1984 Cincinnati Milacron VMC with 4th Axis
- LAIR82
- Thank you received: 3
10 Nov 2015 18:04 - 23 Dec 2015 14:06 #65087
by LAIR82
1984 Cincinnati Milacron VMC with 4th Axis was created by LAIR82
Here is our first VMC that we have done, this is a small clip of the tool changer in action, it utilizes the Carousel Component, and a pretty hefty chunk of ladder logic to run all of this.
More to come !!!!!!!!!!!!
RIck
RIck
Last edit: 23 Dec 2015 14:06 by LAIR82.
The following user(s) said Thank You: robins
- OT-CNC
- Thank you received: 75
25 Nov 2015 22:35 #65803
by OT-CNC
Replied by OT-CNC on topic 1984 Cincinnati Milacron VMC
Congrats!
- Jake
- Thank you received: 10
30 Nov 2015 01:05 #66074
by Jake
Replied by Jake on topic 1984 Cincinnati Milacron VMC
Awesome!
I have a Hurco that I am going to get on Thursday, hopefully I will be able to pull off getting the tool changer working also.
- BigJohnT
- Thank you received: 994
01 Dec 2015 00:26 #66142
by BigJohnT
Replied by BigJohnT on topic 1984 Cincinnati Milacron VMC
Nice!
Almost as slow as my BP Discovery 308 on tool change lol...
JT
JT
- LAIR82
03 Dec 2015 12:18 #66277
by LAIR82
Replied by LAIR82 on topic 1984 Cincinnati Milacron VMC
Thanks Guys,
Update,
The machine is now pretty much fully functional,
The tool changer/carousel works using the Carousel component, it has the Moveoff component installed and working (so now we can Jog While Paused Woo-Hoo), and now it has a "A Axis" 300mm DIA Rotary contouring table outfitted with a 3kw servo drive with encoder feedback, with a internal hydraulic disc brake that is automatically commanded based off of the velocity command for the servo, so _NO_ operator involvement on setting or releasing the brake.
As soon as I get all my tools/BS off of the machine, and we get our first test piece running, I will take some more video and post it,
More to Come,
Rick
Update,
More to Come,
Rick
The following user(s) said Thank You: Arpad
- LAIR82
07 Dec 2015 18:13 #66570
by LAIR82
Here is our first test part, random program the boss made,
Rick
Rick
- Thank you received: 2181
07 Dec 2015 21:38 #66584
Replied by cmorley on topic 1984 Cincinnati Milacron VMC
That is awesome Rick!
I think you have earned 'expert level' integrator
I'm of course very happy that you are finding the Gscreen-Industrial screen useful.
Are your operators finding linuxcnc difficult to adapt to?
- LAIR82
22 Dec 2015 19:34 #67244
by LAIR82
Here is the second job on the machine, Windmill components,
The part has mounting holes around the circumference in the large tapered section, that had to be perpendicular to the taper, so we mounted the A axis at the corresponding angle, getting ready to make some chips now.
Try to post a video when we actually start machining this.
- LAIR82
11 Jan 2016 20:28 #68198
by LAIR82
Here is another part for that goes along with the second part we ran.
4000 RPM
189 IPM
5/8" DIA cutter
0.030 Depth of cut
Rick
4000 RPM
189 IPM
5/8" DIA cutter
0.030 Depth of cut
Rick
- LAIR82
12 Jan 2016 12:58 #68232
by LAIR82
And This is the finishing operation on the previous part,
Full X-Y-Z movement on each pass!!!!!
Definitely some very powerful software!!!!!
Rick
Rick
Time to create page: 0.471 seconds
