My first CNC - begged and borrowed all the way.
- JammyJulien
23 Sep 2016 07:46 #80823
by JammyJulien
My first CNC - begged and borrowed all the way. was created by JammyJulien
Hello all,
I browsed through the "Show Your Stuff" section and realised my machine is pretty small fry compared to some of your creations ! I am in awe!
However, somewhat humbled, I though I'd share my progress so far anyway. This project has cost me under £100 so far. I've managed to get the steppers from salvage - it's using 8mm lead screws. I 3D printed mounts and other parts as required.
Next step is to get the wiring / end stops etc done - thanks to BigJohnT for the support getting LinuxCNC installed.
I have no idea how capable it will be - but if it cuts wood and not my fingers it'll be a good start.
- Thank you received: 5951
23 Sep 2016 10:53 #80825
Replied by tommylight on topic My first CNC - begged and borrowed all the way.
Nice for starters, for sure. When you see it moving, that is very satisfying and rewarding.
Regards,
Tom
Regards,
Tom
The following user(s) said Thank You: JammyJulien
- JammyJulien
23 Sep 2016 10:57 #80827
by JammyJulien
Replied by JammyJulien on topic My first CNC - begged and borrowed all the way.
Thanks for the encouragement Tom !
23 Sep 2016 11:48 #80828
You are welcomed, always.
23 Sep 2016 23:12 - 23 Sep 2016 23:14 #80842
by BigJohnT
Replied by BigJohnT on topic My first CNC - begged and borrowed all the way.
You're machine is looking good! Don't matter the size, just that you make it work for you. When you design the limit/home switches make them so you can't crash them.
My home made plasma in it's early stages. Notice the support structure (saw horses) lol.
JT
JT
Last edit: 23 Sep 2016 23:14 by BigJohnT.
- JammyJulien
26 Sep 2016 06:53 #80920
by JammyJulien
Thanks John,
My machine looks like its made of Lego compared to yours ! But hey - it's my first attempt - if this works I going to slowly build something bigger and more capable.
What did you mean about the limit switches ? I haven't got there yet - I was just going to print a holder for micro switches which will bolt onto the extrusion. Is there something I should watch out for ?
Regards
Julien
Regards
Julien
26 Sep 2016 23:35 #80963
by BigJohnT
You want the limit switch design so you can't crash into them but rather pass over them if things mess up.
JT
JT
- JammyJulien
27 Sep 2016 06:31 #80969
by JammyJulien
Gotcha - thanks again John.
- dennis.lewis5
01 Oct 2016 17:49 #81130
by dennis.lewis5
Replied by dennis.lewis5 on topic My first CNC - begged and borrowed all the way.
I think you have a great project going there. I have been in the build process for several years now. I had a test run yesterday and it got through that phase.
Just keep at it. There is a lot to learn in the whole process.
Good Luck.
Good Luck.
12 Oct 2016 07:26 #81570
by janriis
Replied by janriis on topic My first CNC - begged and borrowed all the way.
Hi
I am completely new to this forum. Your build looks great. Any chance you might share drawings and parts lists ?
Time to create page: 0.172 seconds
