inslaling ISO Linuxcnc 2.8.4
06 Oct 2023 13:58 #282440
by CNCGOOS
inslaling ISO Linuxcnc 2.8.4 was created by CNCGOOS
Hello All,
i am trying to instal Linuxcnc from USB iso
last Download form 6-10 15.30
I Get a Erro wen the system wants to install
Installation step Failed
thats after the Installer wants to Coppy Data to the disk
IS a New PC prodesk 600 G2 Intel I3 Core
have has a sugestion for me?
- Thank you received: 5945
06 Oct 2023 14:50 #282441
Replied by tommylight on topic inslaling ISO Linuxcnc 2.8.4
What is the exact error?
06 Oct 2023 17:28 - 06 Oct 2023 17:30 #282453
by CNCGOOS
Replied by CNCGOOS on topic inslaling ISO Linuxcnc 2.8.4
this was de message in the screen
Last edit: 06 Oct 2023 17:30 by CNCGOOS.
06 Oct 2023 17:38 #282455
Was this at the end of installation?
If yes, disable "secure boot" in the PC's BIOS settings.
06 Oct 2023 20:00 #282460
by CNCGOOS
this was just (30 sec ) after starting installation.
before these step i have te chose about the disks
06 Oct 2023 20:25 #282464
by CNCGOOS
i have tryed it with secure boot disabled en legacy on. same problem.
is refus a good tool to make the iso on a SD card .
or do i use only usb stiks in stead of usb sd card reader?
06 Oct 2023 21:22 #282467
Replied by rodw on topic inslaling ISO Linuxcnc 2.8.4
Linuxcnc 2.9 is days from being released on Debian 12 Bookworm. Likely over this weekend.
Bookworm has much better support for Secure boot/UEFI
Please try my prerelease installer. It will probably solve your problem.
www.forum.linuxcnc.org/9-installing-linu...xcnc-x86-only#278427
Once you do a sudo apt upgrade, Linuxcnc will be right up to date as the last remaining issue has been resolved.
The following user(s) said Thank You: CNCGOOS
06 Oct 2023 21:26 #282468
by CNCGOOS
Thanks for the advies
I will try it tomorrow Dutch time
08 Oct 2023 11:23 - 08 Oct 2023 11:36 #282535
by CNCGOOS
instalation went oke after i canhed from sd card to USB Stick.
now i am strugglinf wit my Pythom change dialog
first error was un rule 59. wen i comment that line next errorline was 75
do i have to change the ril 59 from
print "change_prolog: Toolchanger soft fault %d" % int(self.params[5601]) to
rint ("change_prolog: Toolchanger soft fault %d" % int(self.params[5601]))
wenn i edit the file in visual studio code the red under highlight is gone afte i Add ( and )
Last edit: 08 Oct 2023 11:36 by CNCGOOS.
09 Oct 2023 00:42 - 09 Oct 2023 00:43 #282575
At a guess, your python script is Python 2.7. It needs to be Python 3 compliant today.
use the components supplied on the installation disk and you should be OK
Last edit: 09 Oct 2023 00:43 by rodw.
Time to create page: 0.168 seconds
