how to downgrade from 2.8.0 to 2.7.x?
- lumberjack_jeff
18 Sep 2017 00:21 #99069
by lumberjack_jeff
how to downgrade from 2.8.0 to 2.7.x? was created by lumberjack_jeff
2.8.0 pre1 3347-g9d99a30 linux cnc
3.4.9 - RTAI 686-PAE kernel
Debian Wheezy
Installed from with the live cd, somehow got updated to the master release. It's my production machine, and I'm chasing gremlins. Can you please help direct me in the right direction?
Debian Wheezy
- Thank you received: 1369
18 Sep 2017 01:52 #99070
Replied by Todd Zuercher on topic how to downgrade from 2.8.0 to 2.7.x?
Fist thing is to check your repository list and make sure that the one for 2.7-rt is checked and that the one for master-rt is unchecked. Then using synaptic force the version of Linuxcnc to the latest 2.7 version.
If you had a working config before you updated to Master you will need to restore it. Once you have reverted to version 2.7, then you will need to restore your old configuration. Master tries to convert an older config to the new JA system automatically the first time you try to run it. The old config files are saved in a backup directory in the config directory. Restoring those files to their original location should return the config to what it was.
Time to create page: 0.090 seconds
