Fresh install extremely slow
06 Jun 2018 20:29 #111788
by Ishtar
Fresh install extremely slow was created by Ishtar
I'm trying to migrate from Mach3 to LinuxCNC.
After I log in though, everything is incredibly slow. The best way I can describe it is I'm getting 1 frame per 5-10 seconds. If I leave the computer for 15 mins or so I can move the mouse fine until I mouse over an icon or click anything, then it's back to the way it was before.
I have tried installing on a partition to my SSD and a clean install on a wiped HDD. The computer is fairly old though, CPU is an Athlon 64. It had been running Windows 7 and Mach3 fine though, albeit Chrome was a little sluggish. I would have expected better performance than this though, is there anything I can check or is it a hardware problem?
New to Linux so please bear with me!
07 Jun 2018 16:23 #111896
Replied by andypugh on topic Fresh install extremely slow
This might potentially be a graphics problem, but before trying to fix that, what are the results of the latency test?
07 Jun 2018 17:38 #111905
by Ishtar
Replied by Ishtar on topic Fresh install extremely slow
I can't even get to the latency test
I really can't progress any further than logging in, the system is pretty much unusable after that.
Currently, I AM operating on integrated graphics. I'll try to find a graphics card and try again.
07 Jun 2018 17:48 #111907
I was meaning more to do with graphics drivers.
Which ISO did you load? It might be worth trying an alternative one (and maybe even a generic non-linuxCNC one)
07 Jun 2018 18:41 #111919
by Ishtar
Sure, it's 2.7, downloaded it the day before yesterday.
If I can boot into command line, what can I do to check the graphics drivers?
07 Jun 2018 18:59 #111922
Try this ISO instead (also 2.7 but a different kernel and Linux distribution)
www.linuxcnc.org/testing-stretch-rtpreempt/
07 Jun 2018 20:15 - 07 Jun 2018 20:27 #111931
by Ishtar
Thanks! That one is working MUCH better, a little jerky but I can live with it as long as it doesn't affect machining. I can get to the latency test now, result is 439010. Seems high?
EDIT. Make that 2223594
Last edit: 07 Jun 2018 20:27 by Ishtar.
07 Jun 2018 20:45 #111936
Yes, that's way too high to be useful, unfortunately.
I would normally suggest the SMI patch, but as this is an AMD CPU that would not be relevant.
There may be other tricks to improve latency with the preempt-rt kernel.
Or you could try comparing unmodified Stretch and Wheezy liveDVDs to see if the slow graphics problem is with the base Linux distribution or the LinuxCNC realtime architecture.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
07 Jun 2018 22:38 - 07 Jun 2018 22:42 #111944
by InMyDarkestHour
Replied by InMyDarkestHour on topic Fresh install extremely slow
What exact Athalon 64:
Runningwill give you the details of the cpu and what Motherboard ?will list the computer info, press enter to scroll down and q to quit
I've being getting some really good results on some old AMD platforms. If you can stretch it try and get an older Radeon graphics card.
Running
cat /proc/cpuinfo
sudo dmidecode | more
Last edit: 07 Jun 2018 22:42 by InMyDarkestHour.
08 Jun 2018 06:58 #111965
by Ishtar
CPU is an Athlon 64 X2 4600+ 2.4GHz, overclocked to 3GHz.
Motherboard has an AGP slot... Recommendations on a card would be good!
Would it make you laugh if I say I remember buying this CPU brand new?
I have no problem going out and trying to find a used PC with better specs if that's what's needed.
Time to create page: 0.339 seconds
