Problem Updating from 2.6 to 2.9
04 Jun 2023 18:43 #272897
by kt600v
Problem Updating from 2.6 to 2.9 was created by kt600v
Hello guys, I have a lathe with linuxcnc 2.6 wich I need to upgrade to 2.9
Updating from 2.6 to 2.7 worked fine by following the instructions from the manual.
Updating 2.7 to 2.8 : I used the script which converts configuration files automatically , when launching for the first time suddendly I get an error log (attached please zoom the image).At this point I coudn`t figure out the cause.I wonder if you guys would be willing to help me with this issue.
- Thank you received: 5933
04 Jun 2023 18:48 #272899
Replied by tommylight on topic Problem Updating from 2.6 to 2.9
Edit the custom_postgui.hal with a text editor (not office stuff), omit or delete the line 7 that contains
motion.spindle-brake
ONLY if you are not actually using a spindle brake.
The following user(s) said Thank You: kt600v
08 Jun 2023 13:28 - 08 Jun 2023 14:03 #273171
by kt600v
Replied by kt600v on topic Problem Updating from 2.6 to 2.9
Linuxcnc 2.8.4 works very well so far, I'm going to update to 2.9, I'll use the method wich consist of downloading the latest deb file (from buildbot) and installing it with dpkg. My question is ig this is a good way to go, or could anyone suggest me another one. thank you
Last edit: 08 Jun 2023 14:03 by kt600v. Reason: mistake
08 Jun 2023 15:28 #273179
Use gdebi to install debs, it is a GUI package manager and is a bit safer than dpkg
sudo apt install gdebi
after installing this, just double clicking on a deb file from the file explorer with open it, no need for terminal.
12 Jun 2023 02:09 #273365
by kt600v
I´ve a question, is it possible to roll back to previous version by installing older deb the same way Updates are installed?
13 Jun 2023 20:12 #273510
To some extent, yes.
To be safe, save the new or working debs, then
sudo apt purge linuxcnc-uspace
then try installing the deb you want.
14 Jun 2023 22:55 #273558
by kt600v
When trying to install lastest deb (2.9) I got some errors and it couldn't be updated (2.8.4 ==> 2.9). I couldn't install gdebi either so I used dpkg.
I made a new clean install but errors persist.
I couldn't figure out how to solve this. Need help
14 Jun 2023 23:26 #273559
sudo apt update
then
uname -a
lsb_release -a
then
uname -a
lsb_release -a
16 Jun 2023 23:37 #273725
by kt600v
sudo apt update
then
uname -a
lsb_release -a
this is what i get
16 Jun 2023 23:40 #273726
Something wrong with your repository file, what is the error from
sudo apt update
sudo apt update
Time to create page: 0.165 seconds
