- General
- Installing LinuxCNC
- Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
13 May 2018 15:16 - 13 May 2018 15:17 #110678
by punking
I recently thought I try updating my set up.
I updated from ubuntu ( 12.04) on the internet (not from a usb stick) all went nominal.
commented out
#loadrt probe_parport
-and-
#addf hm2_5i25.0.pet_watchdog servo-thread
from my Hal file per the update instructions - linuxcnc.org/docs/2.7/html/getting-start..._configuration_files
It starts up and the banner with the version shows on desktop but hangs there indefinitely.
I kill the process off , go to start again and it says linuxcnc is already running.
I really don't know if this version is too incompatible with my machine or not.
I've run 2.6 for about 4 years flawlessly.
BTW may mill is a supermax taht had an old anilam controllor in it. i reused all the glass slides and servo drives. the computer is amd processor on a gigabyte MB GA-MA78GM with radeon onboard video. It has been running fine for years.
maybe I need to configure something more, I don't know...
any help is appreciated
commented out
-and-
Last edit: 13 May 2018 15:17 by punking. Reason: added clarity
13 May 2018 17:09 - 13 May 2018 17:10 #110689
Replied by PCW on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
I would try a couple things to determine what's going on before going back to 2.6
1. Can you start LinuxCNC from the command line so you can capture any error messages
2. if this is s RTAI based distribution (likely) can you post the kernel log here:
to do this you clear the log , run linuxcnc and then look at any pertinent error messages in the log
( do this in a terminal window )
sudo dmesg -c (clears the log)
linuxcnc (run linuxcnc)
dmesg > log.txt (copy the kernel log to a file)
and then post log.txt here
Note that when LinuxCNC hangs and does not fully exit for any reason you need to execute
halrun -U
to remove any hung bits of LinuxCNC
Many times this does not work and you will need to reboot the computer to try again
halrun -U
Last edit: 13 May 2018 17:10 by PCW.
13 May 2018 17:58 #110691
by punking
Replied by punking on topic Linuxcnc 2.7 is "bricking" my computer, any way to rollback update to 2.6?
OK , Thank you for the assistance.
here is the log:
here is the log:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000cfee0000 (usable)
[ 0.000000] BIOS-e820: 00000000cfee0000 - 00000000cfee3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000cfee3000 - 00000000cfef0000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000cfef0000 - 00000000cff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000128000000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. GA-MA74GM-S2/GA-MA74GM-S2, BIOS F1 04/17/2008
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xcfee0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 base 0000CFF00000 mask FFFFFFF00000 uncachable
[ 0.000000] 4 base 000100000000 mask FFFFE0000000 write-back
[ 0.000000] 5 base 000120000000 mask FFFFF8000000 write-back
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000128000000 aka 4736M
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000cff00000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00f5840] f5840
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363e0000 - 371e8000
[ 0.000000] 2438MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000cfee0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x000cfee0
[ 0.000000] On node 0 totalpages: 851567
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f49e0200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4878 pages used for memmap
[ 0.000000] HighMem zone: 619476 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] SFI: Simple Firmware Interface v0.81 http://simplefirmware.org
[ 0.000000] Intel MultiProcessor Specification v1.4
[ 0.000000] Virtual Wire compatibility mode.
[ 0.000000] MPTABLE: OEM ID: OEM00000
[ 0.000000] MPTABLE: Product ID: PROD00000000
[ 0.000000] MPTABLE: APIC at: 0xFEE00000
[ 0.000000] Processor #0 (Bootup-CPU)
[ 0.000000] Processor #1
[ 0.000000] IOAPIC[0]: apic_id 4, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] Processors: 2
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at cff00000 (gap: cff00000:10100000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77c9000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 844913
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=2adfb343-52e8-4903-9bbe-9889b806915a ro quiet splash acpi=off vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6813312 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000cfee0)
[ 0.000000] Memory: 3351748k/3406720k available (3496k kernel code, 54520k reserved, 1237k data, 416k init, 2497416k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] WARNING: Persistent clock returned invalid value!
[ 0.000000] Check your CMOS/BIOS settings.
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 2705.791 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5411.58 BogoMIPS (lpj=10823164)
[ 0.000005] pid_max: default: 32768 minimum: 301
[ 0.000043] Security Framework initialized
[ 0.000048] AppArmor: AppArmor disabled by boot time parameter
[ 0.000063] Mount-cache hash table entries: 512
[ 0.000223] Initializing cgroup subsys cpuacct
[ 0.000226] Initializing cgroup subsys memory
[ 0.000232] Initializing cgroup subsys devices
[ 0.000233] Initializing cgroup subsys freezer
[ 0.000235] Initializing cgroup subsys net_cls
[ 0.000237] Initializing cgroup subsys blkio
[ 0.000243] Initializing cgroup subsys perf_event
[ 0.000265] CPU: Physical Processor ID: 0
[ 0.000266] CPU: Processor Core ID: 0
[ 0.000269] mce: CPU supports 6 MCE banks
[ 0.000274] LVT offset 0 assigned for vector 0xf9
[ 0.000278] using AMD E400 aware idle routine
[ 0.000377] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000475] ExtINT not setup in hardware but reported by MP table
[ 0.000987] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.040628] CPU0: AMD Athlon(tm) 7750 Dual-Core Processor stepping 03
[ 0.253819] Performance Events: AMD PMU driver.
[ 0.253824] ... version: 0
[ 0.253825] ... bit width: 48
[ 0.253827] ... generic registers: 4
[ 0.253828] ... value mask: 0000ffffffffffff
[ 0.253830] ... max period: 00007fffffffffff
[ 0.253831] ... fixed-purpose events: 0
[ 0.253832] ... event mask: 000000000000000f
[ 0.265827] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.277811] CPU 1 irqstacks, hard=f3c74000 soft=f3c76000
[ 0.277813] Booting Node 0, Processors #1 Ok.
[ 0.287954] Initializing CPU#1
[ 0.290842] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.290868] Brought up 2 CPUs
[ 0.290871] Total of 2 processors activated (10823.16 BogoMIPS).
[ 0.292254] devtmpfs: initialized
[ 0.292505] PM: Registering ACPI NVS region [mem 0xcfee0000-0xcfee2fff] (12288 bytes)
[ 0.292609] dummy:
[ 0.292668] NET: Registered protocol family 16
[ 0.292740] node 0 link 0: io port [c000, ffff]
[ 0.292743] TOM: 00000000d8000000 aka 3456M
[ 0.292746] Fam 10h mmconf [mem 0xe0000000-0xe00fffff]
[ 0.292748] node 0 link 0: mmio [a0000, bffff]
[ 0.292751] node 0 link 0: mmio [d8000000, dfffffff]
[ 0.292754] node 0 link 0: mmio [e0000000, fe02ffff] ==> [e0100000, fe02ffff]
[ 0.292758] node 0 link 0: mmio [e0000000, efffffff] ==> [e0100000, efffffff]
[ 0.292761] TOM2: 0000000128000000 aka 4736M
[ 0.292763] bus: [00, 03] on node 0 link 0
[ 0.292765] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.292767] bus: 00 index 1 [mem 0x000a0000-0x000bffff]
[ 0.292769] bus: 00 index 2 [mem 0xd8000000-0xdfffffff]
[ 0.292771] bus: 00 index 3 [mem 0xe0100000-0xffffffff]
[ 0.294107] PCI: PCI BIOS revision 3.00 entry at 0xfb810, last bus=3
[ 0.294109] PCI: Using configuration type 1 for base access
[ 0.294110] PCI: Using configuration type 1 for extended access
[ 0.294657] bio: create slab <bio-0> at 0
[ 0.294748] ACPI: Interpreter disabled.
[ 0.294800] vgaarb: loaded
[ 0.294821] PCI: Probing PCI hardware
[ 0.294824] PCI: Probing PCI hardware (bus 00)
[ 0.294825] PCI: root bus 00: hardware-probed resources
[ 0.294850] PCI host bridge to bus 0000:00
[ 0.294852] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.294855] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.294857] pci_bus 0000:00: root bus resource [mem 0xd8000000-0xdfffffff]
[ 0.294859] pci_bus 0000:00: root bus resource [mem 0xe0100000-0xffffffff]
[ 0.294869] pci 0000:00:00.0: [1002:7911] type 00 class 0x060000
[ 0.294895] pci 0000:00:01.0: [1002:7912] type 01 class 0x060400
[ 0.294930] pci 0000:00:06.0: [1002:7916] type 01 class 0x060400
[ 0.294956] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.294992] pci 0000:00:11.0: [1002:4390] type 00 class 0x01018f
[ 0.295015] pci 0000:00:11.0: reg 10: [io 0xff00-0xff07]
[ 0.295025] pci 0000:00:11.0: reg 14: [io 0xfe00-0xfe03]
[ 0.295035] pci 0000:00:11.0: reg 18: [io 0xfd00-0xfd07]
[ 0.295046] pci 0000:00:11.0: reg 1c: [io 0xfc00-0xfc03]
[ 0.295056] pci 0000:00:11.0: reg 20: [io 0xfb00-0xfb0f]
[ 0.295066] pci 0000:00:11.0: reg 24: [mem 0xfe02f000-0xfe02f3ff]
[ 0.295088] pci 0000:00:11.0: set SATA to AHCI mode
[ 0.295130] pci 0000:00:12.0: [1002:4397] type 00 class 0x0c0310
[ 0.295144] pci 0000:00:12.0: reg 10: [mem 0xfe02e000-0xfe02efff]
[ 0.295210] pci 0000:00:12.1: [1002:4398] type 00 class 0x0c0310
[ 0.295224] pci 0000:00:12.1: reg 10: [mem 0xfe02d000-0xfe02dfff]
[ 0.295296] pci 0000:00:12.2: [1002:4396] type 00 class 0x0c0320
[ 0.295316] pci 0000:00:12.2: reg 10: [mem 0xfe02c000-0xfe02c0ff]
[ 0.295390] pci 0000:00:12.2: supports D1 D2
[ 0.295392] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.295416] pci 0000:00:13.0: [1002:4397] type 00 class 0x0c0310
[ 0.295430] pci 0000:00:13.0: reg 10: [mem 0xfe02b000-0xfe02bfff]
[ 0.295496] pci 0000:00:13.1: [1002:4398] type 00 class 0x0c0310
[ 0.295510] pci 0000:00:13.1: reg 10: [mem 0xfe02a000-0xfe02afff]
[ 0.295583] pci 0000:00:13.2: [1002:4396] type 00 class 0x0c0320
[ 0.295603] pci 0000:00:13.2: reg 10: [mem 0xfe029000-0xfe0290ff]
[ 0.295676] pci 0000:00:13.2: supports D1 D2
[ 0.295678] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.295706] pci 0000:00:14.0: [1002:4385] type 00 class 0x0c0500
[ 0.295802] pci 0000:00:14.1: [1002:439c] type 00 class 0x01018a
[ 0.295819] pci 0000:00:14.1: reg 10: [io 0x0000-0x0007]
[ 0.295829] pci 0000:00:14.1: reg 14: [io 0x0000-0x0003]
[ 0.295839] pci 0000:00:14.1: reg 18: [io 0x0000-0x0007]
[ 0.295849] pci 0000:00:14.1: reg 1c: [io 0x0000-0x0003]
[ 0.295859] pci 0000:00:14.1: reg 20: [io 0xfa00-0xfa0f]
[ 0.295911] pci 0000:00:14.2: [1002:4383] type 00 class 0x040300
[ 0.295934] pci 0000:00:14.2: reg 10: [mem 0xfe024000-0xfe027fff 64bit]
[ 0.295995] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.296010] pci 0000:00:14.3: [1002:439d] type 00 class 0x060100
[ 0.296090] pci 0000:00:14.4: [1002:4384] type 01 class 0x060401
[ 0.296132] pci 0000:00:14.5: [1002:4399] type 00 class 0x0c0310
[ 0.296146] pci 0000:00:14.5: reg 10: [mem 0xfe028000-0xfe028fff]
[ 0.296216] pci 0000:00:18.0: [1022:1200] type 00 class 0x060000
[ 0.296232] pci 0000:00:18.1: [1022:1201] type 00 class 0x060000
[ 0.296246] pci 0000:00:18.2: [1022:1202] type 00 class 0x060000
[ 0.296261] pci 0000:00:18.3: [1022:1203] type 00 class 0x060000
[ 0.296278] pci 0000:00:18.4: [1022:1204] type 00 class 0x060000
[ 0.296318] pci 0000:01:05.0: [1002:796e] type 00 class 0x030000
[ 0.296328] pci 0000:01:05.0: reg 10: [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.296335] pci 0000:01:05.0: reg 18: [mem 0xfdff0000-0xfdffffff 64bit]
[ 0.296340] pci 0000:01:05.0: reg 20: [io 0xee00-0xeeff]
[ 0.296345] pci 0000:01:05.0: reg 24: [mem 0xfde00000-0xfdefffff]
[ 0.296357] pci 0000:01:05.0: supports D1 D2
[ 0.296371] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.296375] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.296378] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdffffff]
[ 0.296381] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.296419] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.296433] pci 0000:02:00.0: reg 10: [io 0xde00-0xdeff]
[ 0.296455] pci 0000:02:00.0: reg 18: [mem 0xfdaff000-0xfdafffff 64bit pref]
[ 0.296469] pci 0000:02:00.0: reg 20: [mem 0xfdae0000-0xfdaeffff 64bit pref]
[ 0.296479] pci 0000:02:00.0: reg 30: [mem 0x00000000-0x0000ffff pref]
[ 0.296509] pci 0000:02:00.0: supports D1 D2
[ 0.296511] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.301783] pci 0000:00:06.0: PCI bridge to [bus 02-02]
[ 0.301787] pci 0000:00:06.0: bridge window [io 0xd000-0xdfff]
[ 0.301789] pci 0000:00:06.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.301793] pci 0000:00:06.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.301824] pci 0000:03:07.0: [2718:5125] type 00 class 0x110000
[ 0.301842] pci 0000:03:07.0: reg 10: [mem 0xfdcf0000-0xfdcfffff]
[ 0.301956] pci 0000:00:14.4: PCI bridge to [bus 03-03] (subtractive decode)
[ 0.301960] pci 0000:00:14.4: bridge window [io 0xc000-0xcfff]
[ 0.301965] pci 0000:00:14.4: bridge window [mem 0xfdc00000-0xfdcfffff]
[ 0.301969] pci 0000:00:14.4: bridge window [mem 0xfdb00000-0xfdbfffff pref]
[ 0.301971] pci 0000:00:14.4: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.301974] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.301976] pci 0000:00:14.4: bridge window [mem 0xd8000000-0xdfffffff] (subtractive decode)
[ 0.301978] pci 0000:00:14.4: bridge window [mem 0xe0100000-0xffffffff] (subtractive decode)
[ 0.302354] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.302826] PCI: pci_cache_line_size set to 64 bytes
[ 0.302898] Expanded resource reserved due to conflict with PCI Bus #00
[ 0.302901] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.302903] reserve RAM buffer: 00000000cfee0000 - 00000000cfffffff
[ 0.303066] pnp: PnP ACPI: disabled
[ 0.303069] PnPBIOS: Scanning system for PnP BIOS support...
[ 0.303334] PnPBIOS: Found PnP BIOS installation structure at 0xc00fc360
[ 0.303340] PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xc390, dseg 0xf0000
[ 0.303372] pnp 00:00: [irq 2]
[ 0.303374] pnp 00:00: [io 0x0020-0x0021]
[ 0.303376] pnp 00:00: [io 0x00a0-0x00a1]
[ 0.303392] pnp 00:00: Plug and Play BIOS device, IDs PNP0000 (active)
[ 0.303412] pnp 00:01: [dma 4]
[ 0.303414] pnp 00:01: [io 0x0000-0x000f]
[ 0.303416] pnp 00:01: [io 0x0081-0x0083]
[ 0.303417] pnp 00:01: [io 0x0087]
[ 0.303419] pnp 00:01: [io 0x0089-0x008b]
[ 0.303421] pnp 00:01: [io 0x008f-0x0091]
[ 0.303423] pnp 00:01: [io 0x00c0-0x00df]
[ 0.303436] pnp 00:01: Plug and Play BIOS device, IDs PNP0200 (active)
[ 0.303449] pnp 00:02: [irq 0]
[ 0.303450] pnp 00:02: [io 0x0040-0x0043]
[ 0.303463] pnp 00:02: Plug and Play BIOS device, IDs PNP0100 (active)
[ 0.303477] pnp 00:03: [irq 8]
[ 0.303479] pnp 00:03: [io 0x0070-0x0071]
[ 0.303491] pnp 00:03: Plug and Play BIOS device, IDs PNP0b00 (active)
[ 0.303510] pnp 00:04: [irq 1]
[ 0.303511] pnp 00:04: [io 0x0060]
[ 0.303513] pnp 00:04: [io 0x0064]
[ 0.303528] pnp 00:04: Plug and Play BIOS device, IDs PNP0303 (active)
[ 0.303542] pnp 00:05: [io 0x0061]
[ 0.303554] pnp 00:05: Plug and Play BIOS device, IDs PNP0800 (active)
[ 0.303568] pnp 00:06: [irq 13]
[ 0.303570] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.303584] pnp 00:06: Plug and Play BIOS device, IDs PNP0c04 (active)
[ 0.303608] pnp 00:07: [mem 0x00000000-0x0009ffff]
[ 0.303610] pnp 00:07: [mem 0xfffe0000-0xffffffff]
[ 0.303612] pnp 00:07: [mem 0xfff80000-0xfffdffff]
[ 0.303614] pnp 00:07: [mem 0xfec00000-0xfec0ffff]
[ 0.303616] pnp 00:07: [mem 0xfee00000-0xfee0ffff]
[ 0.303618] pnp 00:07: [mem 0x00100000-0xcfefffff disabled]
[ 0.303651] system 00:07: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.303654] system 00:07: [mem 0xfffe0000-0xffffffff] has been reserved
[ 0.303657] system 00:07: [mem 0xfff80000-0xfffdffff] has been reserved
[ 0.303660] system 00:07: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.303663] system 00:07: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.303666] system 00:07: Plug and Play BIOS device, IDs PNP0c01 (active)
[ 0.303685] pnp 00:08: [mem 0x000f0000-0x000f3fff]
[ 0.303687] pnp 00:08: [mem 0x000f4000-0x000f7fff]
[ 0.303689] pnp 00:08: [mem 0x000f8000-0x000fffff]
[ 0.303691] pnp 00:08: [mem 0x000cd800-0x000cffff]
[ 0.303720] system 00:08: [mem 0x000f0000-0x000f3fff] could not be reserved
[ 0.303723] system 00:08: [mem 0x000f4000-0x000f7fff] could not be reserved
[ 0.303725] system 00:08: [mem 0x000f8000-0x000fffff] could not be reserved
[ 0.303727] system 00:08: [mem 0x000cd800-0x000cffff] has been reserved
[ 0.303730] system 00:08: Plug and Play BIOS device, IDs PNP0c02 (active)
[ 0.303748] pnp 00:09: [io 0x0290-0x029f]
[ 0.303750] pnp 00:09: [io 0x04d0-0x04d1]
[ 0.303752] pnp 00:09: [io 0x0cf8-0x0cff]
[ 0.303765] pnp 00:09: Plug and Play BIOS device, IDs PNP0a03 (active)
[ 0.303833] pnp 00:0b: [irq 4]
[ 0.303835] pnp 00:0b: [io 0x03f8-0x03ff]
[ 0.303856] pnp 00:0b: Plug and Play BIOS device, IDs PNP0501 (active)
[ 0.303907] pnp 00:0c: [dma 2]
[ 0.303908] pnp 00:0c: [io 0x03f0-0x03f5]
[ 0.303911] pnp 00:0c: [io 0x03f7]
[ 0.303913] pnp 00:0c: [irq 6]
[ 0.303930] pnp 00:0c: Plug and Play BIOS device, IDs PNP0700 (active)
[ 0.304011] pnp 00:0d: [irq 7]
[ 0.304013] pnp 00:0d: [io 0x0378-0x037f]
[ 0.304014] pnp 00:0d: [io 0x0778-0x077f]
[ 0.304038] pnp 00:0d: Plug and Play BIOS device, IDs PNP0400 (active)
[ 0.304041] PnPBIOS: 13 nodes reported by PnP BIOS; 13 recorded by driver
[ 0.305657] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.305660] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.305663] pci 0000:00:01.0: bridge window [mem 0xfde00000-0xfdffffff]
[ 0.305667] pci 0000:00:01.0: bridge window [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.305672] pci 0000:02:00.0: BAR 6: assigned [mem 0xfda00000-0xfda0ffff pref]
[ 0.305675] pci 0000:00:06.0: PCI bridge to [bus 02-02]
[ 0.305677] pci 0000:00:06.0: bridge window [io 0xd000-0xdfff]
[ 0.305680] pci 0000:00:06.0: bridge window [mem 0xfdd00000-0xfddfffff]
[ 0.305683] pci 0000:00:06.0: bridge window [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.305687] pci 0000:00:14.4: PCI bridge to [bus 03-03]
[ 0.305690] pci 0000:00:14.4: bridge window [io 0xc000-0xcfff]
[ 0.305695] pci 0000:00:14.4: bridge window [mem 0xfdc00000-0xfdcfffff]
[ 0.305699] pci 0000:00:14.4: bridge window [mem 0xfdb00000-0xfdbfffff pref]
[ 0.305719] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.305722] pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.305724] pci_bus 0000:00: resource 6 [mem 0xd8000000-0xdfffffff]
[ 0.305726] pci_bus 0000:00: resource 7 [mem 0xe0100000-0xffffffff]
[ 0.305729] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.305731] pci_bus 0000:01: resource 1 [mem 0xfde00000-0xfdffffff]
[ 0.305734] pci_bus 0000:01: resource 2 [mem 0xd8000000-0xdfffffff 64bit pref]
[ 0.305736] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.305738] pci_bus 0000:02: resource 1 [mem 0xfdd00000-0xfddfffff]
[ 0.305740] pci_bus 0000:02: resource 2 [mem 0xfda00000-0xfdafffff 64bit pref]
[ 0.305742] pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
[ 0.305745] pci_bus 0000:03: resource 1 [mem 0xfdc00000-0xfdcfffff]
[ 0.305747] pci_bus 0000:03: resource 2 [mem 0xfdb00000-0xfdbfffff pref]
[ 0.305749] pci_bus 0000:03: resource 4 [io 0x0000-0xffff]
[ 0.305751] pci_bus 0000:03: resource 5 [mem 0x000a0000-0x000bffff]
[ 0.305753] pci_bus 0000:03: resource 6 [mem 0xd8000000-0xdfffffff]
[ 0.305755] pci_bus 0000:03: resource 7 [mem 0xe0100000-0xffffffff]
[ 0.305824] NET: Registered protocol family 2
[ 0.305874] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.306029] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.306428] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.306638] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.306640] TCP: reno registered
[ 0.306643] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.306650] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.306726] NET: Registered protocol family 1
[ 0.306757] pci 0000:00:12.0: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 0.389706] pci 0000:00:12.1: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 0.473620] pci 0000:00:12.2: PCI->APIC IRQ transform: INT B -> IRQ 17
[ 0.473655] pci 0000:00:13.0: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 0.557514] pci 0000:00:13.1: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 0.641429] pci 0000:00:13.2: PCI->APIC IRQ transform: INT B -> IRQ 19
[ 0.641470] pci 0000:00:14.5: PCI->APIC IRQ transform: INT C -> IRQ 18
[ 0.725322] pci 0000:01:05.0: Boot video device
[ 0.725333] PCI: CLS 4 bytes, default 64
[ 0.725384] Unpacking initramfs...
[ 0.988529] Freeing initrd memory: 14368k freed
[ 0.994200] LVT offset 1 assigned for vector 0x400
[ 0.994212] IBS: LVT offset 1 assigned
[ 0.994224] perf: AMD IBS detected (0x00000007)
[ 0.994404] audit: initializing netlink socket (disabled)
[ 0.994419] type=2000 audit(0.852:1): initialized
[ 1.004718] highmem bounce pool size: 64 pages
[ 1.004723] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.004902] VFS: Disk quotas dquot_6.5.2
[ 1.004929] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.004999] msgmni has been set to 1696
[ 1.005150] alg: No test for stdrng (krng)
[ 1.005179] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.005182] io scheduler noop registered
[ 1.005184] io scheduler deadline registered
[ 1.005206] io scheduler cfq registered (default)
[ 1.005310] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.005324] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.005326] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.005364] vesafb: mode is 1280x1024x32, linelength=5120, pages=0
[ 1.005366] vesafb: scrolling: redraw
[ 1.005368] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 1.005748] vesafb: framebuffer at 0xd8000000, mapped to 0xf8000000, using 5120k, total 5120k
[ 1.005788] fbcon: VESA VGA (fb0) is primary device
[ 1.150615] Console: switching to colour frame buffer device 160x64
[ 1.295380] fb0: VESA VGA frame buffer device
[ 1.295433] isapnp: Scanning for PnP cards...
[ 1.605438] isapnp: No Plug & Play device found
[ 1.605482] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.625917] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.646584] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.646726] Linux agpgart interface v0.103
[ 1.647035] i8042: PNP: PS/2 Controller [PNP0303] at 0x60,0x64 irq 1
[ 1.647037] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.647196] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.647291] mousedev: PS/2 mouse device common for all mice
[ 1.647417] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 1.647445] rtc0: alarms up to one day, 114 bytes nvram
[ 1.647549] TCP: cubic registered
[ 1.647606] NET: Registered protocol family 10
[ 1.647786] Mobile IPv6
[ 1.647788] NET: Registered protocol family 17
[ 1.647792] Registering the dns_resolver key type
[ 1.647829] Using IPI No-Shortcut mode
[ 1.647904] PM: Hibernation image not present or could not be loaded.
[ 1.647916] registered taskstats version 1
[ 1.648180] rtc_cmos 00:03: setting system clock to 2044-09-20 05:49:19 UTC (2357963359)
[ 1.648272] Freeing unused kernel memory: 416k freed
[ 1.648496] Write protecting the kernel text: 3500k
[ 1.648515] Write protecting the kernel read-only data: 980k
[ 1.662712] udevd[55]: starting version 175
[ 1.670589] SCSI subsystem initialized
[ 1.670930] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.675475] usbcore: registered new interface driver usbfs
[ 1.675497] usbcore: registered new interface driver hub
[ 1.694284] libata version 3.00 loaded.
[ 1.694310] usbcore: registered new device driver usb
[ 1.701932] ahci 0000:00:11.0: version 3.0
[ 1.701955] ahci 0000:00:11.0: PCI->APIC IRQ transform: INT A -> IRQ 22
[ 1.702065] ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 1.702070] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
[ 1.703006] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.708461] scsi0 : ahci
[ 1.709880] scsi1 : ahci
[ 1.710006] scsi2 : ahci
[ 1.710113] scsi3 : ahci
[ 1.710157] ata1: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f100 irq 22
[ 1.710161] ata2: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f180 irq 22
[ 1.710165] ata3: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f200 irq 22
[ 1.710169] ata4: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f280 irq 22
[ 1.710237] ehci_hcd 0000:00:12.2: PCI->APIC IRQ transform: INT B -> IRQ 17
[ 1.710266] ehci_hcd 0000:00:12.2: EHCI Host Controller
[ 1.710292] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.710302] ehci_hcd 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.710327] QUIRK: Enable AMD PLL fix
[ 1.710330] ehci_hcd 0000:00:12.2: applying AMD SB600/SB700 USB freeze workaround
[ 1.710345] ehci_hcd 0000:00:12.2: debug port 1
[ 1.710371] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfe02c000
[ 1.713727] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.720166] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.720194] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.720197] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.720199] usb usb1: Product: EHCI Host Controller
[ 1.720201] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.720203] usb usb1: SerialNumber: 0000:00:12.2
[ 1.720309] hub 1-0:1.0: USB hub found
[ 1.720313] hub 1-0:1.0: 6 ports detected
[ 1.720414] ehci_hcd 0000:00:13.2: PCI->APIC IRQ transform: INT B -> IRQ 19
[ 1.720439] ehci_hcd 0000:00:13.2: EHCI Host Controller
[ 1.720449] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[ 1.720458] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.720474] ehci_hcd 0000:00:13.2: applying AMD SB600/SB700 USB freeze workaround
[ 1.720489] ehci_hcd 0000:00:13.2: debug port 1
[ 1.720515] ehci_hcd 0000:00:13.2: irq 19, io mem 0xfe029000
[ 1.732157] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.732183] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.732186] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.732188] usb usb2: Product: EHCI Host Controller
[ 1.732190] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.732192] usb usb2: SerialNumber: 0000:00:13.2
[ 1.732296] hub 2-0:1.0: USB hub found
[ 1.732301] hub 2-0:1.0: 6 ports detected
[ 1.732418] pata_atiixp 0000:00:14.1: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 1.732753] scsi4 : pata_atiixp
[ 1.732818] scsi5 : pata_atiixp
[ 1.732865] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfa00 irq 14
[ 1.732868] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfa08 irq 15
[ 1.733034] ohci_hcd 0000:00:12.0: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 1.733062] ohci_hcd 0000:00:12.0: OHCI Host Controller
[ 1.733073] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 3
[ 1.733107] ohci_hcd 0000:00:12.0: irq 16, io mem 0xfe02e000
[ 1.793163] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.793165] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.793168] usb usb3: Product: OHCI Host Controller
[ 1.793170] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.793171] usb usb3: SerialNumber: 0000:00:12.0
[ 1.793277] hub 3-0:1.0: USB hub found
[ 1.793284] hub 3-0:1.0: 3 ports detected
[ 1.793359] ohci_hcd 0000:00:12.1: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 1.793374] ohci_hcd 0000:00:12.1: OHCI Host Controller
[ 1.793380] ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 4
[ 1.793395] ohci_hcd 0000:00:12.1: irq 16, io mem 0xfe02d000
[ 1.853088] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.853091] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.853093] usb usb4: Product: OHCI Host Controller
[ 1.853094] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.853096] usb usb4: SerialNumber: 0000:00:12.1
[ 1.853184] hub 4-0:1.0: USB hub found
[ 1.853190] hub 4-0:1.0: 3 ports detected
[ 1.853718] ohci_hcd 0000:00:13.0: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 1.853738] ohci_hcd 0000:00:13.0: OHCI Host Controller
[ 1.853746] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
[ 1.853774] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfe02b000
[ 1.917016] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.917018] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.917020] usb usb5: Product: OHCI Host Controller
[ 1.917022] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.917024] usb usb5: SerialNumber: 0000:00:13.0
[ 1.917120] hub 5-0:1.0: USB hub found
[ 1.917126] hub 5-0:1.0: 3 ports detected
[ 1.917633] ohci_hcd 0000:00:13.1: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 1.917653] ohci_hcd 0000:00:13.1: OHCI Host Controller
[ 1.917660] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 6
[ 1.917677] ohci_hcd 0000:00:13.1: irq 18, io mem 0xfe02a000
[ 1.976964] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.976967] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.976970] usb usb6: Product: OHCI Host Controller
[ 1.976971] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.976973] usb usb6: SerialNumber: 0000:00:13.1
[ 1.977081] hub 6-0:1.0: USB hub found
[ 1.977088] hub 6-0:1.0: 3 ports detected
[ 1.977616] ohci_hcd 0000:00:14.5: PCI->APIC IRQ transform: INT C -> IRQ 18
[ 1.977638] ohci_hcd 0000:00:14.5: OHCI Host Controller
[ 1.977649] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 7
[ 1.977668] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfe028000
[ 1.995852] Switching to clocksource tsc
[ 2.031826] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.031889] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.032904] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.035858] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.035860] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.035862] usb usb7: Product: OHCI Host Controller
[ 2.035864] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 2.035866] usb usb7: SerialNumber: 0000:00:14.5
[ 2.035963] hub 7-0:1.0: USB hub found
[ 2.035969] hub 7-0:1.0: 2 ports detected
[ 2.203612] ata1: softreset failed (device not ready)
[ 2.204441] ata1: applying PMP SRST workaround and retrying
[ 2.244641] usb 3-2: new low-speed USB device number 2 using ohci_hcd
[ 2.375426] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.376345] ata1.00: ATA-9: CT120BX100SSD1, MU01, max UDMA/133
[ 2.376348] ata1.00: 234441648 sectors, multi 2: LBA48 NCQ (depth 31/32), AA
[ 2.376543] ata1.00: configured for UDMA/133
[ 2.376666] scsi 0:0:0:0: Direct-Access ATA CT120BX100SSD1 MU01 PQ: 0 ANSI: 5
[ 2.377335] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 2.377350] r8169 0000:02:00.0: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 2.377532] r8169 0000:02:00.0: eth0: RTL8168c/8111c at 0xf8556000, 00:1f:d0:9e:f9:76, XID 1c4000c0 IRQ 18
[ 2.377535] r8169 0000:02:00.0: eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko]
[ 2.384640] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 2.384694] sd 0:0:0:0: [sda] Write Protect is off
[ 2.384697] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.384714] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.385276] sda: sda1 sda2 < sda5 >
[ 2.385579] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.406493] usb 3-2: New USB device found, idVendor=046d, idProduct=c077
[ 2.406497] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.406501] usb 3-2: Product: USB Optical Mouse
[ 2.406503] usb 3-2: Manufacturer: Logitech
[ 2.414639] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb3/3-2/3-2:1.0/input/input1
[ 2.414759] generic-usb 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:12.0-2/input0
[ 2.414782] usbcore: registered new interface driver usbhid
[ 2.414784] usbhid: USB HID core driver
[ 2.417341] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 2.417344] EXT4-fs (sda1): write access will be enabled during recovery
[ 2.493166] EXT4-fs (sda1): orphan cleanup on readonly fs
[ 2.493175] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 3685197
[ 2.493251] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 3684392
[ 2.493290] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 3685171
[ 2.493306] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 3685170
[ 2.493336] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 6029429
[ 2.493345] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 6029427
[ 2.493353] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 6029424
[ 2.493362] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 6029383
[ 2.493370] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4728748
[ 2.493410] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4728745
[ 2.493424] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4725813
[ 2.493440] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4725807
[ 2.493453] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4725801
[ 2.493467] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4725800
[ 2.493481] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 4725625
[ 2.493493] EXT4-fs (sda1): 15 orphan inodes deleted
[ 2.493495] EXT4-fs (sda1): recovery complete
[ 2.499801] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 2.606722] init: ureadahead main process (222) terminated with status 5
[ 2.664295] Adding 1046524k swap on /dev/sda5. Priority:-1 extents:1 across:1046524k SS
[ 2.713616] udevd[300]: starting version 175
[ 2.741920] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 2.762282] lp: driver loaded but no devices found
[ 2.814470] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 2.890459] ACPI Exception: AE_BAD_PARAMETER, Thread 4141562688 could not acquire Mutex [0x1] (20120320/utmutex-276)
[ 2.890474] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.891747] ppdev: user-space parallel port driver
[ 2.895022] parport_pc 00:0d: reported by Plug and Play BIOS
[ 2.895085] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 2.904167] k10temp 0000:00:18.3: unreliable CPU thermal sensor; monitoring disabled
[ 2.910917] Bluetooth: Core ver 2.16
[ 2.910937] NET: Registered protocol family 31
[ 2.910939] Bluetooth: HCI device and connection manager initialized
[ 2.910941] Bluetooth: HCI socket layer initialized
[ 2.910943] Bluetooth: L2CAP socket layer initialized
[ 2.910947] Bluetooth: SCO socket layer initialized
[ 2.923772] Bluetooth: RFCOMM TTY layer initialized
[ 2.923780] Bluetooth: RFCOMM socket layer initialized
[ 2.923782] Bluetooth: RFCOMM ver 1.11
[ 2.971936] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.971940] Bluetooth: BNEP filters: protocol multicast
[ 2.972283] [drm] Initialized drm 1.1.0 20060810
[ 2.995925] lp0: using parport0 (interrupt-driven).
[ 3.024939] NET: Registered protocol family 4
[ 3.027040] microcode: CPU0: patch_level=0x01000065
[ 3.038523] NET: Registered protocol family 5
[ 3.059240] udevd[398]: renamed network interface eth0 to eth2
[ 3.068143] [drm] radeon defaulting to kernel modesetting.
[ 3.068145] [drm] radeon kernel modesetting enabled.
[ 3.068208] checking generic (d8000000 500000) vs hw (d8000000 8000000)
[ 3.068209] fb: conflicting fb hw usage radeondrmfb vs VESA VGA - removing generic driver
[ 3.112866] microcode: failed to load file amd-ucode/microcode_amd.bin
[ 3.112876] microcode: CPU1: patch_level=0x01000065
[ 3.118966] microcode: failed to load file amd-ucode/microcode_amd.bin
[ 3.119257] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 3.150942] snd_hda_intel 0000:00:14.2: PCI->APIC IRQ transform: INT A -> IRQ 16
[ 3.230181] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:14.2/input/input2
[ 3.250327] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input3
[ 3.255618] input: HDA ATI SB Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input4
[ 3.255740] input: HDA ATI SB Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input5
[ 3.255866] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input6
[ 3.255988] input: HDA ATI SB Line Out as /devices/pci0000:00/0000:00:14.2/sound/card0/input7
[ 3.339577] Console: switching to colour dummy device 80x25
[ 3.343634] radeon 0000:01:05.0: PCI->APIC IRQ transform: INT A -> IRQ 18
[ 3.344171] [drm] initializing kernel modesetting (RS740 0x1002:0x796E 0x1458:0xD000).
[ 3.344201] [drm] register mmio base: 0xFDFF0000
[ 3.344203] [drm] register mmio size: 65536
[ 3.347269] ATOM BIOS: ATI
[ 3.347284] radeon 0000:01:05.0: VRAM: 128M 0x00000000D0000000 - 0x00000000D7FFFFFF (128M used)
[ 3.347288] radeon 0000:01:05.0: GTT: 512M 0x00000000A0000000 - 0x00000000BFFFFFFF
[ 3.348510] [drm] Detected VRAM RAM=128M, BAR=128M
[ 3.353456] [drm] RAM width 128bits DDR
[ 3.359182] [TTM] Zone kernel: Available graphics memory: 434558 kiB
[ 3.359186] [TTM] Zone highmem: Available graphics memory: 1683266 kiB
[ 3.359190] [TTM] Initializing pool allocator
[ 3.359217] [drm] radeon: 128M of VRAM memory ready
[ 3.359219] [drm] radeon: 512M of GTT memory ready.
[ 3.359237] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 3.414694] init: failsafe main process (690) killed by TERM signal
[ 3.464787] [drm] radeon: ib pool ready.
[ 3.465888] [drm] radeon: 1 quad pipes, 1 z pipes initialized.
[ 3.487018] [drm] PCIE GART of 512M enabled (table at 0x0000000033100000).
[ 3.487043] radeon 0000:01:05.0: WB enabled
[ 3.487046] [drm] fence driver on ring 0 use gpu addr 0xa0000000 and cpu addr 0xf6ba1000
[ 3.487050] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 3.487052] [drm] Driver supports precise vblank timestamp query.
[ 3.487064] [drm] radeon: irq initialized.
[ 3.489903] [drm] Loading RS690/RS740 Microcode
[ 3.495417] [drm] radeon: ring at 0x00000000A0001000
[ 3.495436] [drm] ring test succeeded in 1 usecs
[ 3.496213] [drm] ib test succeeded in 0 usecs
[ 3.499794] [drm] Radeon Display Connectors
[ 3.499798] [drm] Connector 0:
[ 3.499800] [drm] VGA
[ 3.499803] [drm] DDC: 0x7e50 0x7e40 0x7e54 0x7e44 0x7e58 0x7e48 0x7e5c 0x7e4c
[ 3.499805] [drm] Encoders:
[ 3.499807] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 3.499809] [drm] Connector 1:
[ 3.499810] [drm] DVI-D
[ 3.499812] [drm] DDC: 0x7e40 0x7e50 0x7e44 0x7e54 0x7e48 0x7e58 0x7e4c 0x7e5c
[ 3.499814] [drm] Encoders:
[ 3.499815] [drm] DFP3: INTERNAL_LVTM1
[ 3.548001] r8169 0000:02:00.0: eth2: link down
[ 3.548007] r8169 0000:02:00.0: eth2: link down
[ 3.548157] ADDRCONF(NETDEV_UP): eth2: link is not ready
[ 3.649329] [drm] fb mappable at 0xD8040000
[ 3.649332] [drm] vram apper at 0xD8000000
[ 3.649334] [drm] size 5242880
[ 3.649336] [drm] fb depth is 24
[ 3.649337] [drm] pitch is 5120
[ 3.650495] fbcon: radeondrmfb (fb0) is primary device
[ 3.652054] Console: switching to colour frame buffer device 160x64
[ 3.669036] fb0: radeondrmfb frame buffer device
[ 3.669040] drm: registered panic notifier
[ 3.669049] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:05.0 on minor 0
[ 3.994813] init: plymouth-upstart-bridge main process (479) killed by TERM signal
[ 4.683005] fuse init (API version 7.18)
[ 5.171528] r8169 0000:02:00.0: eth2: link up
[ 5.171634] ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[ 15.472499] eth2: no IPv6 routers present
[ 83.080175] I-pipe: head domain RTAI registered.
[ 83.080181] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 83.080221] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 83.080225] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12526606, CLK_FREQ 2705791000, CPU_FREQ 2705791000
[ 83.080228] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 83.080231] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12526606, 12526606, 12526500
[ 83.092575] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 83.092610] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 83.092614] RTAI[sched]: hard timer type/freq = APIC/12526606(Hz); default timing: oneshot; linear timed lists.
[ 83.092617] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2705791000 hz.
[ 83.092619] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 83.106322] RTAI[math]: loaded.
13 May 2018 18:14 #110692
OK nothing there (and you forgot to run sudo dmesg -c so theres a ton of irrelevant stuff)
what was the result of running linuxcnc from the command line?
13 May 2018 18:24 #110693
by punking
once i run linuxcnc the whole system locks up
thats why i couldn't get the log you want.
unless it is stored somewhere i can retrieve it after i do a hard restart
13 May 2018 18:45 #110694
The whole system locks up? you mean you no longer have any access to the machine?
I thought only the linuxcnc script hung because you said this:
"I kill the process off , go to start again and it says linuxcnc is already running."
LinuxCNC on Ubuntu 12.04 is not a normal distribution so there could possibly be some incompatibilities with 2.7
If you launch LinuxCNC from the command line you should get some messages even if it hangs
13 May 2018 18:57 #110696
by punking
if all i do is click my shortcut to start linuxcnc it tries to start and the banner just sits there. i kill linuxcnc from system monitor. the computer becomes minimal;ly responsive.
i try to start linuxcnc again but it says the instance is still running.
now
if i try to do the operations from terminal as you request; im not going to kill off linuxcnc , since i figured we want the info from the log. That is when terminal locks up, linuxcnc is still frozen as a banner and i have no access to system monitor or anything.... then i literally haver to shut down computer with the on/off buttonj.
now
14 May 2018 00:51 #110707
Banner? do you mean the chooser?
14 May 2018 10:14 - 14 May 2018 10:33 #110721
by punking
Last edit: 14 May 2018 10:33 by punking. Reason: added question, photo
14 May 2018 12:53 #110726
Can you run any of the sim configurations?
- General
Time to create page: 0.307 seconds
