IPI No-Shortcut mode
[ 0.915081] PM: Hibernation image not present or could not be loaded.
[ 0.915086] registered taskstats version 1
[ 0.915461] rtc_cmos 00:07: setting system clock to 2017-08-16 23:33:09 UTC (1502926389)
[ 0.915529] Freeing unused kernel memory: 416k freed
[ 0.915604] Write protecting the kernel text: 3496k
[ 0.915616] Write protecting the kernel read-only data: 984k
[ 0.922058] udevd[49]: starting version 175
[ 0.939695] usbcore: registered new interface driver usbfs
[ 0.939708] usbcore: registered new interface driver hub
[ 0.943691] usbcore: registered new device driver usb
[ 0.943912] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.943949] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.943952] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.943967] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.943984] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.946563] SCSI subsystem initialized
[ 0.954699] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19
[ 0.954762] libata version 3.00 loaded.
[ 0.959882] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.959898] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7e37000
[ 0.969692] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.969723] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.969725] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.969726] usb usb1: Product: EHCI Host Controller
[ 0.969727] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.969729] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.969797] hub 1-0:1.0: USB hub found
[ 0.969800] hub 1-0:1.0: 2 ports detected
[ 0.969879] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.969882] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.969887] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.969904] ehci_hcd 0000:00:1d.0: debug port 2
[ 0.973909] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 0.973925] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7e36000
[ 0.984526] microcode: CPU0 updated to revision 0x1c, date = 2014-07-03
[ 0.984536] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19
[ 0.985664] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.985692] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.985694] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.985696] usb usb2: Product: EHCI Host Controller
[ 0.985697] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.985698] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.985768] hub 2-0:1.0: USB hub found
[ 0.985771] hub 2-0:1.0: 2 ports detected
[ 0.986674] microcode: CPU1 updated to revision 0x1c, date = 2014-07-03
[ 0.986755] ahci 0000:00:1f.2: version 3.0
[ 0.986817] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
[ 0.986819] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.986822] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.987081] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 0.993981] scsi0 : ahci
[ 0.994044] scsi1 : ahci
[ 0.994088] scsi2 : ahci
[ 0.994133] scsi3 : ahci
[ 0.994170] scsi4 : ahci
[ 0.994206] scsi5 : ahci
[ 0.994695] ata1: SATA max UDMA/133 abar m2048@0xf7e35000 port 0xf7e35100 irq 19
[ 0.994697] ata2: SATA max UDMA/133 abar m2048@0xf7e35000 port 0xf7e35180 irq 19
[ 0.994698] ata3: DUMMY
[ 0.994699] ata4: DUMMY
[ 0.994700] ata5: DUMMY
[ 0.994701] ata6: DUMMY
[ 0.994730] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.994733] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.994759] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 0.994761] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.994768] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.994838] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.994861] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.994862] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994864] usb usb3: Product: xHCI Host Controller
[ 0.994865] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.994866] usb usb3: SerialNumber: 0000:00:14.0
[ 0.994913] xHCI xhci_add_endpoint called for root hub
[ 0.994915] xHCI xhci_check_bandwidth called for root hub
[ 0.994932] hub 3-0:1.0: USB hub found
[ 0.994946] hub 3-0:1.0: 14 ports detected
[ 0.995014] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.995017] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.995033] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.995034] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.995036] usb usb4: Product: xHCI Host Controller
[ 0.995037] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.995038] usb usb4: SerialNumber: 0000:00:14.0
[ 0.995083] xHCI xhci_add_endpoint called for root hub
[ 0.995084] xHCI xhci_check_bandwidth called for root hub
[ 0.995098] hub 4-0:1.0: USB hub found
[ 0.995108] hub 4-0:1.0: 6 ports detected
[ 1.280929] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.312863] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.312878] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.314516] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.314519] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.314521] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.314744] ata1.00: supports DRM functions and may not be fully accessible
[ 1.314783] ata1.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT02B6Q, max UDMA/133
[ 1.314784] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.315127] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.315129] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.315131] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.315353] ata1.00: supports DRM functions and may not be fully accessible
[ 1.315391] ata1.00: configured for UDMA/133
[ 1.315466] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 EMT0 PQ: 0 ANSI: 5
[ 1.316735] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.316737] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.316738] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.317037] ata2.00: ATAPI: ASUS DRW-24B1ST j, 1.01, max UDMA/133
[ 1.318465] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.318466] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.318468] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.318764] ata2.00: configured for UDMA/133
[ 1.320031] scsi 1:0:0:0: CD-ROM ASUS DRW-24B1ST j 1.01 PQ: 0 ANSI: 5
[ 1.323542] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.323573] sd 0:0:0:0: [sda] Write Protect is off
[ 1.323575] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.323585] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.323960] sda: sda1 sda2 < sda5 >
[ 1.324120] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.324993] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.325071] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.326441] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.326444] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.326563] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.413022] usb 1-1: New USB device found, idVendor=8087, idProduct=8009
[ 1.413024] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.413170] hub 1-1:1.0: USB hub found
[ 1.413268] hub 1-1:1.0: 6 ports detected
[ 1.504409] Refined TSC clocksource calibration: 3192.606 MHz.
[ 1.504412] Switching to clocksource tsc
[ 1.524368] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.656450] usb 2-1: New USB device found, idVendor=8087, idProduct=8001
[ 1.656452] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.656594] hub 2-1:1.0: USB hub found
[ 1.656699] hub 2-1:1.0: 8 ports detected
[ 1.927576] usb 2-1.7: new low-speed USB device number 3 using ehci_hcd
[ 2.024724] usb 2-1.7: New USB device found, idVendor=046d, idProduct=c31c
[ 2.024726] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.024727] usb 2-1.7: Product: USB Keyboard
[ 2.024729] usb 2-1.7: Manufacturer: Logitech
[ 2.031942] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.0/input/input0
[ 2.031978] generic-usb 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1d.0-1.7/input0
[ 2.038225] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.1/input/input1
[ 2.038252] generic-usb 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1d.0-1.7/input1
[ 2.038263] usbcore: registered new interface driver usbhid
[ 2.038264] usbhid: USB HID core driver
[ 2.099179] usb 2-1.8: new low-speed USB device number 4 using ehci_hcd
[ 2.195330] usb 2-1.8: New USB device found, idVendor=046d, idProduct=c077
[ 2.195332] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.195333] usb 2-1.8: Product: USB Optical Mouse
[ 2.195334] usb 2-1.8: Manufacturer: Logitech
[ 2.197278] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/input/input2
[ 2.197318] generic-usb 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.8/input0
[ 6.377704] PM: Starting manual resume from disk
[ 6.377706] PM: Hibernation image partition 8:5 present
[ 6.377707] PM: Looking for hibernation image.
[ 6.377847] PM: Image not found (code -22)
[ 6.377849] PM: Hibernation image not present or could not be loaded.
[ 6.390575] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.494054] udevd[402]: starting version 175
[ 6.555304] cfg80211: Calling CRDA to update world regulatory domain
[ 6.580181] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 6.580186] ACPI: Power Button [PWRB]
[ 6.580214] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 6.580217] ACPI: Sleep Button [SLPB]
[ 6.580241] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 6.580243] ACPI: Power Button [PWRF]
[ 6.597985] rtl8192ce: Using firmware rtlwifi/rtl8192cfw.bin
[ 6.620544] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 6.620763] rtlwifi: wireless switch is on
[ 6.624845] cfg80211: World regulatory domain updated:
[ 6.624848] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.624849] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 6.624851] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 6.624852] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 6.624853] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624854] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624856] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 6.624857] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624858] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 6.624866] cfg80211: Calling CRDA for country: EC
[ 6.625000] udevd[449]: renamed network interface wlan0 to wlan1
[ 6.629766] cfg80211: Regulatory domain changed to country: EC
[ 6.629769] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.629770] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 6.629772] cfg80211: (5170000 KHz - 5250000 KHz @ 20000 KHz), (N/A, 1700 mBm)
[ 6.629773] cfg80211: (5250000 KHz - 5330000 KHz @ 20000 KHz), (N/A, 2400 mBm)
[ 6.629774] cfg80211: (5490000 KHz - 5730000 KHz @ 20000 KHz), (N/A, 2400 mBm)
[ 6.629776] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm)
[ 6.643669] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 6.644148] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 6.644209] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 6.644248] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 6.644286] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 6.644334] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 6.644375] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 6.644410] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 6.795332] Adding 9920508k swap on /dev/sda5. Priority:-1 extents:1 across:9920508k SS
[ 6.802991] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 6.823773] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 6.841652] loop: module loaded
[ 7.170879] RPC: Registered named UNIX socket transport module.
[ 7.170881] RPC: Registered udp transport module.
[ 7.170882] RPC: Registered tcp transport module.
[ 7.170883] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.173355] FS-Cache: Loaded
[ 7.176210] NFS: Registering the id_resolver key type
[ 7.176221] FS-Cache: Netfs 'nfs' registered for caching
[ 7.178727] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 7.509716] Bluetooth: Core ver 2.16
[ 7.509727] NET: Registered protocol family 31
[ 7.509729] Bluetooth: HCI device and connection manager initialized
[ 7.509730] Bluetooth: HCI socket layer initialized
[ 7.509731] Bluetooth: L2CAP socket layer initialized
[ 7.509734] Bluetooth: SCO socket layer initialized
[ 7.517261] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.517264] Bluetooth: BNEP filters: protocol multicast
[ 7.519186] Bluetooth: RFCOMM TTY layer initialized
[ 7.519189] Bluetooth: RFCOMM socket layer initialized
[ 7.519190] Bluetooth: RFCOMM ver 1.11
[ 7.561242] lp: driver loaded but no devices found
[ 7.566808] ppdev: user-space parallel port driver
[ 8.007824] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 8.386110] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 9.721766] wlan1: authenticate with 28:16:2e:72:0b:51
[ 9.733582] wlan1: send auth to 28:16:2e:72:0b:51 (try 1/3)
[ 9.734911] wlan1: authenticated
[ 9.745364] wlan1: associate with 28:16:2e:72:0b:51 (try 1/3)
[ 9.747044] wlan1: RX AssocResp from 28:16:2e:72:0b:51 (capab=0x431 status=0 aid=4)
[ 9.747133] wlan1: associated
[ 9.747195] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 9.747232] cfg80211: Calling CRDA for country: US
[ 9.749867] cfg80211: Regulatory domain changed to country: US
[ 9.749869] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.749871] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 9.749872] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 9.749874] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 9.749875] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[ 9.749876] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 9.749878] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 9.762327]
[ cut here ]
[ 9.762340] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/net/mac80211/tx.c:770 invoke_tx_handlers+0x81a/0x12e0 [mac80211]()
[ 9.762342] Hardware name: To Be Filled By O.E.M.
[ 9.762343] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762381] Pid: 3154, comm: wpa_supplicant Not tainted 3.4-9-rtai-686-pae #1
[ 9.762383] Call Trace:
[ 9.762388] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762393] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762397] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762400] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762404] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762406] [<c10f8dfd>] ? do_select+0x4cd/0x530
[ 9.762412] [<f82c8676>] ? ieee80211_tx+0x66/0xd0 [mac80211]
[ 9.762416] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762420] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762424] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762427] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762429] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762433] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762435] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762438] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762440] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762442] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762445] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762447] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762449] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762451] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762453] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762455] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762457] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762460] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762462] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762464] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762466] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762467] ---[ end trace 085e24a6ba17e100 ]---
[ 9.762469]
[ cut here ]
[ 9.762472] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/net/mac80211/tx.c:55 invoke_tx_handlers+0x122c/0x12e0 [mac80211]()
[ 9.762473] Hardware name: To Be Filled By O.E.M.
[ 9.762474] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762502] Pid: 3154, comm: wpa_supplicant Tainted: G W 3.4-9-rtai-686-pae #1
[ 9.762503] Call Trace:
[ 9.762506] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762509] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762512] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762515] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762518] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762520] [<c10f8dfd>] ? do_select+0x4cd/0x530
[ 9.762523] [<f82c8676>] ? ieee80211_tx+0x66/0xd0 [mac80211]
[ 9.762527] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762530] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762533] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762535] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762537] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762539] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762542] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762544] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762546] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762548] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762549] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762552] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762554] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762555] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762557] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762559] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762561] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762563] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762565] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762567] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762569] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762570] ---[ end trace 085e24a6ba17e101 ]---
[ 9.762573]
[ cut here ]
[ 9.762576] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/include/net/mac80211.h:1330 rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]()
[ 9.762577] Hardware name: To Be Filled By O.E.M.
[ 9.762578] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762606] Pid: 3154, comm: wpa_supplicant Tainted: G W 3.4-9-rtai-686-pae #1
[ 9.762607] Call Trace:
[ 9.762610] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762613] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762615] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762617] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762619] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762622] [<c1007349>] ? nommu_map_page+0x39/0x70
[ 9.762625] [<f8283933>] ? rtl92ce_tx_fill_desc+0x143/0x710 [rtl8192ce]
[ 9.762628] [<c135df80>] ? printk+0x7c/0xe1
[ 9.762631] [<f81be4cf>] ? rtl_pci_tx+0x22f/0x520 [rtlwifi]
[ 9.762633] [<c102adfd>] ? warn_slowpath_common+0x7d/0xb0
[ 9.762636] [<f81ba4d0>] ? rtl_op_tx+0x80/0x90 [rtlwifi]
[ 9.762640] [<f82c65d6>] ? __ieee80211_tx+0x156/0x280 [mac80211]
[ 9.762644] [<f82c86b8>] ? ieee80211_tx+0xa8/0xd0 [mac80211]
[ 9.762647] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762651] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762653] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762655] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762657] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762659] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762662] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762664] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762666] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762668] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762670] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762672] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762674] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762675] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762677] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762679] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762681] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762683] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762685] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762687] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762689] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762690] ---[ end trace 085e24a6ba17e102 ]---
[ 18.012702] I-pipe: head domain RTAI registered.
[ 18.012706] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 18.012733] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 18.012735] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 18.012736] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 18.012738] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 6131250
[ 18.019985] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 18.019999] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 18.020002] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 18.020004] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 18.020005] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 18.029490] RTAI[math]: loaded.
[ 18.078579] hm2: loading Mesa HostMot2 driver version 0.15
[ 18.080301] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 18.080323] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 18.080608] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 18.135563] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 18.135565] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 18.135567] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 18.135568] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 18.135570] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 18.135571] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 18.135572] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 18.135573] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 18.135575] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 18.135576] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 18.135577] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 18.135578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 18.135579] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 18.135581] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 18.135582] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 18.135583] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 18.135585] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 18.135586] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 18.135587] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 18.135588] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 18.135590] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 18.135591] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 18.135592] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 18.135593] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 18.135594] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 18.135595] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 18.135597] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 18.135598] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 18.135599] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 18.135600] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 18.135601] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 18.135602] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 18.135604] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 18.135605] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 18.135606] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 18.135632] hm2/hm2_5i25.0: registered
[ 18.135634] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 18.245154] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 18.245158] hm2/hm2_5i25.0: unregistered
[ 18.245192] hm2_pci: driver unloaded
[ 18.246147] hm2: unloading
[ 20.294080] RTAI[math]: unloaded.
[ 20.295015] SCHED releases registered named ALIEN PEDV$D
[ 20.297943] RTAI[malloc]: unloaded.
[ 20.396693] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 20.397667] I-pipe: head domain RTAI unregistered.
[ 20.397703] RTAI[hal]: unmounted.
[ 195.084038] I-pipe: head domain RTAI registered.
[ 195.084041] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 195.084070] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 195.084072] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 195.084073] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 195.084075] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 6230000
[ 195.087339] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 195.087354] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 195.087357] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 195.087359] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 195.087360] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 195.090905] RTAI[math]: loaded.
[ 195.230573] hm2: loading Mesa HostMot2 driver version 0.15
[ 195.231636] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 195.231661] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 195.231949] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 195.286931] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 195.286933] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 195.286935] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 195.286937] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 195.286938] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 195.286939] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 195.286941] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 195.286942] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 195.286943] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 195.286944] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 195.286945] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 195.286947] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 195.286948] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 195.286949] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 195.286950] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 195.286952] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 195.286953] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 195.286954] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 195.286956] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 195.286957] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 195.286958] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 195.286959] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 195.286960] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 195.286961] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 195.286963] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 195.286964] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 195.286965] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 195.286966] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 195.286967] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 195.286968] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 195.286970] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 195.286971] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 195.286972] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 195.286973] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 195.286974] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 195.287001] hm2/hm2_5i25.0: registered
[ 195.287003] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 195.395151] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 195.395154] hm2/hm2_5i25.0: unregistered
[ 195.395188] hm2_pci: driver unloaded
[ 195.396075] hm2: unloading
[ 197.443704] RTAI[math]: unloaded.
[ 197.444577] SCHED releases registered named ALIEN PEDV$D
[ 197.447581] RTAI[malloc]: unloaded.
[ 197.544838] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 197.545807] I-pipe: head domain RTAI unregistered.
[ 197.545842] RTAI[hal]: unmounted.
[ 260.243415] [Hardware Error]: Machine check events logged
[ 465.169115] I-pipe: head domain RTAI registered.
[ 465.169119] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 465.169146] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 465.169148] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 465.169150] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 465.169152] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 5930500
[ 465.172393] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 465.172412] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 465.172414] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 465.172416] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 465.172418] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 465.182149] RTAI[math]: loaded.
[ 465.223132] hm2: loading Mesa HostMot2 driver version 0.15
[ 465.224102] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 465.224245] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 465.224537] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 465.279561] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 465.279564] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 465.279566] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 465.279568] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 465.279569] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 465.279570] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 465.279572] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 465.279573] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 465.279574] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 465.279575] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 465.279576] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 465.279578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 465.279579] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 465.279580] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 465.279581] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 465.279583] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 465.279584] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 465.279586] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 465.279587] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 465.279588] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 465.279589] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 465.279590] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 465.279592] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 465.279593] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 465.279594] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 465.279595] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 465.279596] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 465.279597] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 465.279599] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 465.279600] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 465.279601] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 465.279602] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 465.279603] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 465.279604] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 465.279606] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 465.279633] hm2/hm2_5i25.0: registered
[ 465.279634] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 465.390988] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 465.390991] hm2/hm2_5i25.0: unregistered
[ 465.391024] hm2_pci: driver unloaded
[ 465.391972] hm2: unloading
[ 467.443185] RTAI[math]: unloaded.
[ 467.444101] SCHED releases registered named ALIEN PEDV$D
[ 467.447248] RTAI[malloc]: unloaded.
[ 467.546453] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 467.547407] I-pipe: head domain RTAI unregistered.
[ 467.547442] RTAI[hal]: unmounted.
Today I tried to start my LinuxCNC program and it won't start up. It gave me this long file, which I'm not really sure what to look for. Can someone help me out? Below is what the report log generated:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/tim/linuxcnc/configs/Lathe'
Machine configuration file is 'Lathe.ini'
INIFILE=/home/tim/linuxcnc/configs/Lathe/Lathe.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Lathe.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=4130
Debug file information:
./Lathe.hal:27: Pin 'hm2_5i25.0.7i76.0.0.input-16' does not exist
4130
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bc8a4000 (usable)
[ 0.000000] BIOS-e820: 00000000bc8a4000 - 00000000bc8ab000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bc8ab000 - 00000000bd5a6000 (usable)
[ 0.000000] BIOS-e820: 00000000bd5a6000 - 00000000bdadb000 (reserved)
[ 0.000000] BIOS-e820: 00000000bdadb000 - 00000000cdac6000 (usable)
[ 0.000000] BIOS-e820: 00000000cdac6000 - 00000000cdb2d000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdb2d000 - 00000000cdb82000 (usable)
[ 0.000000] BIOS-e820: 00000000cdb82000 - 00000000cdcb5000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cdcb5000 - 00000000cdfff000 (reserved)
[ 0.000000] BIOS-e820: 00000000cdfff000 - 00000000ce000000 (usable)
[ 0.000000] BIOS-e820: 00000000cf000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000041ee00000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./H97 Pro4, BIOS P1.90 07/27/2015
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xce000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7C00000000 write-back
[ 0.000000] 1 base 0400000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00D0000000 mask 7FF0000000 uncachable
[ 0.000000] 4 base 00CF000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 041F000000 mask 7FFF000000 uncachable
[ 0.000000] 6 base 041EE00000 mask 7FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cf000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd170] fd170
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36522000 - 37289000
[ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT cdc84080 00084 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP cdc946d0 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT cdc841a0 1052F (v02 ALASKA A M I 00000190 INTL 20120711)
[ 0.000000] ACPI: FACS cdcb4f80 00040
[ 0.000000] ACPI: APIC cdc947e0 00062 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT cdc94848 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT cdc94890 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT cdc94dd0 00B74 (v01 CpuRef CpuSsdt 00003000 INTL 20051117)
[ 0.000000] ACPI: MCFG cdc95948 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET cdc95988 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT cdc959c0 0036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT cdc95d30 05B5E (v01 SaSsdt SaSsdt 00003000 INTL 20120711)
[ 0.000000] ACPI: ASF! cdc9b890 000A5 (v32 INTEL HCG 00000001 TFSM 000F4240)
[ 0.000000] ACPI: AAFT cdc9b938 0022C (v01 ALASKA OEMAAFT 01072009 MSFT 00000097)
[ 0.000000] ACPI: UEFI cdc9bb68 00042 (v01 ALASKA A M I 01072009 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2408MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000ce000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000bc8a4
[ 0.000000] 0: 0x000bc8ab -> 0x000bd5a6
[ 0.000000] 0: 0x000bdadb -> 0x000cdac6
[ 0.000000] 0: 0x000cdb2d -> 0x000cdb82
[ 0.000000] 0: 0x000cdfff -> 0x000ce000
[ 0.000000] On node 0 totalpages: 841069
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4b62200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4817 pages used for memmap
[ 0.000000] HighMem zone: 609041 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77c9000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 834476
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=68f83532-ebed-4681-a7a8-78652217663e ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x3, cntxt size 0x240
[ 0.000000] allocated 6750080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000ce000)
[ 0.000000] Memory: 3310720k/3375104k available (3495k kernel code, 53556k reserved, 1237k data, 416k init, 2455432k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f4006000 soft=f4008000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3192.841 MHz processor.
[ 0.000000] Calibrating delay loop (skipped), value calculated using timer frequency.. 6385.68 BogoMIPS (lpj=12771364)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000026] Security Framework initialized
[ 0.000029] AppArmor: AppArmor disabled by boot time parameter
[ 0.000038] Mount-cache hash table entries: 512
[ 0.000147] Initializing cgroup subsys cpuacct
[ 0.000149] Initializing cgroup subsys memory
[ 0.000152] Initializing cgroup subsys devices
[ 0.000154] Initializing cgroup subsys freezer
[ 0.000155] Initializing cgroup subsys net_cls
[ 0.000156] Initializing cgroup subsys blkio
[ 0.000159] Initializing cgroup subsys perf_event
[ 0.000176] CPU: Physical Processor ID: 0
[ 0.000177] CPU: Processor Core ID: 0
[ 0.001699] mce: CPU supports 7 MCE banks
[ 0.001707] CPU0: Thermal monitoring enabled (TM1)
[ 0.001769] ACPI: Core revision 20120320
[ 0.010875] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.011197] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.050793] CPU0: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz stepping 03
[ 0.158148] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.158153] ... version: 3
[ 0.158154] ... bit width: 48
[ 0.158155] ... generic registers: 8
[ 0.158156] ... value mask: 0000ffffffffffff
[ 0.158157] ... max period: 000000007fffffff
[ 0.158158] ... fixed-purpose events: 3
[ 0.158159] ... event mask: 00000007000000ff
[ 0.170152] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.182114] CPU 1 irqstacks, hard=f40d2000 soft=f40d4000
[ 0.182116] Booting Node 0, Processors #1 Ok.
[ 0.192306] Initializing CPU#1
[ 0.196711] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196731] Brought up 2 CPUs
[ 0.196733] Total of 2 processors activated (12771.36 BogoMIPS).
[ 0.197902] devtmpfs: initialized
[ 0.198051] PM: Registering ACPI NVS region [mem 0xbc8a4000-0xbc8aafff] (28672 bytes)
[ 0.198058] PM: Registering ACPI NVS region [mem 0xcdb82000-0xcdcb4fff] (1257472 bytes)
[ 0.198141] dummy:
[ 0.198174] NET: Registered protocol family 16
[ 0.198250] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.198252] ACPI: bus type pci registered
[ 0.198285] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.198287] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.198288] PCI: Using MMCONFIG for extended config space
[ 0.198289] PCI: Using configuration type 1 for base access
[ 0.198645] bio: create slab <bio-0> at 0
[ 0.198699] ACPI: Added _OSI(Module Device)
[ 0.198701] ACPI: Added _OSI(Processor Device)
[ 0.198703] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.198704] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.201373] ACPI: EC: Look up EC in DSDT
[ 0.204851] ACPI: Executed 15 blocks of module-level executable AML code
[ 0.209522] ACPI: SSDT cdb0bc18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.210218] ACPI: Dynamic OEM Table Load:
[ 0.210220] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.210447] ACPI: SSDT cdb0b618 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.211230] ACPI: Dynamic OEM Table Load:
[ 0.211232] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.211330] ACPI: SSDT cdb0ad98 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.212026] ACPI: Dynamic OEM Table Load:
[ 0.212028] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.212642] ACPI: Interpreter enabled
[ 0.212650] ACPI: (supports S0 S3 S4 S5)
[ 0.212674] ACPI: Using IOAPIC for interrupt routing
[ 0.213026] ACPI: Power Resource [PG00] (on)
[ 0.213365] ACPI: Power Resource [PG01] (on)
[ 0.213698] ACPI: Power Resource [PG02] (on)
[ 0.219779] ACPI: No dock devices found.
[ 0.219783] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.220057] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.220414] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.220416] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.220417] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.220419] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.220420] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.220421] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.220423] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.220424] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.220425] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.220427] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.220447] PCI host bridge to bus 0000:00
[ 0.220448] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.220450] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.220451] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.220453] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.220454] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.220455] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.220456] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.220458] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.220459] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.220460] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.220467] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.220496] pci 0000:00:02.0: [8086:0402] type 00 class 0x030000
[ 0.220505] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.220510] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.220514] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.220555] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
[ 0.220572] pci 0000:00:14.0: reg 10: [mem 0xf7e20000-0xf7e2ffff 64bit]
[ 0.220616] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.220634] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
[ 0.220654] pci 0000:00:16.0: reg 10: [mem 0xf7e3b000-0xf7e3b00f 64bit]
[ 0.220701] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.220726] pci 0000:00:19.0: [8086:15a1] type 00 class 0x020000
[ 0.220741] pci 0000:00:19.0: reg 10: [mem 0xf7e00000-0xf7e1ffff]
[ 0.220748] pci 0000:00:19.0: reg 14: [mem 0xf7e38000-0xf7e38fff]
[ 0.220755] pci 0000:00:19.0: reg 18: [io 0xf080-0xf09f]
[ 0.220798] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.220819] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
[ 0.220838] pci 0000:00:1a.0: reg 10: [mem 0xf7e37000-0xf7e373ff]
[ 0.220904] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.220926] pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300
[ 0.220939] pci 0000:00:1b.0: reg 10: [mem 0xf7e30000-0xf7e33fff 64bit]
[ 0.220986] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.221003] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
[ 0.221049] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.221068] pci 0000:00:1c.2: [8086:8c94] type 01 class 0x060400
[ 0.221115] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.221136] pci 0000:00:1c.6: [8086:244e] type 01 class 0x060401
[ 0.221182] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[ 0.221206] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
[ 0.221224] pci 0000:00:1d.0: reg 10: [mem 0xf7e36000-0xf7e363ff]
[ 0.221291] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.221313] pci 0000:00:1f.0: [8086:8cc6] type 00 class 0x060100
[ 0.221413] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
[ 0.221427] pci 0000:00:1f.2: reg 10: [io 0xf0d0-0xf0d7]
[ 0.221433] pci 0000:00:1f.2: reg 14: [io 0xf0c0-0xf0c3]
[ 0.221440] pci 0000:00:1f.2: reg 18: [io 0xf0b0-0xf0b7]
[ 0.221446] pci 0000:00:1f.2: reg 1c: [io 0xf0a0-0xf0a3]
[ 0.221452] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.221459] pci 0000:00:1f.2: reg 24: [mem 0xf7e35000-0xf7e357ff]
[ 0.221483] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.221496] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
[ 0.221508] pci 0000:00:1f.3: reg 10: [mem 0xf7e34000-0xf7e340ff 64bit]
[ 0.221526] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.221579] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.221637] pci 0000:02:00.0: [10ec:8178] type 00 class 0x028000
[ 0.221655] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.221686] pci 0000:02:00.0: reg 18: [mem 0xf7d00000-0xf7d03fff 64bit]
[ 0.221756] pci 0000:02:00.0: supports D1 D2
[ 0.221757] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.228657] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.228660] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.228663] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.228711] pci 0000:03:00.0: [1b21:1080] type 01 class 0x060401
[ 0.228796] pci 0000:00:1c.6: PCI bridge to [bus 03-04] (subtractive decode)
[ 0.228800] pci 0000:00:1c.6: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.228805] pci 0000:00:1c.6: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.228806] pci 0000:00:1c.6: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.228808] pci 0000:00:1c.6: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.228809] pci 0000:00:1c.6: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.228810] pci 0000:00:1c.6: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.228812] pci 0000:00:1c.6: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.228813] pci 0000:00:1c.6: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.228815] pci 0000:00:1c.6: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.228816] pci 0000:00:1c.6: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.228818] pci 0000:00:1c.6: bridge window [mem 0xdf200000-0xfeafffff] (subtractive decode)
[ 0.228859] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.228879] pci 0000:04:00.0: reg 10: [mem 0xf7c00000-0xf7c0ffff]
[ 0.229030] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.229041] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.229049] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229051] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[ 0.229052] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229054] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.229055] pci 0000:03:00.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.229056] pci 0000:03:00.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.229058] pci 0000:03:00.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.229059] pci 0000:03:00.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.229061] pci 0000:03:00.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.229062] pci 0000:03:00.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.229063] pci 0000:03:00.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.229065] pci 0000:03:00.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.229066] pci 0000:03:00.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.229068] pci 0000:03:00.0: bridge window [mem 0xdf200000-0xfeafffff] (subtractive decode)
[ 0.229088] pci_bus 0000:00: on NUMA node 0
[ 0.229090] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.229244] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.229280] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.229317] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07._PRT]
[ 0.229354] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP07.BR40._PRT]
[ 0.229502] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.239532] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.239572] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.239612] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.239649] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.239687] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.239725] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.239763] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.239801] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.239846] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.239852] vgaarb: loaded
[ 0.239853] vgaarb: bridge control possible 0000:00:02.0
[ 0.239869] PCI: Using ACPI for IRQ routing
[ 0.241159] PCI: pci_cache_line_size set to 64 bytes
[ 0.241215] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.241217] reserve RAM buffer: 00000000bc8a4000 - 00000000bfffffff
[ 0.241218] reserve RAM buffer: 00000000bd5a6000 - 00000000bfffffff
[ 0.241219] reserve RAM buffer: 00000000cdac6000 - 00000000cfffffff
[ 0.241221] reserve RAM buffer: 00000000cdb82000 - 00000000cfffffff
[ 0.241222] reserve RAM buffer: 00000000ce000000 - 00000000cfffffff
[ 0.241300] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.241306] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.243313] Switching to clocksource hpet
[ 0.243342] pnp: PnP ACPI init
[ 0.243348] ACPI: bus type pnp registered
[ 0.243544] pnp 00:00: [bus 00-3e]
[ 0.243546] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.243547] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.243548] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.243550] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.243551] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.243552] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.243553] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.243555] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.243556] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.243557] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.243558] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.243560] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.243561] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.243562] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.243563] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.243565] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.243566] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.243567] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.243602] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.243658] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.243684] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.243686] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.243694] pnp 00:02: [io 0x0000-0x001f]
[ 0.243695] pnp 00:02: [io 0x0081-0x0091]
[ 0.243696] pnp 00:02: [io 0x0093-0x009f]
[ 0.243697] pnp 00:02: [io 0x00c0-0x00df]
[ 0.243698] pnp 00:02: [dma 4]
[ 0.243715] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.243720] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.243737] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.243790] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.243808] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.243825] pnp 00:05: [io 0x00f0]
[ 0.243830] pnp 00:05: [irq 13]
[ 0.243848] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.243865] pnp 00:06: [io 0x0800-0x087f]
[ 0.243891] system 00:06: [io 0x0800-0x087f] has been reserved
[ 0.243892] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.243898] pnp 00:07: [io 0x0070-0x0077]
[ 0.243901] pnp 00:07: [irq 8]
[ 0.243920] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.243933] pnp 00:08: [io 0x1854-0x1857]
[ 0.243958] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.243960] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.244003] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.244004] pnp 00:09: [io 0x0290-0x029f]
[ 0.244006] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.244032] system 00:09: [io 0x0290-0x029f] has been reserved
[ 0.244034] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.244211] pnp 00:0a: [io 0x0010-0x001f]
[ 0.244213] pnp 00:0a: [io 0x0022-0x003f]
[ 0.244214] pnp 00:0a: [io 0x0044-0x005f]
[ 0.244215] pnp 00:0a: [io 0x0062-0x0063]
[ 0.244216] pnp 00:0a: [io 0x0065-0x006f]
[ 0.244217] pnp 00:0a: [io 0x0072-0x007f]
[ 0.244218] pnp 00:0a: [io 0x0080]
[ 0.244219] pnp 00:0a: [io 0x0084-0x0086]
[ 0.244221] pnp 00:0a: [io 0x0088]
[ 0.244222] pnp 00:0a: [io 0x008c-0x008e]
[ 0.244223] pnp 00:0a: [io 0x0090-0x009f]
[ 0.244224] pnp 00:0a: [io 0x00a2-0x00bf]
[ 0.244225] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.244227] pnp 00:0a: [io 0x04d0-0x04d1]
[ 0.244256] system 00:0a: [io 0x04d0-0x04d1] has been reserved
[ 0.244258] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.244394] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.244398] pnp 00:0b: [irq 4]
[ 0.244399] pnp 00:0b: [dma 0 disabled]
[ 0.244437] pnp 00:0b: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.244816] pnp 00:0c: [mem 0xfed1c000-0xfed1ffff]
[ 0.244817] pnp 00:0c: [mem 0xfed10000-0xfed17fff]
[ 0.244819] pnp 00:0c: [mem 0xfed18000-0xfed18fff]
[ 0.244820] pnp 00:0c: [mem 0xfed19000-0xfed19fff]
[ 0.244821] pnp 00:0c: [mem 0xf8000000-0xfbffffff]
[ 0.244822] pnp 00:0c: [mem 0xfed20000-0xfed3ffff]
[ 0.244823] pnp 00:0c: [mem 0xfed90000-0xfed93fff]
[ 0.244825] pnp 00:0c: [mem 0xfed45000-0xfed8ffff]
[ 0.244826] pnp 00:0c: [mem 0xff000000-0xffffffff]
[ 0.244827] pnp 00:0c: [mem 0xfee00000-0xfeefffff]
[ 0.244828] pnp 00:0c: [mem 0xf7fe0000-0xf7feffff]
[ 0.244870] system 00:0c: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.244872] system 00:0c: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.244874] system 00:0c: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.244875] system 00:0c: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.244877] system 00:0c: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.244878] system 00:0c: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.244880] system 00:0c: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.244881] system 00:0c: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.244883] system 00:0c: [mem 0xff000000-0xffffffff] has been reserved
[ 0.244885] system 00:0c: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.244886] system 00:0c: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.244888] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.245043] pnp: PnP ACPI: found 13 devices
[ 0.245044] ACPI: ACPI bus type pnp unregistered
[ 0.245046] PnPBIOS: Disabled by ACPI PNP
[ 0.280659] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.280668] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.280670] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.280674] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.280680] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.280687] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.280698] pci 0000:00:1c.6: PCI bridge to [bus 03-04]
[ 0.280702] pci 0000:00:1c.6: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.280735] pci 0000:03:00.0: setting latency timer to 64
[ 0.280738] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.280739] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.280741] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.280742] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.280743] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.280745] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.280746] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.280747] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.280748] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.280750] pci_bus 0000:00: resource 13 [mem 0xdf200000-0xfeafffff]
[ 0.280751] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.280753] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.280754] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.280755] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.280756] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.280758] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.280759] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.280760] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.280761] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.280763] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.280764] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.280765] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.280767] pci_bus 0000:03: resource 13 [mem 0xdf200000-0xfeafffff]
[ 0.280768] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.280769] pci_bus 0000:04: resource 5 [mem 0xf7c00000-0xf7cfffff]
[ 0.280771] pci_bus 0000:04: resource 8 [io 0x0000-0x0cf7]
[ 0.280772] pci_bus 0000:04: resource 9 [io 0x0d00-0xffff]
[ 0.280773] pci_bus 0000:04: resource 10 [mem 0x000a0000-0x000bffff]
[ 0.280774] pci_bus 0000:04: resource 11 [mem 0x000d0000-0x000d3fff]
[ 0.280776] pci_bus 0000:04: resource 12 [mem 0x000d4000-0x000d7fff]
[ 0.280777] pci_bus 0000:04: resource 13 [mem 0x000d8000-0x000dbfff]
[ 0.280778] pci_bus 0000:04: resource 14 [mem 0x000dc000-0x000dffff]
[ 0.280779] pci_bus 0000:04: resource 15 [mem 0x000e0000-0x000e3fff]
[ 0.280781] pci_bus 0000:04: resource 16 [mem 0x000e4000-0x000e7fff]
[ 0.280782] pci_bus 0000:04: resource 17 [mem 0xdf200000-0xfeafffff]
[ 0.280823] NET: Registered protocol family 2
[ 0.280856] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.280944] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.281056] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.281114] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.281116] TCP: reno registered
[ 0.281117] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.281120] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.281162] NET: Registered protocol family 1
[ 0.281169] pci 0000:00:02.0: Boot video device
[ 0.281473] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.281479] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.319173] PCI: CLS 64 bytes, default 64
[ 0.319197] Unpacking initramfs...
[ 0.506338] Freeing initrd memory: 13724k freed
[ 0.507660] audit: initializing netlink socket (disabled)
[ 0.507668] type=2000 audit(1502926388.400:1): initialized
[ 0.516228] highmem bounce pool size: 64 pages
[ 0.516231] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.516345] VFS: Disk quotas dquot_6.5.2
[ 0.516360] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.516403] msgmni has been set to 1697
[ 0.516498] alg: No test for stdrng (krng)
[ 0.516514] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.516516] io scheduler noop registered
[ 0.516517] io scheduler deadline registered
[ 0.516528] io scheduler cfq registered (default)
[ 0.516640] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.516649] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.516651] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.516868] acpiphp: Slot [1] registered
[ 0.517020] GHES: HEST is not enabled!
[ 0.517027] isapnp: Scanning for PnP cards...
[ 0.870604] isapnp: No Plug & Play device found
[ 0.870635] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.890944] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.911468] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.911646] Linux agpgart interface v0.103
[ 0.911739] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.914536] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.914552] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.914603] mousedev: PS/2 mouse device common for all mice
[ 0.914635] rtc_cmos 00:07: RTC can wake from S4
[ 0.914731] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.914754] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.914826] TCP: cubic registered
[ 0.914856] NET: Registered protocol family 10
[ 0.914978] Mobile IPv6
[ 0.914980] NET: Registered protocol family 17
[ 0.914982] Registering the dns_resolver key type
[ 0.915017] Using IPI No-Shortcut mode
[ 0.915081] PM: Hibernation image not present or could not be loaded.
[ 0.915086] registered taskstats version 1
[ 0.915461] rtc_cmos 00:07: setting system clock to 2017-08-16 23:33:09 UTC (1502926389)
[ 0.915529] Freeing unused kernel memory: 416k freed
[ 0.915604] Write protecting the kernel text: 3496k
[ 0.915616] Write protecting the kernel read-only data: 984k
[ 0.922058] udevd[49]: starting version 175
[ 0.939695] usbcore: registered new interface driver usbfs
[ 0.939708] usbcore: registered new interface driver hub
[ 0.943691] usbcore: registered new device driver usb
[ 0.943912] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.943949] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.943952] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.943967] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.943984] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.946563] SCSI subsystem initialized
[ 0.954699] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x19
[ 0.954762] libata version 3.00 loaded.
[ 0.959882] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.959898] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7e37000
[ 0.969692] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.969723] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.969725] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.969726] usb usb1: Product: EHCI Host Controller
[ 0.969727] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.969729] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.969797] hub 1-0:1.0: USB hub found
[ 0.969800] hub 1-0:1.0: 2 ports detected
[ 0.969879] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.969882] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.969887] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.969904] ehci_hcd 0000:00:1d.0: debug port 2
[ 0.973909] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 0.973925] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7e36000
[ 0.984526] microcode: CPU0 updated to revision 0x1c, date = 2014-07-03
[ 0.984536] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x19
[ 0.985664] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.985692] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.985694] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.985696] usb usb2: Product: EHCI Host Controller
[ 0.985697] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.985698] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.985768] hub 2-0:1.0: USB hub found
[ 0.985771] hub 2-0:1.0: 2 ports detected
[ 0.986674] microcode: CPU1 updated to revision 0x1c, date = 2014-07-03
[ 0.986755] ahci 0000:00:1f.2: version 3.0
[ 0.986817] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
[ 0.986819] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.986822] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.987081] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 0.993981] scsi0 : ahci
[ 0.994044] scsi1 : ahci
[ 0.994088] scsi2 : ahci
[ 0.994133] scsi3 : ahci
[ 0.994170] scsi4 : ahci
[ 0.994206] scsi5 : ahci
[ 0.994695] ata1: SATA max UDMA/133 abar m2048@0xf7e35000 port 0xf7e35100 irq 19
[ 0.994697] ata2: SATA max UDMA/133 abar m2048@0xf7e35000 port 0xf7e35180 irq 19
[ 0.994698] ata3: DUMMY
[ 0.994699] ata4: DUMMY
[ 0.994700] ata5: DUMMY
[ 0.994701] ata6: DUMMY
[ 0.994730] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.994733] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.994759] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 0.994761] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.994768] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.994838] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.994861] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.994862] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994864] usb usb3: Product: xHCI Host Controller
[ 0.994865] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.994866] usb usb3: SerialNumber: 0000:00:14.0
[ 0.994913] xHCI xhci_add_endpoint called for root hub
[ 0.994915] xHCI xhci_check_bandwidth called for root hub
[ 0.994932] hub 3-0:1.0: USB hub found
[ 0.994946] hub 3-0:1.0: 14 ports detected
[ 0.995014] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.995017] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.995033] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.995034] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.995036] usb usb4: Product: xHCI Host Controller
[ 0.995037] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.995038] usb usb4: SerialNumber: 0000:00:14.0
[ 0.995083] xHCI xhci_add_endpoint called for root hub
[ 0.995084] xHCI xhci_check_bandwidth called for root hub
[ 0.995098] hub 4-0:1.0: USB hub found
[ 0.995108] hub 4-0:1.0: 6 ports detected
[ 1.280929] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.312863] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.312878] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.314516] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.314519] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.314521] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.314744] ata1.00: supports DRM functions and may not be fully accessible
[ 1.314783] ata1.00: ATA-9: Samsung SSD 850 EVO 250GB, EMT02B6Q, max UDMA/133
[ 1.314784] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.315127] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.315129] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.315131] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.315353] ata1.00: supports DRM functions and may not be fully accessible
[ 1.315391] ata1.00: configured for UDMA/133
[ 1.315466] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 850 EMT0 PQ: 0 ANSI: 5
[ 1.316735] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.316737] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.316738] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.317037] ata2.00: ATAPI: ASUS DRW-24B1ST j, 1.01, max UDMA/133
[ 1.318465] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.318466] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.318468] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.318764] ata2.00: configured for UDMA/133
[ 1.320031] scsi 1:0:0:0: CD-ROM ASUS DRW-24B1ST j 1.01 PQ: 0 ANSI: 5
[ 1.323542] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.323573] sd 0:0:0:0: [sda] Write Protect is off
[ 1.323575] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.323585] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.323960] sda: sda1 sda2 < sda5 >
[ 1.324120] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.324993] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.325071] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.326441] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.326444] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.326563] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.413022] usb 1-1: New USB device found, idVendor=8087, idProduct=8009
[ 1.413024] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.413170] hub 1-1:1.0: USB hub found
[ 1.413268] hub 1-1:1.0: 6 ports detected
[ 1.504409] Refined TSC clocksource calibration: 3192.606 MHz.
[ 1.504412] Switching to clocksource tsc
[ 1.524368] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.656450] usb 2-1: New USB device found, idVendor=8087, idProduct=8001
[ 1.656452] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.656594] hub 2-1:1.0: USB hub found
[ 1.656699] hub 2-1:1.0: 8 ports detected
[ 1.927576] usb 2-1.7: new low-speed USB device number 3 using ehci_hcd
[ 2.024724] usb 2-1.7: New USB device found, idVendor=046d, idProduct=c31c
[ 2.024726] usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.024727] usb 2-1.7: Product: USB Keyboard
[ 2.024729] usb 2-1.7: Manufacturer: Logitech
[ 2.031942] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.0/input/input0
[ 2.031978] generic-usb 0003:046D:C31C.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboard] on usb-0000:00:1d.0-1.7/input0
[ 2.038225] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.1/input/input1
[ 2.038252] generic-usb 0003:046D:C31C.0002: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard] on usb-0000:00:1d.0-1.7/input1
[ 2.038263] usbcore: registered new interface driver usbhid
[ 2.038264] usbhid: USB HID core driver
[ 2.099179] usb 2-1.8: new low-speed USB device number 4 using ehci_hcd
[ 2.195330] usb 2-1.8: New USB device found, idVendor=046d, idProduct=c077
[ 2.195332] usb 2-1.8: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.195333] usb 2-1.8: Product: USB Optical Mouse
[ 2.195334] usb 2-1.8: Manufacturer: Logitech
[ 2.197278] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8:1.0/input/input2
[ 2.197318] generic-usb 0003:046D:C077.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.8/input0
[ 6.377704] PM: Starting manual resume from disk
[ 6.377706] PM: Hibernation image partition 8:5 present
[ 6.377707] PM: Looking for hibernation image.
[ 6.377847] PM: Image not found (code -22)
[ 6.377849] PM: Hibernation image not present or could not be loaded.
[ 6.390575] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.494054] udevd[402]: starting version 175
[ 6.555304] cfg80211: Calling CRDA to update world regulatory domain
[ 6.580181] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 6.580186] ACPI: Power Button [PWRB]
[ 6.580214] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 6.580217] ACPI: Sleep Button [SLPB]
[ 6.580241] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 6.580243] ACPI: Power Button [PWRF]
[ 6.597985] rtl8192ce: Using firmware rtlwifi/rtl8192cfw.bin
[ 6.620544] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 6.620763] rtlwifi: wireless switch is on
[ 6.624845] cfg80211: World regulatory domain updated:
[ 6.624848] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.624849] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 6.624851] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 6.624852] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 6.624853] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624854] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624856] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[ 6.624857] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 6.624858] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 6.624866] cfg80211: Calling CRDA for country: EC
[ 6.625000] udevd[449]: renamed network interface wlan0 to wlan1
[ 6.629766] cfg80211: Regulatory domain changed to country: EC
[ 6.629769] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 6.629770] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 6.629772] cfg80211: (5170000 KHz - 5250000 KHz @ 20000 KHz), (N/A, 1700 mBm)
[ 6.629773] cfg80211: (5250000 KHz - 5330000 KHz @ 20000 KHz), (N/A, 2400 mBm)
[ 6.629774] cfg80211: (5490000 KHz - 5730000 KHz @ 20000 KHz), (N/A, 2400 mBm)
[ 6.629776] cfg80211: (5735000 KHz - 5835000 KHz @ 20000 KHz), (N/A, 3000 mBm)
[ 6.643669] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 6.644148] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 6.644209] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 6.644248] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 6.644286] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 6.644334] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 6.644375] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 6.644410] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 6.795332] Adding 9920508k swap on /dev/sda5. Priority:-1 extents:1 across:9920508k SS
[ 6.802991] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 6.823773] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 6.841652] loop: module loaded
[ 7.170879] RPC: Registered named UNIX socket transport module.
[ 7.170881] RPC: Registered udp transport module.
[ 7.170882] RPC: Registered tcp transport module.
[ 7.170883] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 7.173355] FS-Cache: Loaded
[ 7.176210] NFS: Registering the id_resolver key type
[ 7.176221] FS-Cache: Netfs 'nfs' registered for caching
[ 7.178727] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 7.509716] Bluetooth: Core ver 2.16
[ 7.509727] NET: Registered protocol family 31
[ 7.509729] Bluetooth: HCI device and connection manager initialized
[ 7.509730] Bluetooth: HCI socket layer initialized
[ 7.509731] Bluetooth: L2CAP socket layer initialized
[ 7.509734] Bluetooth: SCO socket layer initialized
[ 7.517261] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.517264] Bluetooth: BNEP filters: protocol multicast
[ 7.519186] Bluetooth: RFCOMM TTY layer initialized
[ 7.519189] Bluetooth: RFCOMM socket layer initialized
[ 7.519190] Bluetooth: RFCOMM ver 1.11
[ 7.561242] lp: driver loaded but no devices found
[ 7.566808] ppdev: user-space parallel port driver
[ 8.007824] ADDRCONF(NETDEV_UP): wlan1: link is not ready
[ 8.386110] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input14
[ 9.721766] wlan1: authenticate with 28:16:2e:72:0b:51
[ 9.733582] wlan1: send auth to 28:16:2e:72:0b:51 (try 1/3)
[ 9.734911] wlan1: authenticated
[ 9.745364] wlan1: associate with 28:16:2e:72:0b:51 (try 1/3)
[ 9.747044] wlan1: RX AssocResp from 28:16:2e:72:0b:51 (capab=0x431 status=0 aid=4)
[ 9.747133] wlan1: associated
[ 9.747195] ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[ 9.747232] cfg80211: Calling CRDA for country: US
[ 9.749867] cfg80211: Regulatory domain changed to country: US
[ 9.749869] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 9.749871] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm)
[ 9.749872] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 9.749874] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm)
[ 9.749875] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm)
[ 9.749876] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm)
[ 9.749878] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 9.762327]
[ cut here ]
[ 9.762340] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/net/mac80211/tx.c:770 invoke_tx_handlers+0x81a/0x12e0 [mac80211]()
[ 9.762342] Hardware name: To Be Filled By O.E.M.
[ 9.762343] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762381] Pid: 3154, comm: wpa_supplicant Not tainted 3.4-9-rtai-686-pae #1
[ 9.762383] Call Trace:
[ 9.762388] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762393] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762397] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762400] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762404] [<f82c7a6a>] ? invoke_tx_handlers+0x81a/0x12e0 [mac80211]
[ 9.762406] [<c10f8dfd>] ? do_select+0x4cd/0x530
[ 9.762412] [<f82c8676>] ? ieee80211_tx+0x66/0xd0 [mac80211]
[ 9.762416] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762420] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762424] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762427] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762429] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762433] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762435] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762438] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762440] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762442] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762445] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762447] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762449] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762451] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762453] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762455] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762457] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762460] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762462] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762464] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762466] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762467] ---[ end trace 085e24a6ba17e100 ]---
[ 9.762469]
[ cut here ]
[ 9.762472] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/net/mac80211/tx.c:55 invoke_tx_handlers+0x122c/0x12e0 [mac80211]()
[ 9.762473] Hardware name: To Be Filled By O.E.M.
[ 9.762474] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762502] Pid: 3154, comm: wpa_supplicant Tainted: G W 3.4-9-rtai-686-pae #1
[ 9.762503] Call Trace:
[ 9.762506] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762509] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762512] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762515] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762518] [<f82c847c>] ? invoke_tx_handlers+0x122c/0x12e0 [mac80211]
[ 9.762520] [<c10f8dfd>] ? do_select+0x4cd/0x530
[ 9.762523] [<f82c8676>] ? ieee80211_tx+0x66/0xd0 [mac80211]
[ 9.762527] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762530] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762533] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762535] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762537] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762539] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762542] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762544] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762546] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762548] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762549] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762552] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762554] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762555] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762557] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762559] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762561] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762563] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762565] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762567] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762569] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762570] ---[ end trace 085e24a6ba17e101 ]---
[ 9.762573]
[ cut here ]
[ 9.762576] WARNING: at /tmp/buildd/linux-3.4.55/debian/build/source_rtai/include/net/mac80211.h:1330 rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]()
[ 9.762577] Hardware name: To Be Filled By O.E.M.
[ 9.762578] Modules linked in: parport_pc ppdev lp parport rfcomm bnep bluetooth uinput nfsd nfs nfs_acl auth_rpcgss fscache lockd sunrpc loop snd_hda_codec_realtek arc4 video thermal_sys snd_hda_intel snd_hda_codec snd_hwdep snd_pcm snd_page_alloc snd_seq snd_seq_device joydev snd_timer evdev button rtl8192ce rtlwifi rtl8192c_common coretemp mac80211 psmouse snd cfg80211 crc32c_intel rfkill serio_raw soundcore ext4 crc16 jbd2 mbcache usbhid hid sg sr_mod sd_mod cdrom crc_t10dif xhci_hcd ahci libahci microcode libata scsi_mod ehci_hcd usbcore usb_common [last unloaded: scsi_wait_scan]
[ 9.762606] Pid: 3154, comm: wpa_supplicant Tainted: G W 3.4-9-rtai-686-pae #1
[ 9.762607] Call Trace:
[ 9.762610] [<c102adf8>] ? warn_slowpath_common+0x78/0xb0
[ 9.762613] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762615] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762617] [<c102ae4b>] ? warn_slowpath_null+0x1b/0x20
[ 9.762619] [<f81b5830>] ? rtl_get_tcb_desc+0x400/0x5d0 [rtlwifi]
[ 9.762622] [<c1007349>] ? nommu_map_page+0x39/0x70
[ 9.762625] [<f8283933>] ? rtl92ce_tx_fill_desc+0x143/0x710 [rtl8192ce]
[ 9.762628] [<c135df80>] ? printk+0x7c/0xe1
[ 9.762631] [<f81be4cf>] ? rtl_pci_tx+0x22f/0x520 [rtlwifi]
[ 9.762633] [<c102adfd>] ? warn_slowpath_common+0x7d/0xb0
[ 9.762636] [<f81ba4d0>] ? rtl_op_tx+0x80/0x90 [rtlwifi]
[ 9.762640] [<f82c65d6>] ? __ieee80211_tx+0x156/0x280 [mac80211]
[ 9.762644] [<f82c86b8>] ? ieee80211_tx+0xa8/0xd0 [mac80211]
[ 9.762647] [<f82c877e>] ? ieee80211_xmit+0x9e/0xf0 [mac80211]
[ 9.762651] [<f82c8e2b>] ? ieee80211_subif_start_xmit+0x38b/0xb10 [mac80211]
[ 9.762653] [<c128b65b>] ? netif_skb_features+0xfb/0x110
[ 9.762655] [<c12913da>] ? dev_hard_start_xmit+0x32a/0x560
[ 9.762657] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762659] [<c12a7683>] ? sch_direct_xmit+0xb3/0x190
[ 9.762662] [<c1291734>] ? dev_queue_xmit+0x124/0x530
[ 9.762664] [<c13432df>] ? packet_sendmsg+0xa7f/0xb20
[ 9.762666] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762668] [<c12a5890>] ? eth_rebuild_header+0x80/0x80
[ 9.762670] [<c127ccd5>] ? sock_sendmsg+0xf5/0x110
[ 9.762672] [<c1053d2c>] ? update_curr+0x18c/0x2a0
[ 9.762674] [<c104ec08>] ? get_parent_ip+0x8/0x20
[ 9.762675] [<c1367107>] ? sub_preempt_count+0x67/0xa0
[ 9.762677] [<c1027894>] ? __kunmap_atomic+0x34/0x90
[ 9.762679] [<c10c28af>] ? __do_fault+0x1af/0x4a0
[ 9.762681] [<c127ea55>] ? sys_sendto+0x105/0x160
[ 9.762683] [<c1366c7d>] ? do_page_fault+0x19d/0x4b0
[ 9.762685] [<c10dc13d>] ? kmem_cache_free+0x6d/0xa0
[ 9.762687] [<c127f554>] ? sys_socketcall+0x214/0x330
[ 9.762689] [<c1368c28>] ? sysenter_do_call+0x12/0x16
[ 9.762690] ---[ end trace 085e24a6ba17e102 ]---
[ 18.012702] I-pipe: head domain RTAI registered.
[ 18.012706] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 18.012733] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 18.012735] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 18.012736] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 18.012738] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 6131250
[ 18.019985] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 18.019999] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 18.020002] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 18.020004] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 18.020005] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 18.029490] RTAI[math]: loaded.
[ 18.078579] hm2: loading Mesa HostMot2 driver version 0.15
[ 18.080301] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 18.080323] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 18.080608] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 18.135563] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 18.135565] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 18.135567] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 18.135568] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 18.135570] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 18.135571] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 18.135572] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 18.135573] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 18.135575] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 18.135576] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 18.135577] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 18.135578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 18.135579] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 18.135581] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 18.135582] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 18.135583] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 18.135585] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 18.135586] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 18.135587] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 18.135588] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 18.135590] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 18.135591] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 18.135592] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 18.135593] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 18.135594] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 18.135595] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 18.135597] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 18.135598] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 18.135599] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 18.135600] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 18.135601] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 18.135602] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 18.135604] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 18.135605] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 18.135606] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 18.135632] hm2/hm2_5i25.0: registered
[ 18.135634] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 18.245154] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 18.245158] hm2/hm2_5i25.0: unregistered
[ 18.245192] hm2_pci: driver unloaded
[ 18.246147] hm2: unloading
[ 20.294080] RTAI[math]: unloaded.
[ 20.295015] SCHED releases registered named ALIEN PEDV$D
[ 20.297943] RTAI[malloc]: unloaded.
[ 20.396693] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 20.397667] I-pipe: head domain RTAI unregistered.
[ 20.397703] RTAI[hal]: unmounted.
[ 195.084038] I-pipe: head domain RTAI registered.
[ 195.084041] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 195.084070] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 195.084072] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 195.084073] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 195.084075] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 6230000
[ 195.087339] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 195.087354] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 195.087357] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 195.087359] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 195.087360] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 195.090905] RTAI[math]: loaded.
[ 195.230573] hm2: loading Mesa HostMot2 driver version 0.15
[ 195.231636] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 195.231661] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 195.231949] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 195.286931] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 195.286933] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 195.286935] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 195.286937] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 195.286938] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 195.286939] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 195.286941] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 195.286942] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 195.286943] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 195.286944] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 195.286945] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 195.286947] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 195.286948] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 195.286949] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 195.286950] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 195.286952] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 195.286953] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 195.286954] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 195.286956] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 195.286957] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 195.286958] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 195.286959] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 195.286960] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 195.286961] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 195.286963] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 195.286964] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 195.286965] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 195.286966] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 195.286967] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 195.286968] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 195.286970] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 195.286971] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 195.286972] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 195.286973] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 195.286974] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 195.287001] hm2/hm2_5i25.0: registered
[ 195.287003] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 195.395151] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 195.395154] hm2/hm2_5i25.0: unregistered
[ 195.395188] hm2_pci: driver unloaded
[ 195.396075] hm2: unloading
[ 197.443704] RTAI[math]: unloaded.
[ 197.444577] SCHED releases registered named ALIEN PEDV$D
[ 197.447581] RTAI[malloc]: unloaded.
[ 197.544838] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 197.545807] I-pipe: head domain RTAI unregistered.
[ 197.545842] RTAI[hal]: unmounted.
[ 260.243415] [Hardware Error]: Machine check events logged
[ 465.169115] I-pipe: head domain RTAI registered.
[ 465.169119] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 465.169146] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 465.169148] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 6235080, CLK_FREQ 3192841000, CPU_FREQ 3192841000
[ 465.169150] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 465.169152] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235080, 6235080, 5930500
[ 465.172393] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 465.172412] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 465.172414] RTAI[sched]: hard timer type/freq = APIC/6235080(Hz); default timing: oneshot; linear timed lists.
[ 465.172416] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3192841000 hz.
[ 465.172418] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 465.182149] RTAI[math]: loaded.
[ 465.223132] hm2: loading Mesa HostMot2 driver version 0.15
[ 465.224102] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 465.224245] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 465.224537] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 465.279561] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 465.279564] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 465.279566] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 465.279568] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 465.279569] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 465.279570] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 465.279572] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 465.279573] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 465.279574] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
[ 465.279575] hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
[ 465.279576] hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
[ 465.279578] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 465.279579] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 465.279580] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 465.279581] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 465.279583] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
[ 465.279584] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
[ 465.279586] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
[ 465.279587] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 465.279588] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 465.279589] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 465.279590] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 465.279592] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 465.279593] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 465.279594] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 465.279595] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 465.279596] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 465.279597] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 465.279599] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 465.279600] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 465.279601] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 465.279602] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 465.279603] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 465.279604] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 465.279606] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 465.279633] hm2/hm2_5i25.0: registered
[ 465.279634] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 465.390988] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 465.390991] hm2/hm2_5i25.0: unregistered
[ 465.391024] hm2_pci: driver unloaded
[ 465.391972] hm2: unloading
[ 467.443185] RTAI[math]: unloaded.
[ 467.444101] SCHED releases registered named ALIEN PEDV$D
[ 467.447248] RTAI[malloc]: unloaded.
[ 467.546453] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 467.547407] I-pipe: head domain RTAI unregistered.
[ 467.547442] RTAI[hal]: unmounted.
- Thank you received: 1369
17 Aug 2017 02:39 #97608
Replied by Todd Zuercher on topic LinuxCNC terminated with an error
The important info is here;
My guess is that you lost field power to the 7i76 board, so the io on the SmartSerial part of the card disappeared, and Linuxcnc can't find those hal pins.
Debug file information:
./Lathe.hal:27: Pin 'hm2_5i25.0.7i76.0.0.input-16' does not exist
4130
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
The following user(s) said Thank You: tml
18 Aug 2017 01:19 #97680
by tml
Replied by tml on topic LinuxCNC terminated with an error
Oh that makes sense. My 24V power supply was turned off... I didn't think to check that first. Thank you!
Time to create page: 0.107 seconds
