Show axes letters instead numbers
- isladelobos
03 Jun 2016 07:09 #75389
by isladelobos
Show axes letters instead numbers was created by isladelobos
How?
In the .ini file?
Or hal file.
This is one XYZBCW steppers machine.
I use for display tkem
In the .ini file?
TRAJ]
#+ machine specific settings
AXES = 9
COORDINATES = X Y Z B C W
HOME = 0 0 0 0 0 0#- Introductory graphic
INTRO_TIME = 5
EDITOR = gedit
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
GEOMETRY = XYZBCUVW
#LAST_POSITION = last_position.txtOr hal file.
03 Jun 2016 10:25 #75397
Replied by andypugh on topic Show axes letters instead numbers
Which kinematics file are you using? Which version of LinuxCNC?
- isladelobos
03 Jun 2016 12:52 - 03 Jun 2016 12:53 #75411
by isladelobos
Replied by isladelobos on topic Show axes letters instead numbers
Hi.
Im using 5axiskins with 2.6.8
Last edit: 03 Jun 2016 12:53 by isladelobos.
03 Jun 2016 12:56 - 03 Jun 2016 13:16 #75414
I don't know how to switch from Joint Mode to World Mode in tklinuxcnc.
In the Axis interface you use the $ keyboard shortcut.
tklinuxcnc is currently deprecated, and is probably a poor choice for a non-trivial kinematics machine.
This was mainly incorrect info.
Last edit: 03 Jun 2016 13:16 by andypugh.
03 Jun 2016 13:16 #75420
Use the "World Mode" checkbox to display XYZ rather than 012.
The following user(s) said Thank You: isladelobos
- isladelobos
03 Jun 2016 13:28 - 04 Jun 2016 15:59 #75422
by isladelobos
Stuff !!! thas was simple!!!
Thanks and sorry for the delay.
Last edit: 04 Jun 2016 15:59 by BigJohnT. Reason: G rated forum
Time to create page: 0.117 seconds
