Moving setup-files to another computer
08 Oct 2017 21:09 #100097
by Stonefire
Moving setup-files to another computer was created by Stonefire
Hi
Newbie need help to move setup to another computer.
My old computer with ver2.6 was to slow. So I've got a new and installed ver2.7, but how do I move my setup to the new computer ?
Sincerly
Steen
Sincerly
Steen
- Thank you received: 1369
09 Oct 2017 01:50 #100104
Replied by Todd Zuercher on topic Moving setup-files to another computer
I'd start by copying the "linuxcnc" folder in your home directory from your old computer to your new one. That should move all of your old configuration files from the old to new.
There are also a couple of minor changes that may need to be made to your hal files. They are coverd here.
linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
The following user(s) said Thank You: Tchefter
09 Oct 2017 07:29 #100112
by Stonefire
Replied by Stonefire on topic Moving setup-files to another computer
Hi Todd
Thanks!
!'ll try that...
Sincerly
Stonefire
Thanks!
!'ll try that...
Sincerly
Stonefire
10 Oct 2017 14:38 #100143
by Stonefire
Hi Todd
That went ok, but now my x- and Y-axis is turneded around, and I can't recall how to change it. I'ts is more than 3 years since I set my cnc up...
Sincerly
Sincerly
10 Oct 2017 14:48 #100144
X and Y switched or just moving the wrong way?
There are lots of ways to change these, and the simplest solution will depend on how your machine is configured.
To change the direction of a step/dir config, you can usually just invert the dir pin.
10 Oct 2017 15:08 #100148
by Stonefire
Also got this error:
RTAPI:ERROR: Unexpected realtimedelay on task 1...
10 Oct 2017 15:11 #100149
by Stonefire
both - I belive I did it once in one of the config-files, but can't recall wich one....
Sincerly
Sincerly
10 Oct 2017 17:35 #100156
If you have more than one config file, then the one that is right is probably still there, keep trying different ones until you find the one that is right.
(If you look at file dates it is probably the newest one.)
10 Oct 2017 18:02 #100157
by Stonefire
Thanks, but is it a ini or a hal-file ? do you know ?
Sincerly
Sincerly
10 Oct 2017 18:57 #100160
by Stonefire
Hi Todd
Got it all working again, except the strange Rtapi-error
Sincerly
Sincerly
Time to create page: 0.170 seconds
