1987 engraving machine recyceling...
- gobo38
- Topic Author
11 years 1 month ago - 11 years 1 month ago #62730
by gobo38
1987 engraving machine recyceling... was created by gobo38
Hello ,
want to show you my milling machine made of an 1987 Gravograph VX.
I changed the power supply, the controller board and the engraving spindle to some own build parts.
The machine can work at 300x200x60mm and runs with LinuxCNC absolutely perfect.
regards Guenther
regards Guenther
Last edit: 11 years 1 month ago by gobo38. Reason: correction
11 years 1 month ago #62731
Replied by tommylight on topic 1987 engraving machine recyceling...
Nice setup, you can do a lot of things with it, just let your imagination run free, and do not be hindered by small size, you can divide work into 2 or 4 or more parts.
Regards,
Tom
Regards,
Tom
- Rick G
- Thank you received: 114
11 years 1 month ago - 11 years 1 month ago #62740
by Rick G
Replied by Rick G on topic 1987 engraving machine recyceling...
Looks good!
Thanks for sharing.
Rick G
Thanks for sharing.
Rick G
Last edit: 11 years 1 month ago by Rick G.
- kornphlake79
- Thank you received: 10
11 years 1 month ago - 11 years 1 month ago #62793
by kornphlake79
Replied by kornphlake79 on topic 1987 engraving machine recyceling...
That looks very similar to my machine, built from a Hermes vanguard 7200. I removed the engraving head and made a custom bracket to hold a trim router I can reposition the router in the bracket manually to get an effective z axis travel of about 4 inches. I had the power supply and stepper driver from the original machine that I used instead of making one. It was a hassle though, if I had more money to invest in the machine I would have done something more like you did.
Last edit: 11 years 1 month ago by kornphlake79.
- daboom01
5 years 1 month ago #219922
by daboom01
Replied by daboom01 on topic 1987 engraving machine recyceling...
I know this is a longshot replying to an old thread, however my dad has 6 of these machines we would like to get going and i am wondering if any of you could share a bit more about what you did? any help would be amazing.
thanks in advance.
thanks in advance.
- gobo38
- Topic Author
5 years 1 month ago #219970
by gobo38
Replied by gobo38 on topic 1987 engraving machine recyceling...
Hi, first i made a steel cylinder with two ball bearings and a ER11 axle(from aliexpress) that is fitting in the holder where the engraving spindle is. Then i made two very simple circuit boards, one as power supply, the other for controlling the machine. If you want i can send you the eagleCAD files. the whole electronic fits in the right side of the gravograph. It is designed for parallel port only! you can also try a cheap cnc board with stepsticks (also from aliexpress).
Time to create page: 0.080 seconds
