28 May 2013 18:44 #34821 by mariusl
Hi Nortbert
I did this but still get the old screen
git reset origin/master --hard
git fetch --all
./autogen
./configure
make
sudo make setuid
Is there another way for me to get the code?
Regards
Marius
www.bluearccnc.com
28 May 2013 19:28 #34823 by newbynobi
Halo Marius,
in the title line of the screen you will see the gmoccapy version.
it should say
gscreen - gmoccapy for linuxcnc 0.9.3.1
if so, you got the latest version.
If you got 0.9.3.1, please go to the settings page and adjust the height of the GUI. If you don't use the settings page, gmoccapy will use the settings from your hidden preference file, whitch at the moment are the old ones.
You can also just delete your hidden preference file.
Norbert
28 May 2013 19:37 #34824 by mariusl
Norbert
I have 0.9.3.
Did I do the pull right?
Regards
Marius
www.bluearccnc.com
28 May 2013 19:53 #34825 by newbynobi
Halo Marius,
normaly it is enough to give a
git pull
to get the newest version.
If you want a new clone just do :
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
after deleting your linuxcnc-dev directory.
Buut attention you will loose the changes you made by your own.
Don't forget :
cd linuxcnc-dev
 cd src
 ./autogen.sh
 ./configure
 make
 sudo make setuid
 cd ..
 . ./scripts/rip-environment
 linuxcnc
after that.
Norbert
28 May 2013 19:53 - 28 May 2013 19:55 #34826 by newbynobi
dobble posted
Last edit: 28 May 2013 19:55 by newbynobi.
28 May 2013 19:56 #34827 by mariusl
Norbert,
I redid the pull and now I have the latest files.
Is there a way to change the 750 minimum or is it hard coded?
Regards
Marius
www.bluearccnc.com
28 May 2013 20:01 #34828 by jlviloria
Norbert problem time error, I have a problem in my spindle scale.
when I run s100. LinuxCNC s180 shows me running.
I'll work on this have if I can fix this problem
Jorge Viloria
Barranquilla - Colombia
28 May 2013 20:03 #34829 by newbynobi
Hallo Marius,
it is hard codded, I can tell you how to change the value, but I do not recommend it.
If you make the screen smaller than this, the widgets will overlap each other, because they do need certain space.
Just see the settings page with 750 set, you will see that there the widgets will begin to hide each other.
Best is to use a screen size not smaller than 768, I just choose 750, because this value is the smallest I have been able to realize without investing to much time.
Norbert
28 May 2013 20:06 #34831 by mariusl
Norbert,
It is looking very good. Can I give some feedback if I may please?
1: The DRO tab opens up to big so the DRO are cut off to the right
2: The last button on jog increments shows inches while the rest show mm
3: Under settings - the keyboard shortcuts frame is to small
4:In the settings - appearance-dro the first radio button label has a typo (Schow -> Show)
Thanks a lot for all your hard work on this. I am really happy that you are doing it for us.
Regards
Marius
www.bluearccnc.com
28 May 2013 20:12 #34832 by newbynobi
I do not understand very well, but I will try:
You enter in MDI the following code
S100 M3
after starting and homing the machine,
then the label in the spindle frame should say S 100
If not, please check the spindle override!
Moderators: newbynobiHansU
Time to create page: 0.173 seconds
