External E-Stop
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
17 Nov 2012 00:38 - 12 Nov 2013 20:35 #26684 by BigJohnT
External E-Stop was created by BigJohnT
This method uses the ESTOP_LATCH component to connect up an external physical E-Stop to LinuxCNC.
# estop
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <=  parport.0.pin-in10-not
The typical estop loopback looks like this so either comment it out or remove it.
#  ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
Last edit: 12 Nov 2013 20:35 by BigJohnT.
The following user(s) said Thank You: akb1212, stratcat, OT-CNC, kt600v, ikkuh
18 Nov 2012 12:21 #26739 by jmelson
Replied by jmelson on topic External E-Stop
net remote-estop estop-latch.0.fault-in <=  hm2_5i20.0.gpio.025.in_not
Well, if you are going to post hardware-specific code, I have to match that with the
code that I use with my hardware.
# connect e-stop write/sense to I/O controller
# and ppmc's fault with estop's output, so  estop FF is reset, but
#      prevent continued estop signal from ppmc from holding FF cleared
newsig ppmcEstop bit
linksp ppmcEstop ppmc.0.din.estop.in
linksp ppmcEstop and2.0.in0
newsig EstopOkIn bit
linksp EstopOkIn estop-latch.0.fault-in
linksp EstopOkIn and2.0.out
newsig EstopOkOut bit
#linksp EstopOkOut ppmc.0.dout.07.out
linksp EstopOkOut ppmc.0.dout.Estop.out
linksp EstopOkOut iocontrol.0.emc-enable-in
linksp EstopOkOut estop-latch.0.ok-out
linksp EstopOkOut and2.0.in1
newsig emc-estop-out bit
linksp emc-estop-out iocontrol.0.user-enable-out
linksp emc-estop-out estop-latch.0.ok-in
newsig emc-estop-reset bit
linksp emc-estop-reset iocontrol.0.user-request-enable
linksp emc-estop-reset estop-latch.0.reset
This links up a hardware Estop sense circuit and estop latch
with a software one in LinuxCNC. Anthing that breaks the
Estop sense loop in the hardware, or a software command
to go to E-stop will cause both hard and soft E-stop latches
to go to E-stop. Only when the hardware Estop chain is
closed and the software command is given to come out of E-stop
will it do so. The hardware also has a watchdog timer to cause
an E-stop if LinuxCNC stops controlling it.
The timing of these functions is critical, as handled
by the order of addf's in the ppmc_load.hal file.
addf and2.0 servo-thread
Since there is a delay of one servo cycle between sending a command to
the hardware and reading back the status, these operations have to be
done in the right order.
Jon
  • BigJohnT
  • Administrator
  • Administrator
18 Nov 2012 22:02 #26751 by BigJohnT
Replied by BigJohnT on topic External E-Stop
That was not my intention I just quickly copied and pasted the example I had at hand.
19 Nov 2012 04:57 #26779 by jmelson
Just a little ribbing, I should have thrown in one of those :laugh:
emoticons!
Jon
08 Aug 2016 16:04 #78495 by cparsons
Replied by cparsons on topic External E-Stop
I am trying to get my estop to work - and saw your example, I am going to do some experimenting but wondered if the line
should be
net remote-estop estop-latch.0.fault-in <= parport.0.pin-10-in-not
I also wondered what the line 'addf estop-latch.0 servo-thread' does - I don't have servos, I have stepper motors??
Regards
Chris
08 Aug 2016 17:06 #78496 by tommylight
Replied by tommylight on topic External E-Stop
should be
Regards
Chris
Yes it should.
Tom
  • BigJohnT
  • Administrator
  • Administrator
14 Aug 2016 21:49 #78775 by BigJohnT
should be
Regards
Chris
If you don't have normally closed estop then yes you need to change the input.
The "servo-thread" is for some reason unknown to me means the slower thread with math and has nothing to do with the drives you may be using.
JT
14 Aug 2016 21:53 #78776 by tommylight
The first line has an error at "....in10-not....", should be ".....10-in-not".
regards,
Tom
30 Aug 2016 19:04 #79737 by OT-CNC
Replied by OT-CNC on topic External E-Stop
# estop
loadrt estop_latch
Thanks for posting this. My E-stop circuit is now improved.
I'd like to add my limits to the estop circuit through software if necessary. As physically wired, I can't run the limits in series with the estop. What is your opinion on this? This would protect the machine only from a drive failure. I'm using DMM servo drives in step mode and I don't know how they would react if an encoder wiring would fail down the road. Runaway? Or is it safe enough to rely on a drive enable signal to disable the drive? Linking the limit signal to disable the drives?
15 Jan 2019 19:01 - 15 Jan 2019 19:03 #124257 by LinfieldGarage
Replied by LinfieldGarage on topic External E-Stop
I know this is an old thread but it helped me get my estop working.
Here is a working config from my system running Master branch 2.8 and a Mesa 7i96 board. My estop button is N/C and is a 24 volt input to GPIO 010 on the Mesa board. Just change the last line for your particular board and GPIO pin.
# create a signal for the estop loopback
#config from BigJohn#
loadrt estop_latch
net remote-estop estop-latch.0.fault-in <= hm2_[HOSTMOT2](BOARD).0.gpio.010.in_not
Last edit: 15 Jan 2019 19:03 by LinfieldGarage.
The following user(s) said Thank You: ikkuh, Project_Hopeless, rgb
Time to create page: 0.183 seconds
